11-14-2018, 02:36 PM
Limited Aftermarket Tire Sizing
Hello! I am pulling out XREAS, ditching the stock wheels and putting in a Toytec Boss lift with 17" tires (Rims chosen are 17"x9"). The installer recommended 285's but I am worried about the mpg hit I will take. I have seen some others put 265's with Spidertrax spacers but a little weary of the additional maintenance that goes along with those. I also thought about 275's but the Falken Wildpeaks in the load range I want don't come in that size.
I calculated a 2 mpg hit on fuel economy, based on size difference between the 265 vs 285...is this reasonable? With my current driving and current fuel prices, that's almost ~$240 per year.
This will likely be a pavement queen, I hardly ever go off road.
Thoughts?
2015 Limited
11-14-2018, 02:42 PM
11-14-2018, 03:03 PM
Thoughts?
Curious how you calculated a MPG change on paper, what is this based on?
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
11-14-2018, 03:11 PM
I remember seeing some posts about Limited trim only getting 15-16mpg with 285's. I only get 19 now with 245, so I just implied I'd take a 2mpg hit with 265's and 4 with 285's.
This is why I asked the question if it was unrealistic. Thanks!
2015 Limited
11-14-2018, 03:17 PM
my average only dropped .5-1mpg when switch from 20s to 17s w/ 265s then 285s. havent seen a hit when switching from 265 to 285. 16.5 mpg avg, mostly traffic. occasional highway.
11-14-2018, 03:29 PM
Don’t do 285 if your truck is a pavement queen. The mpg drop is real and the truck will become significantly more sluggish especially on a Ltd that’s equipped with full time 4wd.
Do 255/75/17 instead,it performs better on roads.
11-14-2018, 05:22 PM
I'm getting an average of about 14 mpg with 285's. 95% city driving, but also have other mods with additional weight. See my sig. Also note your truck will kick out of overdrive a lot more on the highway on shorter/smaller inclines at 70+mph than with OEM tire size.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
11-14-2018, 10:14 PM
I've got 265/70R18 on Falken Wildpeak AT/3 (E load rating). I'm getting just shy of 17 mpg, and most of my driving is county roads and freeway driving.
||2018 Limited Magnetic Gray Metallic||MetalTech Sliders (stock rocker delete)||Icon Stage 5 Suspension (Stage 7 reservoirs)||Falken Wildpeak A/T3W (265/70/R18) on FN BFD Matte Black wheels||Diode Dynamics LED low beams, fogs, and all interiors||TRD CAI and Borla Catback Exhaust||
11-15-2018, 02:18 AM
2nd this ^^
11-15-2018, 11:40 AM
Do you have a pic of your setup? What type of rims do you have?
This guy's setup really intrigued me, but haven't seen it on a Limited. He put spacers on his 265's to push the wheels out. Not sure if that will be needed but I really like the look of the wheels flush. From what I have read, the offset affects how far the rim gets pushed out.
Lifts with 265/70/17, issues?
2015 Limited
11-15-2018, 04:36 PM
I have a similar story: 2013 Limited, removed XREAS, added 3 inch Toytec lift, switched to 265/70/17 Cooper AT3's on OEM trail rims.
As with the poster above, I would estimate 0.5 to 1 mpg decrease. Current avg mpg is 18.1 mpg.
I second some of the others - I would not install the 285's on a pavement queen if you are the least bit concerned about mpg.
2013 Limited Shoreline Blue Pearl, Ham Radio installed (Kenwood D710A and V71A with APRS), Trail Wheels with Michelin X-ice 265/70R17 tires
FS: Full set of 20" Limited OEM wheels + spare, see classifieds for pictures
11-17-2018, 04:34 AM
11-17-2018, 07:07 AM
Real Name: BLACK TRD PRO
OP, Snoranger’s limited 4Runner tire size works out to be 32.61” tall with a 265(10.43”) width. This narrow, tall tire provides better rolling resistance, but, due to the height reduces torque and will feel more sluggish and reduce mpg. A 285-70-17 looks great and works out to be a 32.71” tall tire with an 11.22” width, but, will be worse on mileage and power by about 1.5-2mpg over a 265-70-17. I run a 275-70-17, (32.16” x 10.83” width), and IMO, think it is a perfect overall size for looks, mpg, power, etc. Speedometer/odometer is only off 1.8% over my factory equipped 265-70-17 (31.61” tall x 10.43” width). Not worth recalibration in my case. You can also still fit a 275-70-17 under the truck in the spare tire location as opposed to a 285-70-17. Pic of my 4Runner with 275-70-17. Stock TRD Pro height, which, is 1” taller than other factory 4Runner suspensions. Tire sizes will vary slightly from different manufacturers. Good luck with your decision.
11-17-2018, 10:16 AM
Real Name: Halko
Real Name: Halko
Choose your priority, the look of larger tires or slightly better MPG. Oh and with a 17x9 rim and 285’s be prepared for rubbing, and if you put wheel spacers on it’s almost guaranteed.
I was fine with 265’s with my setup, going to 285’s hasn’t made much difference in mileage or drive ability into the mtns.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
