TOTAL CHAOS Weld-On Rear Bump Stop Mount (KING)
PART# -
48624K
PRICE - $249.99
- Increase rear suspension dampening control and reduce harsh bottom outs with added weight packed in the rear of the SUV.
- CNC laser cut brackets weld to the outer frame rail and offer easy access to adjust the nitrogen pressure.
- Designed to work with KING 2.0" compact threaded adjustable bump stops and adjuster nuts.
- KING bump stops offer adjustable nitrogen pressure to custom tune your vehicle for your specific use and off-road application.
- Cutting, welding, and basic fabrication are required.
- Designed to reduce rear-end "bucking" sensation and the harsh bottom out with factory rubber bump stops.
- No need to remove the rear coil spring to adjust nitrogen settings like other brands.
- NOT INCLUDED in kit: QTY (2) KING PT#BS2120
Installation Instructions
Want to order a
Rear Bump Stop Kit?
Please email
[email protected], call 951-737-9682, or visit one of our
Authorized Dealers
TOTAL CHAOS
WWW.CHAOSFAB.COM
