So in planning to move up to 285's, I noticed recently during my online shopping voyage that the prefab kits available for the 5th Gen aren't very similar at all?
Sure some shops like to water jet their logo or name into them, which seems like a great way to create a mud and moisture trap that rots them right back out if you ask me. But even the modification itself and the "area to be removed" seems to vary a lot depending on how each shop makes their plates to fit.
RSG- offers the nicely rounded (logo only) option for $39.99, which is about twice as much as most others, but has a nice curvature that seems to be the best option to get a close, rounded fit and max clearance.
Metaltech- offers the side-specific rounded and creased version for $24.95, which seems like a bit of a short-cut to actually rounding the piece like the RSG, but seems to accomplish the same end result in trimming the end-length off. The only issue is that they include a bunch of "installed" pics, but if you look closely at the finished piece, they all seem to have an extra tab piece welded in to the end to complete the bridge and it ends up looking a bit hacked together (although could also just be the result of a bad trim/weld).
Then there's the
ORW (Off Road Warehouse) kit for $30 that uses a different longer pattern and cut on the frame than the others, which seems to leave a lot more of the original length extending passed the body mount point, and instead opts to trim a length-wise slice off the inner tire-facing face. Which seems to retain a stock look while making for a much cleaner trim and weld job, but still leaves a large section sitting in front of the tire as compared to the RSG and Metaltech.
There are others, but these three seem to be at the opposite ends of the spectrum.
Naturally when making a permanent change/removal to your truck like this we only get one shot, so I was wondering if anyone has had any good/bad experiences with any of these plates and their different fitments?
Thanks!
