Old 10-23-2018, 08:23 PM #1
Zmartin19 Zmartin19 is offline
Zmartin19 is on a distinguished road
Accidentally tapped the wrong wires....
So I was wiring my AOB switch for my anytime backup camera and completely misunderstood which wires to tap. I tapped into the green and grey wires of the ACTUAL dimmer switch... like an idiot. Quickly realized those werenít correct after plugging in the switch and it did nothing. May have even tried the RED and GREEN wires for the switched source and pressed he switch, canít remember.
Anyway, nothing happened and all is well and with my APB switch. The dimmer switch works but I just noticed that if I dim the lights and then tap on the switch with my finger the lights will get brighter with each tap. Any wiring gurus wanna comment on if I may have ruined my dimmer switch or possibly hurt something else? Just concerned is all. Thanks.
Sig didnít post; I have a 2016 4Runner trail premium.
2016 White TEP w/o KDSS, 15% tint on front windows, 35% on all others including windshield (all ceramic), temporary Daystar lift, Gobi rack with 40" E series light bar and two 6"srq lights out back, RCI sliders without tread plate, and Bussmann aux fuseblock custom built to power all accessories
Zmartin19 is offline   Reply With QuoteReply With Quote
Old 10-24-2018, 01:41 AM #2
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep will become famous soon enough wcjeep will become famous soon enough
wcjeep's Avatar
Did you use the guillotine style splice connectors? Hopefully not.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 10-24-2018, 06:17 PM #3
gdvan01's Avatar
gdvan01 gdvan01 is offline
Real Name: George
gdvan01 will become famous soon enough
gdvan01's Avatar
Real Name: George
Which connectors/taps would be better to use?
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
gdvan01 is offline   Reply With QuoteReply With Quote
Old 10-24-2018, 10:26 PM #4
I used t taps.... left them on there for right now because I donít have any shrink tubing small enough to go on those tiny wires... probably 24-26 AWG. Also didnít have a tool small enough to depin the rheostat harness... should be fine for right now. (Didnít wanna use electrical tape because that stuff is garbage)
Old 10-24-2018, 10:28 PM #5
So does anyone know what all is on that rheostat circuit? And why would the switch still function for the most part but when itís dimmed and you tap the dash the lights flash...
Old 10-24-2018, 11:00 PM #6
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner will become famous soon enough 03_4x4Runner will become famous soon enough
Long shot here. Maybe you cut some of the strands of wire using the t taps and have to much resistance now. t taps are known for damaging wires.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 10-27-2018, 04:42 AM #7
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec has a spectacular aura about rigtec has a spectacular aura about
rigtec's Avatar
Real Name: Greg
Zmartin19 said: "...I tapped into the green and grey wires of the ACTUAL dimmer switch..."
Hi Zmartin19,
The Green (POS) and Gray (NEG) wires are only for the "Illumination circuit", e.g., instrument cluster, center console illumination, dash switches...etc. if you wired the AOB switch contacts across the green and grey wires (with the parking/headlights on), you may have burned the carbon pile or rheostat resistor.
This may have caused it's wiper contact (common) to fuse and break... can't be sure unless some tests are performed. The dimmer dial is wired Directly to the 'Main body ECU compu network' which is the main processor over ALL 26 or 27 ecu's in the vehicle's interior!
If it were up to me, I would run a few tests on the dimmer dial (using an ohm meter) to prove or dis-prove it's proper functionality. If it fails the analysis testing, I'd order a new one off ebay (they run from $10 to $30 bucks): https://www.ebay.com/itm/Toyota-4Run...1:pf:0&vxp=mtr
Just search for the one that fits your truck... this one was just an example for a GEN-4 4Runner; not sure if it'll fit GEN-5! 'Best to you',
rig
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
HELP - Accidentally added T-IV to Dexron III staghv1 3rd gen T4Rs 43 07-13-2018 03:08 AM
Previous owner tapped into spark plug wires - any ideas why? dkyleb 4th Gen T4Rs 12 03-10-2016 02:44 AM
accidentally wrong terminals. Supra725 General Discussions 6 04-04-2014 12:24 AM
VSS wire tapped. No cluster. Weirdness. CookieRoe 4th Gen T4Rs 7 08-02-2012 01:22 AM
errr... I tapped the wrong wire and bad stuff. Techenigma Problems & Warranty Issues 10 06-25-2006 11:53 PM
