Thread Tools Rating: Thread Rating: 4 votes, 3.25 average. Display Modes
Old 10-02-2018, 12:59 PM #1
TOTAL CHAOS TOTAL CHAOS is offline
TOTAL CHAOS will become famous soon enough TOTAL CHAOS will become famous soon enough
TOTAL CHAOS Long Travel *Discussion* Thread
We wanted to create a Long Travel Discussion Thread!
This is a place to discuss ANYTHING Total Chaos Long Travel!
Post questions, pictures, feedback, tips/tricks, etc. We are happy to help
[email protected]
TOTAL CHAOS
WWW.CHAOSFAB.COM
TOTAL CHAOS Long Travel *Discussion* Thread-687474703a2f2f7777772e6368616f736661622e636f6d2f696d616765732f6c6f676f732f74632d6f72616e67652d38-png
___________________________________
2010-2018 4RUNNER Long Travel Suspension Systems
TOTAL CHAOS is offline   Reply With QuoteReply With Quote
Old 10-02-2018, 01:08 PM #2
PRODUCT SPOTLIGHT +2" Race Series Long Travel
2010-2018 4Runner +2" Race Series Long Travel
- 100% chromoly constructed Race System offers maximum ground clearance and weighs 16.8 pounds less than the standard TC +2" LT kit.
- 2" extended 4130 chromoly tubular upper arms bolt to factory control arm mounting locations. Pre tabbed for dual shock capability.
- Upper and lower ball joints are replaced with 1" uniballs for maximum wheel travel and component strength. TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
- Lower control arms feature an integrated uniball cup that provides 2.5" additional ground clearance when compared to the standard mild steel +2" LT kit. On top of that, Lower arms are 8.4 pounds lighter each side than the standard +2" LT kit.
- 2.5" long travel specific coil over shocks bolt into the factory coil bucket location. Extended travel shocks are too short and will not work.
- A secondary external bypass shock can be installed to increase dampening and tune-ability.
- Adjustable limit strap clevis' are included so that you can properly limit the suspensions droop wheel travel and make necessary adjustments during the life of the limit strap.
- DOT approved stainless steel braided brake lines, TC custom 17-4 stainless hi-misalignment spacers and all grade 8 mounting hardware is included.
- TC 4340 custom extended axles reuse factory inner and outer CV's to retain 4wd.
(axles are sold separately and not included with the kit)
- 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
- Hand crafted in the U.S.A.
- Fiberglass fenders not required on FJ Cruisers. 4Runners are limited to 275/70R17 tires unless fiberglass is installed. Fiberglass fenders or extreme fender modifications/cutting required on Tacoma.
*If FOX Shox will be used, an "F" must be added to the LT kit part number, i.e. 86002-R-10FJ-F
LIFT: 3-4"
TRAVEL: 11.5"
TIRE: 33" or 285
TRACK WIDTH INCREASE: 4"
Click Here for more information
Old 10-09-2018, 10:49 AM #3
Let's see your TOTAL CHAOS Long Travel Systems in action!
Comment below with a photo of your ride. On social media? Tag our Instagram
https://www.instagram.com/totalchaosfabrication/
TOTAL CHAOS
WWW.CHAOSFAB.COM
Old 10-09-2018, 12:07 PM #4
MTN4RNR's Avatar
MTN4RNR MTN4RNR is offline
Real Name: Max
MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough
MTN4RNR's Avatar
Real Name: Max
2016 MGM Trail Premium - KDSS
Explore4R.com
Building the MTN4RNR
Instagram --- life.to.the.max
Writer/Editor at Trail4Runner.com
MTN4RNR is offline   Reply With QuoteReply With Quote
Old 10-09-2018, 01:47 PM #5
litezzz litezzz is offline
litezzz is on a distinguished road
For those that daily drive their rigs. Curious to see who has the highest mileage on their LT setup? Any gripes or pure stoke?
litezzz is offline   Reply With QuoteReply With Quote
Old 10-09-2018, 02:14 PM #6
puckitpuck's Avatar
puckitpuck puckitpuck is offline
puckitpuck will become famous soon enough
puckitpuck's Avatar
Will LT set up work with KDSS?
IG @ BAJA4RN 2015 4runner TPE, Grey, 285/70/17 BFG KM3, Method 105 17x9 3.50" BS 6x139.7, Magnuson SC, FrontRunner Slimline II, ARB Summit front bumper, Bruteforce Rear, Safari Snorkel, Autohome Columbus RTT, Alu Cab Shadow Awning,Quick Pitch Ensuite, King Shocks OME 2.5", Dometic CFX 65W, REDARC Multi-Stage charger, 100W solar panel, 80ah 2nd AGM battery, BAMF sliders
puckitpuck is offline   Reply With QuoteReply With Quote
Old 10-09-2018, 02:14 PM #7
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
How could I test the quality of these claims as well as actual travel dimensions. I would be willing to install on my 4Runner at NO cost to you. I can email you my address so you can send a complete set.
Thanks in advance.
(Hey, you never know unless you try)
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is offline   Reply With QuoteReply With Quote
Old 10-09-2018, 02:58 PM #8
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Without opening up a can of worms, I’d be curious to learn if you’ve ever considered offering an LT kit with rubber bushings? Noise and the frequency of greasing/maintenance seem to be the biggest detractors I heard people talk of. Maybe even combined with ball joints instead of uniballs.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 10-09-2018, 03:04 PM #9
MTN4RNR's Avatar
Real Name: Max
MTN4RNR's Avatar
Real Name: Max
This has been talked about a bit already (check out this thread...), and the short answer is no. KDSS will negate the benefits of LT, and beyond that, KDSS isn't supported with any LT options. It would have to be something custom.
Explore4R.com
Old 10-09-2018, 03:05 PM #10
rochmpr's Avatar
Real Name: Krister
rochmpr's Avatar
Real Name: Krister
No, they are not compatible.
Old 10-09-2018, 03:26 PM #11
We've got many customers with anywhere from 10k-100k on their systems. Hopefully we have a few that chime in here
Good question - a Long Travel System will not work with KDSS.
TOTAL CHAOS
TOTAL CHAOS FABRICATION
Old 10-09-2018, 03:33 PM #12
dot_tom's Avatar
dot_tom dot_tom is offline
Real Name: Tom
dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all
dot_tom's Avatar
Real Name: Tom
I wish. Like @rochmpr said, Anyone want to give me a kit to try out I'll be more than happy to! haha
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
dot_tom is offline   Reply With QuoteReply With Quote
Old 10-09-2018, 03:46 PM #13
We have not considered a rubber bushing option or ball joints on a Long Travel System.
These kits were designed to handle serious off-road use without any problems! We've found the urethane bushings offer great performance while being easy to maintain and replace if needed. Same applies for the uniball, our 100% stainless steel uniballs are some of the strongest on the market and offer superior corrosion resistance.
Keeping the bushings and uniballs properly lubricated is key to a long-lasting kit. Most customers are happy to perform a tiny bit of extra maintenance for the major performance increase that a Long Travel System offers.
TOTAL CHAOS
WWW.CHAOSFAB.COM
Old 10-09-2018, 03:56 PM #14
Thanks in advance.
If there is anything you have questions on please let us know. We are happy to provide more clarification and details on any of our items.
In regards to sending you a kit, just need your CC info first and we'll get a kit shipped right out!
We can send you a kit, but it'll cost a little $$$
TOTAL CHAOS
WWW.CHAOSFAB.COM
Old 10-09-2018, 06:27 PM #15
cbielat's Avatar
cbielat cbielat is offline
Real Name: Chris
cbielat has a spectacular aura about cbielat has a spectacular aura about
cbielat's Avatar
Real Name: Chris
The OG of your +2 Race Version right here...
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Long Travel Front, Long Travel Rear and everything in between.
cbielat is offline   Reply With QuoteReply With Quote
long travel , suspension , total chaos
total chaos long travel 3rd gen SOCAL magikbean562 For Sale: Suspension/Wheels/Tires 6 12-27-2016 08:46 PM
Looking for Total Chaos Long Travel Kit for my 3rd Gen 4runner 964Runner3rdgen For Sale: Suspension/Wheels/Tires 2 12-12-2016 11:37 AM
WTB: Total Chaos Long Travel Kit 3rd Gen 4Runner 964Runner3rdgen Want to Buy/Trade 1 12-06-2016 01:41 PM
Total chaos long travel heim joint tyr0981 3rd gen T4Rs 5 04-24-2015 08:09 PM
5TH GEN Total Chaos Long travel project Dlak 5th gen T4Rs 11 09-03-2010 11:33 AM
