10-22-2018, 04:29 PM
Gobi Rack with Hard SHell Tent?
As the title states.... Anyone rocking a hard shell tent (Autohome, Roofnest, etc) on their Gobi rack? Pics would be great!! Thanks!!!
P.S. No Gobi haters please!!!
'17 T4R TRD OR Premium w/KDSS. Icon Stage 7,Nitro 4.88 Gears, Volk TE-37 XT-M SPec wheels, Toyo Open Country RT Trail 35/12.50/17 Tires, RCI Aluminum Skids, CBI Front/Rear Bumpers, Alu-Cab load bars, Alu-Cab 3.1 Roof Top Tent, OEM Audio Plus Reference 450Q, Baja designs S8 30", Baja Designs Squadron Pros, Baja Designs Squadron Sports (Rear bumper), Baja Designs LP6 (Roof)
IG: @Expo_T4R
10-23-2018, 09:00 AM
Anyone?
IG: @Expo_T4R
10-23-2018, 02:08 PM
Here go. Autohome Gobi and FrontRunner Slim Line II
Had the Autohome Columbus on Gobi stealth with two Yakima crossbars for about a month. Since thegobi crossbar do not level with the rack side rails, you can't really mount the RTT on the rails without modding and make the crossbar level with the rack side rails. I didn't do that.
I used the cross adapter and the yakima crossbars so the Autohome would sit on the yakima corssbars, but it still not quite ideal. Since Autohome shell constructed from fiberglass, it come with two mounting rail which is also acted as the load frame, the other part does flex when there is load on them. Ideal mounting would be to have the Autohome sit on a completely flat surface.
Since I want to be able to mount Rhinorack Batwing Awning and carry a table, I went with Frontrunner slimline II with extra wide platform and mounting accessories. To me this is ideal.
IG @ BAJA4RN 2015 4runner TPE, Grey, 285/70/17 BFG KM3, Method 105 17x9 3.50" BS 6x139.7, Magnuson SC, FrontRunner Slimline II, ARB Summit front bumper, Bruteforce Rear, Safari Snorkel, Autohome Columbus RTT, Alu Cab Shadow Awning,Quick Pitch Ensuite, King Shocks OME 2.5", Dometic CFX 65W, REDARC Multi-Stage charger, 100W solar panel, 80ah 2nd AGM battery, BAMF sliders
10-28-2018, 10:09 PM
Originally Posted by Brandon H
Anyone?
I am also looking to see who has run a hardshell on their Gobi, looking to get an Alucab or Roofnest on my Gobi. Looks like a Frontrunner is the way to go, but don't want to swap the rack if I can avoid it
2014 4runner Trail, KDSS, 6112's w/King 650# springs, 5100, 295/70/17 DuraTrac, 4.88 Nitro Gears, Harrop Front E-locker, ToyTec 2.0 rear springs, Metal Tech Sliders, Full RCI STEEL skids, Prinsu Rack, C4 Fab Fuel Tank Skid, C4 Lo Pro bumper with High clearance, X20 winch, ARB Twin Compressor, Northstar 27F, Precision LED conversion, NoCo onboard charger, Icon Delta Joint UCA's, Dobinson's Rear Drawers.
1989 4Runner: All Stock
10-31-2018, 04:58 PM
Your rig looks awesome!
'12 Trail
Icon Stage 4 Billet
Stealth 6 Wheels with KO2's
Sliders
01-07-2020, 06:57 PM
Has anyone mounted an Alu-cab or Bush Compay Alpha on thr Gobi Stealh No-Rise option, removable Gobi crossbars?
2019 TRD PRO
Gobi Stealth No-Rise / C4 Fab Sliders / Xenon Depot HID Low LED High / Goose Gear Drawer & Sleeping Platform / RAGO MSP / ARB Dual Compressor / Shrockworks Dual Battery / ARB Differential Breather /
01-07-2020, 07:08 PM
Real Name: Weston
Real Name: Weston
Autohome Columbus Variant Small with Gobi Stealth, rise, removable crossbars.
The tent is on the smaller side but fits perfectly on the rack, not much overhang on the sides and the tailgate is fully operable. The round crossbars don't provide the best mount but you can get aftermarket square tubing that would be a little bit better. All in all no complaints.
The New - 2019 TRD ORP, Supercharged, Lifted, 285s, armored,
https://www.toyota-4runner.org/5th-g...9-trd-orp.html
The Old - 2000 SR5, Supercharged, E-locker, 35s, 4.88
www.outworldhq.com/2000-toyota-4runner
01-09-2020, 12:41 PM
Thank you, your rig looks awesome. Was it just a case of lifting the tent up dropping it on then adding the bolts for the roof bars? I have never removed the bars. Any tips for mounting the bars with the tent on? I am guessing you take the bars off the rack mount them onto the tent without the bar bolts in then lift it up and add the lower bar brackets.
2019 TRD PRO
01-10-2020, 03:27 AM
Ikamper skycamp 2.0 fits on Gobi rack with rise. Those are 85.8 inches long. Leaves about an inch of clearance from the spoiler when the tailgate is up. So anything shorter should fit as well.
02-25-2021, 03:57 PM
Good to know. I'm looking at a CVT Mt. Hood which is 85" long and I have a Gobi with rise.
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
02-25-2021, 04:00 PM
This is 83" long. How much clearance between the tent and the hatch when open? Any more room to move it forward?
02-27-2021, 08:38 AM
Real Name: Nick
Real Name: Nick
Here is my Ikamper on my gobi stealth no rise
Real Name: Nick
Real Name: Nick
Rear view
02-27-2021, 11:04 AM
On gobi rack with rise and ladder
03-17-2021, 06:34 PM
Did you use the 2.0 factory fitting hardware and Gobi standard crossbars? Any alterations needed? The tent does look pretty awesome on the 4Runner.
2019 TRD PRO
