02-13-2019, 03:54 PM
#16
Real Name: Tom
Real Name: Tom
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
#17
Real Name: Tom
Real Name: Tom
IG: dot_tom
06-24-2019, 09:56 PM
#18
Question
For the spare tire carrier, did you weld bolts to the circular plate that holes the spare tire? I got my kit and I’m working on it slowly.
2016 T4R TE w/ KDSS, OME 3" Lift w/ 884 light front coil, SuperFlex rear coil w/ 60020 shocks, Method NV 17x8.5 w/ 0 offset wrapped with 295/70/17 BFG KM3 BMC Mod.
Instagram: dang_t4r
08-07-2019, 12:13 AM
#19
hey there thanks for the play-by-play pics! do you think there's a way to cut a pair of holes to mount a pair of LED Pods down on the lower portion of the bumper. i am a non-welder w/ no experience but I have a couple local guys that can weld. do you think there is space between the crash bar and the bumper for a pair of pods flush mounted? and would a solid welder be able to cut the right holes for something like that? Tks in advance!
Kansas City!!! ...2016 Trail Ed Premium w/ KDSS, Toytec Boss Performance suspension, 285 Nitto Ridge Grapplers, C4 Armor, RCI skids, ExtremeLED bars, Baja Squadrons, Frontrunner Rack, Dobinsons Snorkle and Springs, Magnuson Supercharger. Build out by @AdventureMotorsKC
Instagram: @kcSNOWrunner
08-07-2019, 11:22 AM
#20
Real Name: Tom
Real Name: Tom
I have built a few of these for customers and one of them took it upon himself to have someone cut 2 holes like you are requesting. The holes were not measured right and now you can see the frame. There is not enough room to mount the pods he has. It looks like you could cut the holes but they would need to be further out. Do a lot of measuring so you only cut once. Worse case, weld metal back in and grind down then cut again.
IG: dot_tom
08-07-2019, 11:23 AM
#21
Real Name: Tom
Real Name: Tom
Yes, I welded the bolts directly to the plate for the spare tire.
IG: dot_tom
08-07-2019, 08:30 PM
#22
If I get to keep the 4Runner I am going the dot_Tom route. I really like the look of the coastal offroad bumpers. I wish I knew someone who could weld and lived in my area.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
08-16-2019, 08:09 PM
#23
With this kit, do you also have to weld to the body or you weld the bracket that bolts to the body?
10-22-2019, 09:40 AM
#24
You weld the bracket that bolts to the frame. No frame welding necessary.
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
11-09-2019, 03:55 AM
#25
Looks like you had to remove your factory hitch. Did you ever consider mods to the CO bumper so that you could leave the factory hitch attached?
Sent from my Pixel 3 using Tapatalk
**2011 Limited_Loaded - Black**Rims, ski rack, hooped nerf bars, blackout chrome, red emblems, bug guard
I'm too big of a sissy to bake my head and tail lights to black them out
01-08-2020, 12:45 PM
#26
Great build man!
I just finished mine and have it on my 3rd gen.
A quick question for you, are you experiencing more road noise? I feel like I hear the rear bumper when I make turns or hit bumps. I've check all the bolts and its on there tight.
03-01-2020, 04:00 PM
#27
Hey guys, in working on my 2011 rear Coastal full height bumper and running into a number of challenges. The instructions I received didn't tell me to cut off the tips of the body mounts, so I got things tacked together and started the welding before they got back to me to update as I just couldn't get things to line up right.
Is the horizontal top piece actually close to level with the vehicle for you guys? I can not see any way that would possibly work without large gaps to weld as it sits on the spare tire hoops.
Also, did you do anything to cover the gap between the bumper and the vehicle under the tailgate?
Sent from my SM-N975U using Tapatalk
I drive a TruckUV
'11 T.E. KDSS SS 3/2" lift, cooper at/3s, sleekster sliders, baja racks utility rack & ladder, new piece of bumper plastic
03-07-2020, 11:09 AM
#28
Rear Coastal Offroad bumper - hitch mod
Hi
My 2005 GX470 is almost identical to the 4Runner, but the rear crossmember is really in the way - I took the unusual step of cutting off the top of the crossmember and welding in the factory hitch, so that it wouldn't hang down below the bumper. Ugly welding (my first project) but it works.
04-17-2020, 11:56 AM
#29
Real Name: Jake
Real Name: Jake
Looks great! By far one of my favorite looking rear bumpers.
I am also curious about the hitch, I have a Mission Overland trailer being built (approx 2400#). Definitely need to be able to keep the factory tow capacity. Anyone else play with that?
Hows the weight? I have talked to a few people that put on steel rears and it gave them the death wobble at 70mph. This is still my daily.
04-17-2020, 08:07 PM
#30
