So I have finally (mostly) completed this swap. I have searched the forums and found some good information but found myself with a lot of questions that needed to be answered. Instead of hijacking another thread, I decided to start my own write up. My setup is a 2010 SR5 with the basic stereo head unit. I’ve been wanting to upgrade for a long time but kept holding back because I either didn’t have the info I needed, or I couldn’t find the right deal on an Entune. I really like the factory look and wanted something that would integrate well. A hat tip to these posts that got me most of the way there.
OEM head unit swap to non-JBL entune
https://www.tacomaworld.com/threads/...umbers.318616/
Wiring diagrams (can’t remember the thread I pulled this from, but thank you!)
http://www.toyota-4runner.org/attachments/5th-gen-t4rs/157284d1431460549-2015-trail-nav-wiring-diagram-bui.pdf
http://www.toyota-4runner.org/attachments/5th-gen-t4rs/157285d1431460567-2015-trail-nav-wiring-diagram-sep.pdf
I’ve spent hours researching connectors, wiring diagrams, photos, compatible parts etc. and have come up with this list of factory and aftermarket parts. This, I believe, is the least expensive route after comparing everything and options.
Parts:
Entune from a 2017 Trail bought from a forum member
$27 (plus $7 for shipping) 20/8 to 28 pin adapter PT546-00120-CH
https://parts.mcgeorgetoyota.com/oem...k-pt54600120ch
$8.50 DHT Electronics External GPS
https://www.amazon.com/dp/B00D1G6HCA?ref=yo_pop_ma_swf
$13.27 Metra 40-LX21 Lexus Radio Antenna Adaptor 2009-Up
https://www.amazon.com/dp/B003VYTGUC/ref=cm_sw_r_cp_api_RJVQBbK18S5FC
$15 24 pin connector for back-up camera AX-TOYCAM3
https://www.amazon.com/dp/B01E4B6UQS/ref=cm_sw_r_cp_api_6RgOBb6GH88DE
$11.25 USB adapter
https://www.amazon.com/dp/B00XKUVJQG..._RuiNBbCTGVTDB
Listed for reference, but I didn’t buy this part since I don’t use the USB.
$28 Sat Radio Adapter
XMM-TOY Sat. Radio Antenna Adapter Cable for Toyota and Subaru :: Antennas, Adapters and Boosters :: Car Stereos and components
Listed for reference, but I didn’t buy this part since I don’t use sat radio.
The thing that was throwing me for biggest loop was understanding what each plug on the back of the Entune was for. Below is a photo that gives a high level understanding.
After studying a wiring diagram, I could verify what parts to look for. I think the GPS antenna was the biggest “leap of faith” on this project. Obviously spending $200 - $300 on a factory antenna was not going to cut it, however, there isn’t one on the market with that connector plug. I even tried to search for just the connector on the Toyota parts site, but I don’t think Toyota sells it. I spent a ton of time researching GPS antennas and connectors and finally decided to try the one in the link above and it fits perfectly! Trust me, there’s no falling out with this thing, it’s on there. That custom Toyota connector is a joke. FYI, the radio connectors (nav, sat and AM/FM)… (maybe this was obvious to some, but definitely not me) for the record, they’re all female SMB connections.
To place the GPS antenna, remove the clock in the dash (two screws, very obvious), it’ll expose the area where the stock GPS antenna would go (between the vents). I literally just made sure it was right side up and placed it in there. The GPS signal picked up within a couple mins and works perfectly!
Everything is straight plug and play (except the backup camera). From what I can tell, nav, apps, HD radio, Bluetooth (phone and audio), and the steering wheel controls also work.
In order to activate the premium apps, search for a 4Runner online for sale or whatever with premium Entune and grab the VIN. You’ll need this for verification/activation.
Next steps…
1) The backup camera is going to be a bit of a hack, but I know it’ll work out fine since the wiring diagrams have the wires labeled, and the harness seems to have all the connections I’d ever need for it. I need to purchase some wire and make the runs. Admittedly, I don’t need this since my mirror provides the backup camera, but I want to see this work. There are write ups to access the wires, etc. While in here, I plan to do the rearview on demand hack.
2) Replace the LEDs with color matching ones, either new or from my old head unit. I took apart my old radio, these suckers are small. When I tried to search for them online, they appear to be less than 1mm wide total. Currently looking to desoldering techniques.
3) Painting or replacing the silver plastic in the rest of the 4Runner to match the black.
Hope this helps anyone looking to do the same! I’ll post updates as they come along, but with a new baby, it’s a little tough to find the extra time
