11-22-2021, 09:18 AM
#166
Appreciate the response, Greydog.
So did you just decide to do the ECGS solution yourself, or did you get Toyota to install it under warranty?
I guess I am just surprised that Toyota has known that this needle bearing is suspect and have even issued a TSB for it, but they continue to manufacture the diffs the same way.
That said, I have another 5th Gen 4Runner (2011) with 130K miles on it, and it has NEVER exhibited the issue. Just curious why some 4Runners make it to 130K miles with no issues, and then my new one started it at less than 3K miles from new!!
JA
11-22-2021, 08:46 PM
#167
Real Name: Ted A Hamilton
Originally Posted by Redsoxx1918
So far I've had both front shocks replaced under the TSB,
Can you provide TSB number. Came up dry on several searches
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
11-22-2021, 09:14 PM
#168
They replaced the shocks under the diff TSB? or a different TSB?
11-23-2021, 11:42 AM
#169
TSB-0094-20.
11-23-2021, 03:44 PM
#170
TSB-0094-20.
Thanks, N/A to my SR5
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
No Mods, Yet😇
11-26-2021, 06:08 PM
#171
JA
Were either of yours lifted? I believe it's been mostly a problem on lifted trucks. I have installed 3" Rough and Readylift lifts on about 10 of these and have had 3 of them started the groaning within a week or 3 of installing the lift. 2 of them started the day the lift was installed. One of them (2019 model with 30K miles) had the dealer replace the needle bearing and that fixed it for a month then it started again. The dealer recommended the ECGS bearing but said they couldn't install it under warranty since it's an aftermarket part, and were hesitant to even do the needle bearing because of the lift (said they'd have to leave that info out of their documentation).
I have a 2021 that I put a 3" Readylift on in March at 1200 miles and it now has 6,200 miles on it and no noise so far.
11-27-2021, 08:55 AM
#172
Hi JA, I diagnosed the issue myself and had a local shop install the ECGS bushing.
Long story short, the local dealer can’t get much warranty work done on my truck due to mods I have in it vs the regional reps opinions/BS.
As others noted, adding a lift seems to make the problem worse, less common on stock vehicles at sub-warranty expiration mileage.
Perhaps buy the bearing and seals now, live with it as long as you can, save for the labor costs, and get it done when comvienent?
Good luck, and enjoy the Runner!
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
01-29-2022, 03:18 PM
#173
2021 Front diff replacement - whining
Originally Posted by MikeYQM
Since mid summer I have had the Front Diff Grinding/Groaning Cyclical noise. Sounds like a wheel bearing starting to go. It’s most noticeable in the 80-100km/hr range and goes away completely of 4wd is engaged.
It’s identical to the TSB T-SB-0026-15.
I took it to the dealer last week, however the tech “could not hear the noise”. I even took the tech out for a drive to show him and didn’t showed it to him. However the tech response didn’t change.
I can clearly hear the noise and feel the vibration even when music or road noise drown it out. When he checked the side bearing, he noted “some play” but the only diagnostic is purely subjective on this issue. The dealership service manager refused to do anything since the tech claimed he couldn’t hear the noise.
What should my next step be? I have Toyota ECP until 100000km, but I’m at about 93000 km now.
Thanks,
Purchased our 2021 Premium in March of 2021. I thought I heard it after about 6,000 miles and at 7,500 it became noticeable, the cyclical whining sound when decelerating especially on a corner and especially when turning right. The service manager took it for a test drive and confirmed. Toyota replaced the whole front diff (it's now January 2022)- said there was an active service bulletin. Seems great now!
01-30-2022, 08:51 AM
#174
In the process of replacing the needle bearing on my wifes 5th Gen. Hopefully the process goes smoothly and rectifies the annoying drone.
02-04-2022, 06:38 PM
#175
Real Name: Kirk
Real Name: Kirk
Just ordered the bushing for my 2019 Pro with 51000 miles. Noticed this droning last month...not bad but clearly not "right."
Going to have to do this one myself as the factory diffs now contain 4.88 aftermarket gears. A straight up diff swap is not an option.
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
02-05-2022, 09:13 PM
#176
Mine is completely stock with only 1300 miles on it (2022). The dealer is going to replace the whole front differential as well in the next couple weeks. They are waiting for the parts to come in. They did not mention an active service bulletin. In fact, the one that I showed them was old, so they called the Toyota engineers and they said to go ahead and follow it anyway
02-06-2023, 01:54 PM
#177
Originally Posted by renau001
I did the ECGS bushing. Worked out great. Perfect since.
Hi
2017 4runner same issue and I am out of the warranty I am at 83k. Does the updated TSB extend the warranty?
I'm at the point where I am willing to pay to fix it, what should I expect to pay for this kind of repair?
Thx
02-07-2023, 11:23 PM
#178
Front Diff Grinding/Groaning Cyclical Noise
Presumably the replacement diffs Toyota has been doing just carry replacement warranty like any other part. One year I’d venture to guess. But I don’t think it can be verified whether or not these new components carry an updated needle bearing. Most have said, unlikely. You’d have to be within the OEM warranty to request that repair likely.
My mechanic put the bushing into mine and charged two hours labour. I watched the process. He’s been doing them for years now albeit typically on lifted trucks.
Anyway, he uses the bushing from Nitro Gear. Same thing. The seal was perfect, didn’t put in a new one, re-used it. Needle bearing looked perfect too LoL. Solved that issue immediately.
2017 TRD OR / KDSS / Canuckistan Edition
02-26-2023, 12:45 PM
#179
Same issue, no lift, brand new
Thanks to this thread I have successfully diagnosed that my truck has a needle bearing issue. 450km in, started on a very cold day. Not as noticeable now that temps are higher...debating whether I should just replace it at a shop with ECGS, or deal with a dealer telling me they can't replicate the issue.
'23 40th Anniversary Edition...I don't care if people hate my stripes. Elka 2.0's up front set at 1.75", Nokian Outpost AT's, Sherpa Crestone, other bits and pieces
02-26-2023, 02:32 PM
#180
I had the same issue on my SR5P, dealer wanted to fix it by replacing the diff and i was out of warranty by 3000 miles so i owuld have had to pay $3700 to repair. Not happening, so i bouight the ecgs bushing and seal, at the same time got all the stuff to do the job too. $192 and a few hours of work and the job is complete and fixed. Nice kit and east install, i do have the means to do the job though, lift and all the tools. A lot of videos on how to do it online.
2018 SR5 Premium, blacked out emblems, cornfed 2.5/1.5, AR933 wheels, 285/70/17 firestone destination ATII, 1.25" wheel spacers, its my wifes.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
