Old 05-05-2021, 03:31 PM #151
Flix's Avatar
Flix Flix is offline
Flix is on a distinguished road
Flix's Avatar
Originally Posted by Signal View Post
How long has it been installed?
I installed it Dec 2019. So almost 1.5 years..
I used this type of tape:
Amazon.com: 3M Super Strength Molding Tape, 03609, 1/2 in x 5 ft: Garden & Outdoor
2010 Metallic Grey SR5 w/Premium Package. Shrockworks bumper, P285/70/17 Mickey Thompson Baja Boss A/T, FN 5-Star, Bilstein 6112s w/King 700lb coils, Dobinson GS59-701 w/Toytec 2" Superflex on rear, Custom Full Length Roof Basket.
Accessories: Various lights and other cosmetic touches with bonus authentic BC pinstripes
Flix is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 04:06 PM #152
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Thanks, And that tape lasted almost 2 years. I think one good thing about where I live is there is no real winter so the cold isn't that bad.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 04:27 PM #153
Flix's Avatar
Flix's Avatar
I hope the humidity and heat where you live doesn't affect it long-term. :op
Old 05-17-2021, 08:37 PM #154
Well I attempted to put the snorkel on today I started at 2pm and stopped at 7pm. The template lined up with everything and after I drilled all the holes nothing lined up just the main big hole. I reamed some of the holes out and got the front 3 to sort of fit the threads dont really go past the fender. the back 3 that are near the A arm are no where close to the the holes. I checked 3 times before actually drilling and now I feel like crap knowing I have ruined my fender. I am going to try tomorrow to see how bad they are off and I might try to drill by eye. that is what makes me nervous, once I get it lined up i will hit up the parts store anf buy some fiberglass or bidy filler and try to salvage and patch the holes I don't need. I will say I will not be drilling into the A arm for sure. I had a bad feeling when I started but felt good after the 3rd time making sire everything lined up. I will say this after the roof rack, front bumper and winch show up I am not doing anything else to it. I give up. I This thing has been nothing but problems since we got it and everytime I did domething to it it felt good to know I was doing the work but now I have a 4runer with 6 holes and only 3 line up and it will turn into 9 holes because the template and snorkel body don't match when on the 4Runner.
The Build
Old 05-18-2021, 11:50 AM #155
Flix's Avatar
Flix's Avatar
@Signal I'm sorry to hear of your frustration of installing the snorkel on your truck. Hopefully you get it fitted properly after drilling out the additional 3 holes to make everything line up. Best of luck!
Old 05-18-2021, 12:27 PM #156
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
There's one step in the instructions to verify the template against the snorkel. To do that, you would cut out the large hole in the template, install the studs loosely into the snorkel body, then put the template against the snorkel and see where the studs are in relation to the template, then you'll see if any of them are off.
Not to sound like a jerk, but your fender will have a lot of holes in it with a snorkel on it no matter if the holes were drilled right or not, and the 3 in the rear will most likely still be covered up by the snorkel body. Just be sure to use some paint to protect the holes that you cut to stop rust from forming.
The small holes are all to be drilled out to 16mm (5/8") too, which is a common step that people seem to miss.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 04:05 PM #157
Update, It's on and it's not going anywhere. I need to do the 3M tape for the A Arm bracket ,and I'll be done. But for today it's on and everything is good to go. I will try to do the VHB tape tomorrow. I am waiting on surgery on my shoulder so I am usually good for a few hours. One thing I didn't understand is why plug the drain hole. I bet water gets in there from driving in the rain. I am trying to find a screen that will not let water in there but the air pass through.
Fitment is great, the one stud was a killer, it was really windy yesterday so something was whistling but I am unsure if it was the snorkel or the mirrors.
Dobinsons 5th Gen 4Runner Snorkel-rsz_20210518_141918-jpg
The Build
Old 07-05-2021, 03:25 PM #158
Has anyone changed the snorkel head, I am worried about water with the rain and since I sealed the air box off I don't need water in my engine.
The Build
Old 07-06-2021, 05:01 PM #159
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
Just turn your head around so it is facing rear ward. Even with it facing forward, I would doubt any rain would make it down all the pipping to the air box.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 05:27 PM #160
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I also wonder why it is recommended to plug the drain hole. I didn’t plug mine.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 08:12 PM #161
No issues with it not plugged? Maybe I will undo it when I have both arms back.
The Build
Old 07-06-2021, 09:23 PM #162
ads2539's Avatar
ads2539's Avatar
My snorkel is a recent addition (2 weeks today!), so I don’t have anything to report yet.
Old 07-06-2021, 09:50 PM #163
I might un plug it then, we get a ton of rain here, and I plugged it, unless I can find a different head.
The Build
Old 08-13-2021, 11:36 AM #164
alxdo2 alxdo2 is offline
alxdo2 is on a distinguished road
Is this snorkel in stock anywhere?
alxdo2 is offline   Reply With QuoteReply With Quote
Old 08-13-2021, 11:45 AM #165
Crikeymike's Avatar
Crikeymike's Avatar
No, but they are due back in stock in the next week or 2. You can place a backorder on my website for it to ship as soon as they arrive.
Safari Snorkel confirms snorkel for 4th-gen coming 4WDToyotaOwnerMag 4th Gen T4Rs 488 11-01-2020 10:46 PM
Safari Snorkel releasing snorkel for 3rd-gen 4Runners 4WDToyotaOwnerMag 3rd gen T4Rs 127 03-28-2020 07:56 PM
Dobinsons 2016 4Runner Trail Build Crikeymike 5th gen T4Rs 43 10-04-2018 12:43 AM
Dobinsons vs Bilstein 6112/5160 (+ Dobinsons ?s) MossJenks 5th gen T4Rs 14 09-19-2017 10:58 PM
