Originally Posted by TeeDub21
You've got King suspension at 3.5" lift and stock UCA's? Do yourself a favor and buy UCA's before worrying about your tires. Truck will drive much better.
It actually drives no different than it did stock. Of course the springs are firmer, but there is no wandering, or anything odd. Alignement isn't far off either. I race cars as a hobby, so I have tools to check and adjust alignment to a point. I have adjusted what I can adjust to the following. Hell, It drives fantastic. That surprised me. I was expecting it to be a handful at highway speeds. I set the cruise to 75mph, and it is as smooth as before. No fibrations, shaking, etc.
Toe : .40 on both sides
Caster : 2.1 L - 2.2 R
Camber : -1.0 L - -1.1 R
The camber concerns me the most, as I can't fix that, but overall I am not as far out of spec as I would have thought.
FWIW, I won't be getting tires until around the time I get UCA's, which I stated in the OP that I was getting. I start shopping around early to get the best deal on tires. I'm two months out from buying and probably 3 months out from needing them..
