Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 05-02-2013, 11:38 AM #1
FatTiresRollin's Avatar
FatTiresRollin FatTiresRollin is offline
Real Name: Brian
FatTiresRollin is on a distinguished road
Real Name: Brian
Level 8 MK6
I know there are a few on here that have some experience with the level 8 wheels. They just introduced a new wheel that I am interested in http://www.discounttiredirect.com/di...=MK6&typ=Truck
Can someone weigh in on the quality of the product? Seems to be a discount tire exclusive brand. There are several widths, offsets and colors available. The center cap might have to grow on me, but the overall look reminds me of the Konig Six shooters (my first choice thanks to the enticing photo of audio3x's rig). They are a few pounds heavier per wheel, but also quite a bit cheaper. Less than $600 for 4 wheels is right in my budget wheelhouse.
My first thought is the matte black in 17x8, -10 offset. I would like to have the input of the peanut gallery...will be running the 285/70/17 Duratracs and stock UCAs with the 2.5" Bilstein budget lift. Already pulled the liners all the way forward, so body mount rub and UCA clearance are my main concerns.
2011 Blizzard Pearl SR5 4Runner, AMI 12" Big Stick Antenna, Rocker Panels Removed, Yakima Load Warrior w/ Extension, Plasti-Dip Black Out, Bilstein 5100s On All 4 Corners (Front @ 2.5" Setting) and Toytec Superflex rear coils, 285/70/17 Falken Wildpeak A/T3W, LR UCAs, Front Air Dam Removed, Level 8 MK6 17x8 with 0mm Offset, BudBuilt Bump-Out Sliders
FatTiresRollin is offline   Reply With QuoteReply With Quote
Old 05-02-2013, 12:13 PM #2
Stifler Stifler is offline
Banned
Stifler is on a distinguished road
Banned
I cant comment on quality etc but those center caps are doodoo! I would run the wheel without caps
Stifler is offline   Reply With QuoteReply With Quote
Old 05-02-2013, 12:30 PM #3
Davemon Davemon is offline
Davemon is on a distinguished road
Yep, that big ol' 8 on the cap has gotta go.
Davemon is offline   Reply With QuoteReply With Quote
Old 05-02-2013, 09:30 PM #4
JdMeF9SiR2 JdMeF9SiR2 is offline
Registered User
JdMeF9SiR2 is on a distinguished road
Registered User
As many of you may already know, I do sell FN Wheels and Konig Wheels light-weight and strong wheels.
I'm definitely not here to bash anyone else's product, but I would like to note the following regarding wheel weights:
-The 17x8" Konig Six Shooter weighs approximately 20.5lbs per wheel. The 17x8" Level 8 MK6 weighs approximately 27.5lbs - 28.5lbs per wheel (depending on the offset). Official weight chart from Level 8:
This is a 35% - 40% weight difference, and please remember that your wheels and tires are unsprung weight. This is a huge difference, and you will notice decreased acceleration, decreased fuel economy (worse gas mileage), bumpier suspension, and increased stopping distance (worse braking performance) with heavier wheels. A 10% - 15% difference in unsprung weight is usually noticeable, greater than 25% is significantly noticeable, and 35%+ difference is very, very noticeable.
I do realize that the Level 8 wheels are cheaper priced than the Konig wheels. I don't want to speculate about why they might be cheaper, but I will recommend that you consider the added costs of : more fuel (because of decreased fuel economy), more frequent brake pad and rotor service and replacement (because of the need to apply more pressure to stop in the same distance), more frequent need to service or replace your shocks and suspension bushings (even more frequent if you offroad), and a general all-around more sluggish and bumpy/bouncy feeling to your 4Runner from installing heavier wheels (hard to put a dollar figure on this, but in my opinion "fun factor" is most valuable).
References:
Unsprung mass - Wikipedia, the free encyclopedia
Market Trends in Tires and Wheels | Specialty Equipment Market Association
Wheel Tech, Part I: Wheel Weight Slows You Down | Tuner University
Wheel Tech - Road Wheel Weights Can Affect Your Vehicle's Show...and Go
JdMeF9SiR2 is offline   Reply With QuoteReply With Quote
Old 05-02-2013, 09:59 PM #5
Real Name: Brian
Real Name: Brian
Stock SR5 wheel is supposedly about 29.6 lbs....so even the heavier level 8 mk6 will be lighter. Trust me, if cost wasn't a factor, I would be all over the Konigs. My budget calls for a set of wheels that I can have installed for round $700-$800 out the door. Unfortunately, that won't even get the Konigs to my doorstep.
I never thought choosing wheels would be so difficultly! Not sure if I can live with the giant 8 in the center cap. Come to think of it, I like another set or 2 of level 8s, but hate the center caps!
Old 05-02-2013, 10:25 PM #6
Registered User
Registered User
No problem, I completely understand. If your current wheels are 29.5lbs then you definitely won't be degrading the performance of your vehicle with a set of 28lbs wheels.
However, I just wanted to point out that you would be significantly improving your performance with a set of wheels that are 35% - 40% lighter, and it would save you money in the short term (gas mileage) and long term (vehicle wear and tear), to the tune of a dollar figure that is probably more than the price difference of the wheels.
Aluminum is a pretty inexpensive material, so most of what we pay for in a wheel is manufacturing costs with respect to how much was invested in the engineering of the wheel and how up-to-date and technologically advanced of a manufacturing process was used to create the wheels. Higher technology and a more refined engineering process creates wheels that are stronger and lighter, but usually at a slightly higher cost.
I don't want to come off as trying to talk you into a set of our wheels, but I just want to point these details out for anyone who might be comparing the two wheels.
I'm very proud of the wheels we offer, and I enjoy opportunities to tell fellow enthusiasts about our wheels.
Last edited by JdMeF9SiR2; 05-10-2013 at 04:33 PM. Reason: Spelling error. Nothing else changed.
Old 05-10-2013, 10:52 AM #7
Real Name: Brian
Real Name: Brian
17x8...0mm or -10mm offset
One of the Tacoma World guys posted up a pic of his truck running these wheels without the center caps. I like what I see! And discounttiredirect is offering multiple prepaid VISA offers that could lower the cost of these wheels to $500! My next dilemma is a 0mm or -10mm offset. Based on a wheel fitment calculator I have been utilizing....we are only talking about an additional 0.4" difference in how far the -10mm offset will stick out. I know that could potentially cause significant rubbing vs the 0mm, just not sure how significant the visual difference will be. I have found quite a few pics of the -10mm stance this fitment gives via the ever popular Countersteer X. Whoever is out there running a 17x8 with 0mm offset, would you mind posting a pic in this thread of your stance? I know the 0mm offset should be a better fit to avoid any additional rubbing, just not sure if I will be happy with the stance in the long run.
Old 05-10-2013, 09:28 PM #8
eddie333's Avatar
eddie333 eddie333 is offline
eddie333 is on a distinguished road
eddie333's Avatar
I'm looking at this rim too and my understanding is the 17x8 -10 with 265/70/17 tire won't rub. That's based on fitment data from the -10 Konigs. If you go with a wider tire you'll likely rub.
eddie333 is offline   Reply With QuoteReply With Quote
Old 05-10-2013, 09:38 PM #9
Real Name: Brian
Real Name: Brian
285/70/17 will definitely be the tire size...1 month old Duratracs.
Old 05-14-2013, 10:13 PM #10
a47chuck's Avatar
a47chuck a47chuck is offline
a47chuck will become famous soon enough a47chuck will become famous soon enough
a47chuck's Avatar
I'm lookin' at these wheels also. Based on a 0 offset having 4.5" back spacing for an 8" rim and the stock 20's having about a 4.25 backspacing, I believe that 265/70's won't rub. Comments?
P.S. Spell check, KOOL
a47chuck is offline   Reply With QuoteReply With Quote
Old 05-15-2013, 08:41 AM #11
Real Name: Brian
Real Name: Brian
you shouldn't have any trouble with stock size tire....especially if you are staying away from the more aggressive tires such as Duratracs.
Old 05-15-2013, 03:51 PM #12
Real Name: Brian
Real Name: Brian
I will be the guinea pig....
Looks like I will be the guinea pig for these. Thanks to discount tire direct, the price couldn't be beat. As much as I really like some other MFGs wheels (especially Konig & Method), I simply decided to go the more economical route. Ordered 17x8, 0mm Offset in Matte Black this afternoon. Decided on the less aggressive offset for an easier fit. Certainly not as aggressive as the 17x9, -12 mm offset a lot of you guys are running, but should still be a nice stance with the 285 Duratracs. Worse case scenario, when I break down and buy UCAs, I can always throw some spidertrax on if I feel the need.
Already have the order confirmation and UPS tracking info. Could have them on as early as Friday...if not, I will have my truck at the shop the day of or day after these arrive. Pictures to follow shortly....
Old 05-15-2013, 05:04 PM #13
a47chuck's Avatar
a47chuck's Avatar
Thank you. I'll be checkin' your pic album. What are you doing for TPMS's?
Old 05-15-2013, 05:07 PM #14
Real Name: Brian
Real Name: Brian
All the other wheel/tire threads I read lead me to believe the sensors can just be transferred...that is what I am counting on.
Old 05-16-2013, 12:15 PM #15
eddie333's Avatar
eddie333's Avatar
I think I'm ready to go with this wheel too. 17x8 -10 with 265/70/17 duratracs. More aggressive offset, but my tire size is smaller than yours. Should help out the narrow stance I loathe on my limited.
2013 4Runner Limited - (17" Level-8 Bronze MK6, 265/70/17 Duratracs, ToyTec Ultimate 3/2 Suspension, Baja Long Rack, Shrockworks Front Bumper, Smittybuilt XRC Winch, Shrockworks Sliders/Trim Kit, Gobi ladder, LED Reverse and side lights, Cobra CB, Dual Isolated Odyssey Extreme Batteries, On-Board Air Compressor, ARB Awning & Room, Rooftop tent)
level drgwrr1988 5th gen T4Rs 6 04-01-2013 08:12 AM
Oil Level - whats the right level? buch75 Maintenance/Detailing 2 08-25-2011 11:45 PM
Is my t4r going to be level? SaltwatersouL Classic T4Rs 2 05-20-2011 10:43 PM
Oil Level cbn_78 Classic T4Rs 5 11-04-2007 02:06 PM
V-6 Oil Level <<<< Maintenance/Detailing 4 12-17-2004 09:59 PM
