11-19-2018, 02:54 PM
#16
Good info and pics - thanks.
11-19-2018, 03:49 PM
#17
Originally Posted by 03_4x4Runner
This has been discussed here many times. This one started in 2012 and is still going. Prop shaft greasing
I am newbie here and appreciate the information and pictures.
Thank you for posting; I am loving this forum and community
11-19-2018, 04:56 PM
#18
Real Name: John
Real Name: John
I had this service done a while back, cured my 'clunk'.
The mechanic said they were all but dry. Ouch!
11-19-2018, 06:59 PM
#19
Originally Posted by Khjphoto
Very good information. Still wondering as to brakes, is it better to grease the rotor or the caliber? Thanks.
Neither. the backs of the pads and the pistons.
OP - Thanks! great write up. I plan to do this at the next oil change.
11-19-2018, 11:06 PM
#20
Thanks TRDpro4R for your straight forward explanation and photos. As mentioned, some have been going on for years about this same topic: what is the "best" grease, use only this grease, how much, how often, ect., ect. and still can't agree.
Your practical advise on grease is the way I have done it for decades--pick one and use.
Good job!
12-02-2019, 05:57 PM
#21
Originally Posted by TRDpro4R
That is it. Now your drive shaft is properly lubricated and good to go for the next 15,000 miles.
Hope this helps.
thanks - clearest explanation/HOW-TO I've seen so far, IMO.... Doing this on my 14 LE, it has never been done even @ dealer when they did oil changes and included interval services.
12-03-2019, 03:12 AM
#22
Is the xl lock n lube fitting worth the extra cost over the regular for this application?
04-14-2020, 07:00 PM
#23
With old oil (motor, diff, TC) it's always "out with the old, in with the new". However, with drive shaft grease, does the age and wear of the grease not matter? Is the only important factor whether or not there's simply enough grease?
04-14-2020, 07:39 PM
#24
Spicer, as well as most ujoint manufacturers, recommend greasing the ujoint until NEW grease starts to purge out of all 4 caps. While this creates alot of cleanup, having to wipe all the old grease off, it guarantees the ujoint is filled with new grease.
Sent from my SM-T813 using Tapatalk
04-14-2020, 09:41 PM
#25
On the u-joints I always go to where there is fresh grease coming out at all 4 seals, then clean up the excess. On the u-joint spider bearing essentially all the grease in the bearing is being "used" (heated up and degrading over time) so I think it all needs to come out, and it's what the bearing manufactures recommend.
The slip yokes to me are a bit different there as there is "reserve grease" that is really not all being "used" when the prop shaft spins, only the grease where there is movement at the splines is being heated up and degraded significantly, and as grease slings out the seal new grease is pushed into the area to replace it. Of course if you never grease then there won't be enough grease to move into the spline area and provide lubrication. But I don't see a need to purge all the grease out of the slip yoke ever. I sent you a PM.
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
04-14-2020, 10:08 PM
#26
Real Name: MURDERED TRD
04-28-2020, 05:31 PM
#27
I just purchased a CPO '16 Trail w/ 30k. I plan on doing this for piece of mind
04-28-2020, 07:07 PM
#28
old grease will have fine metallic material which could act like a sanding/filing agent which accelerates metal wear. However with the yokes its fairly sealed and grease is only exposed as it oozes out little by little
05-10-2020, 04:27 AM
#29
Great info. thanks.
Just what I needed.
2018 TRDOR W/KDSS
05-13-2020, 05:24 PM
#30
Real Name: Kirk
Real Name: Kirk
Motion Seconded!
Originally Posted by mcat707
Great tool! Just finished mine this afternoon using the LockNLube. It CAN be a little fiddly to get on to the zerk at certain angles, but once it's on, no issues at all.
FWIW - I am using Valvoline NGLI 2 rated, fully synthetic MOLY lube. Mine is 16350 miles old, and all 6 zerk points were essentially dry, what little bit that did push out of the spiders looked like dirty petroleum jelly...?
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
Reason: punctuation
