Old 09-20-2023, 01:12 PM #106
osugsxr osugsxr is offline
Originally Posted by Uni1brow View Post
Tried that.
need more detail to your set up
the balance to the right is the first step.
try the following:
double check the harness wiring to ensure the wires are pinned & in the proper slots
all harness connections are secure, no cut wires etc.
Old 09-20-2023, 03:21 PM #107
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Got a entune with nav but only 4 speakers work, 2 front left side and left rear hatch. Why? I'm puzzled
From what I understand, depending on what you had from the factory, you need to find the correct replacement headunit. ie With or without JBL, nav, GPS etc. This may be why some functions may not be working.
For example, for me I needed to find a non-JBL with GPS as I did not have JBL from the factory. Just a thought...
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 01-22-2024, 09:57 AM #108
Brandonium's Avatar
Brandonium Brandonium is offline
Real Name: Brandon
Brandonium will become famous soon enough
Brandonium's Avatar
Real Name: Brandon
Were you able to retain party mode with this swap?
Originally Posted by Chadical View Post
I did it! I found a salvage 2020 non-JBL nav head unit and I have successfully retrofitted it into my 2012 TE!
The 2020 HU was not cheap, even for one from a salvage vehicle it still ran $700, and I feel like I still got it for way cheaper than these can be found for.
If you look at the connectors on the 2020 Entune 3.0 HU versus the 2014-2019 Entune 2.0 HU, nearly all are different. So I found this thread on a Tacoma forum where a few folks had retrofitted an Entune 3.0 HU into older models: New 2020 head unit. Buying? | Page 18 | Tacoma World
After some research I determined that all Entune 3.0 HU's share the same connectors, 4Runner included. Obviously the key to it working was getting a harness that would work. Long story short, I contacted the amazing folks at AutoHarnessHouse|Plug and Play Car Wiring and Audio Gear and they were able to create a custom harness that would allow plug-in-play from the Entune 2.0 connectors into Entune 3.0 connectors. And I'm pleased to say it works perfectly! The harness set me back $190. This includes a connector that enables the navigation to work on the newer unit. If you don't need nav on the HU, then the harness only costs $135.
- Radio: The only connector that required no retrofit.
- GPS: I was able to re-use the gps unit that mentioned in my earlier posts
- Backup camera: See my earlier posts, but I had to create a custom harness from splicing together two Axxess harnesses
- USB: Entune 3.0 HU's use a new connector... Purchased this for $21: Metra Online
- XM Radio: My 2012 apparently has a different XM radio unit than the 2014 and up models, so the adapter that I tried didn't work in either the Entune 3.0 or 2.0 HU's. It might work for folks with 2014+ models. Which is fine, I don't use XM radio
- Entune Apps: Based on people in the Tacoma forum and the message I see on the Entune 3.0 HU, the apps seem like they will work if I had the entune app on my phone.
The install was pretty easy overall. After the initial start, it took like 10 minutes for GPS to reset. It also took about 10-15 minutes for bluetooth to start working. Thankfully, the backup camera works fine using my custom harness too. Android Auto worked immediately when I connected my phone via usb.
All in all, I love the 2020 Entune 3.0 HU. The 8" screen is awesome. After having the T9 and 2017 Entune 2.0 HU, the 2020 HU seems to be the best. The sound quality is on par with the T9. I don't regret going to all of this trouble with how good it turned out. I've also gotta say, the new HU looks so good in my vehicle.
If anyone wants to purchase my Beat Sonic unit that allows CarPlay/Android Auto in the 2014-2019 HU's, send me a message. I've also got a 2017 Entune 2.0 HU if anyone wants it (which I will sell for extremely cheap).
One final caveat: This only works for non-JBL head units. If you have a JBL sound system, you are unfortunately SOL.
One last thing, my apologies to the OP of this thread - I am still a junior member on this forum so I am unable to create new threads. Sorry if I hijacked your thread.
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
Brandonium is offline   Reply With QuoteReply With Quote
Old 01-22-2024, 10:23 AM #109
Brandonium's Avatar
Real Name: Brandon
Brandonium's Avatar
Real Name: Brandon
Those are extra buttons that the Entune 2.0 HU utilized that is not utilized in the earlier units or the newer Entune 3.0 HU. Only real option would be to swap out to earlier 4Runner wheel controls if it bothers you.
Originally Posted by emmantik View Post
I recently did the swap - adding a 2020+ headunit to my 2015 SR5 PREM with navigation. The only thing I noticed that did not work was the rewind/fastforward buttons on the steering. Also, the up down controls when in phone and other settings. Has anyone else noticed this? Was there a fix? Thanks!
entune , navigation , radio , stereo , swap
OEM head unit swap to non-JBL entune DLSWyo 5th gen T4Rs 11 06-22-2019 12:14 PM
2012 4Runner swap entune head unit for a 2015 pedrorl 5th gen T4Rs 14 06-18-2019 12:33 AM
Bought premium entune to replace basic no entune apps 4runick 5th gen T4Rs 18 12-23-2016 01:34 PM
Swap 2010 Nav for 2012 EnTune? jangoforhire 5th gen T4Rs 9 01-26-2013 12:25 PM
To entune on not to entune? TOMMYTHETECH 5th gen T4Rs 27 08-31-2012 03:02 AM
