07-21-2019, 05:38 PM
#76
I was leaning towards Aluminum skid plates previously but having done some harder tracks where I've dragged a few rocks underneath the OEM skid plate and taken some harder hits I'm doubting that.
If I go steel I'm assuming a powdercoat helps prevent rust? How many of you opt for a powdercoat versus bare metal? Also damn, $242 for shipping them from CBI.
07-21-2019, 05:43 PM
#77
I jusy rattlecaned my steel skids. Saved some money that way
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
07-21-2019, 06:22 PM
#78
Yeah I was thinking of doing that, I'm a bit scared of rust, but it's not like we have a ton of humidity here.
07-21-2019, 07:20 PM
#79
I had the same concern but after a few trails and scapes that powder coat will be off. Was cheaper to just spray paint it
07-25-2019, 12:25 AM
#80
Originally Posted by Charlievee
Being the ultimate skid plate thread, I will ask a question about threads.
What is the thread and pitch/ sizes of the hardware?
I just watched the Victory 4x4 skid plate install video and they have a mix of metric and inch system hardware
https://www.youtube.com/watch?v=MUCbvfgwDE0&feature=youtu.be
Jim _ My Adventure Blog: http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
07-25-2019, 07:46 AM
#81
Any word on ARB Skid plates?
Even though I already bought and installed a TRD front skid plate, a full set of skids for $418.95 + $70 shipping is kind of tempting to me.
ARB Skid Plates for Toyota 4Runner, FJ Cruiser, & Prado
I note they are 3mm thick vs. everyone else's 3/16 or 4.76mm thickness. Will they hold up?
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
07-25-2019, 10:14 AM
#82
They seem to be for light duty use. A local ad in Craigslist shows a used set with a big dent in the front.
4Runner ARB Skid Plates 5th Gen KDSS - auto parts - by owner - vehicle automotive sale
3/16" thick steel will take more hits so your offroading style will be a factor in the decision.
There are a few interesting ARB skid threads on the forum such as this one: ARB vs Factory skids One of the complaints was about how easy it was to bash in the crossmember that mounts towards the back.
07-25-2019, 03:49 PM
#83
If you are interested in Shrockworks skids don't bother to send emails to their tech info@shrockworks address.
I sent an email on July 11th with 3 questions and 12 days later I received a definite answer to one question about fitment, no answer to the weight of the skids and a request for photos on my third question. I think I will call them rather than wait another 12 days
07-28-2019, 09:56 AM
#84
LFD Steel Skid
I ordered and received the LFD steel skid plate. My initial reaction is this thing is much heavier than I expected. Laid it on the scale and it is 45.2 lbs. I think I was looking in the 30 pound area, but I really didn't know. What I do know is I will not be wanting to drop this skid for each oil change and whatever other work I want to do. I will not be doing heavy crawling in this 4Runner. I just want protection from potentially rough mountain roads I will be experiencing. And for easier maintenance.
Given all this I will prefer an aluminum skid I think. LFD does not appear to make them, and not sure how easy it is going to sell the LFD skid. Should have researched more. LFD customer service has been awesome by the way.
07-28-2019, 10:15 AM
#85
Correct me if I'm wrong but i believe the skid has an opening/door allowing you to access the oil filter. Allows you to change the oil without taking the skid off like the factory one.
07-28-2019, 02:37 PM
#86
You are absolutely correct
07-28-2019, 05:54 PM
#87
Indeed. But someone mentioned you really need to remove the skid since it is pretty tight to work with. If the door works that may alleviate some of my concern. The thing is still pretty friggin heavy though. In some parallel universe I am probably praising it!
If you all are using the "trap doors" though I think I'm good with that.
Happy to support a local company, and the service has been great, as some have mentioned here.
07-28-2019, 09:49 PM
#88
Hope the trap door is sufficient for oil service, that's one of the reasons for the swap. I was about to order the LFD for my daughter's KDSS and realized they only made it in steel. Decided against it due to weight and she only would need an aluminum one for light duty. Ordered the RCI over the 4th, received last weekend and installed it few days ago. I believe it weighs in @ ~24#. All the hardware were M8x1.25.
Good luck with the install. I actually prefer how the LFD looks since the front skid is easily seen.
07-28-2019, 11:03 PM
#89
I have a front skid plate that has the opening, but honestly, just remove it when changing the oil. My first oil change after installing the new skid plate took longer because oil from the filter housing spilled into the skid plate. It was enough oil to warrant removal of skid plate to clean up the oil, which added more time than if I had originally just undid the few bolts holding it in place.
07-29-2019, 11:19 AM
#90
sclui56
you can still spill oil out of the cartridge cover if you don't drain it first. If you drain it with the Toyota supplied nipple it is still possible to get oil on the skid plate.
Use one of these nifty drain valves with a hose to cleanly empty the oil before unscrewing the cover. Far easier than wasting your time dropping the skid plate over and over when it has a nice access cover engineered into it. Simply screw this drain hose to the filter cover end fitting, open the valve and the oil drains right into your used oil container through the tube.
With the cartridge housing empty of used oil you can unscrew it and replace the filter element.
https://www.amazon.com/JDT-TOYOTA-Re...ustomerReviews
https://www.amazon.com/Motivx-Tools-...gateway&sr=8-3
