11-30-2018, 12:24 PM
#16
I had the same dilemma and went with the 40" light bar vs multi light setup. Something worth considering, the top tube bar will make a whistle noise at high speeds, getting a light bar will reduce/eliminate that noise. Also, maybe I'm just simple minded but when would you use just 1 light source when you have multi setup? I went with the full 40" light bar simple bc of that and also I didnt want to run more wires, more harnesses, more switches.
2015 Super White TRDP - Shrockworks, Gobi, ICON, SPC, Auroa LED, Dobinson
11-30-2018, 01:48 PM
#17
You have less wind noise with a light bar than without?
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
11-30-2018, 02:22 PM
#18
Here's a picture of my no-rise Gobi rack with a single 40" row LED light bar in the front a 6" LED in the rear, in case you want to compare.
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
11-30-2018, 04:31 PM
#19
Real Name: Tom
Real Name: Tom
Originally Posted by Texas_Ranger
Love that color man, very liquid looking, nice wax job.
Thanks! It's actually a ceramic coating. No wax in my garage.
I 100% believe that. The flat round bar up top has nothing to disrupt turbulence. So it makes more noise and likely to whistle. The light bar makes the air flow differently which equals less noise.
If you look back at round bar Yakima setups they made a little fin that would clip onto the bar to clean up the air and make it quieter.
here I found a photo of this. I am sure it would work on the Gobi rack also to cut down on some noise.
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
11-30-2018, 08:01 PM
#20
You mind telling me what your using?
11-30-2018, 10:22 PM
#21
Nice! Thanks, I may check that out.
12-02-2018, 01:01 PM
#22
Real Name: Tom
Real Name: Tom
You mind telling me what you're using?
I used CarPro CQuartz Ceramic. I recently used Cquarts EXO V4 on my wife's new Accord and am very happy with it. Much easier application and more gloss IMO. I use CarPro reload to keep the coating looking its best.
Not to go in huge detail but the prep work is the most important. Properly correcting the imperfections in the paint prior to coating the vehicle gets the best results.
IG: dot_tom
12-02-2018, 01:21 PM
#23
Real Name: Sandman
Real Name: Sandman
Im going with the multi light setup next time, I have the single row light bar mounted on the Gobi rack now and hate the way the light reflects off the hood. Way too bright at night.
2015 4runner TRD Pro, 2017 Tacoma 4WD,
1983 HiLux 4WD
02-22-2019, 05:41 PM
#24
Hi,
Is that the no-rise Gobi option? Im in the process of ordering now. Also, how did you attach the maxtrax and tent?
2019 4runner TRD PRO Midnight Black Metallic
02-23-2019, 12:02 PM
#25
Real Name: Sandman
Real Name: Sandman
Originally Posted by Mtnman01
Hi,
Hi, The rack is the Gobi Stealth with 2 4 gallon Roto paks
1983 HiLux 4WD
02-24-2019, 09:01 AM
#26
Wrap a rope around it similar to what you see on some vehicle antennas. This should eliminate the noise.
Mine doesn’t make any noise, maybe because it’s not smooth due to the Line-X.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
02-24-2019, 11:05 AM
#27
Real Name: Shwell
Real Name: Shwell
I have only run my rack with this 40" bar installed. I have not experienced any whistle or extra noise with it in this location..
Having it here, I do lose some light output because of the deflector, but a bonus has been no excess reflection off the hood when it is on.
Very foggy night
'18 TRD ORP 5100's Gobi Rack OME Springs
And a bunch of other stuff I dont really need!
12-15-2019, 03:06 PM
#28
Just acquired a GOBI Stealth...
Hey forum fans,
I just installed my rack (made for the 40" light bar) and now ready to tackle the light bar. Can you guys point me to a how to install guide. Interested in how the wiring is run up to the roof and where you guys install switches ect. on a 2018 TRD Off Road
04-04-2020, 05:56 PM
#29
Questions about Gobi Stealth
I have been looking at Gobis for my 2016 SR5. I stumbled upon this thread while researching, and I LOVE some of the set-ups.
4RUNNER (2010-2020 | 5th GEN) Archives - Gobi Racks
I want to:
- Use a Tepui hard shell roof tent
- Use a 1Up USA hitch-mount bike rack
- Have a multi-light system on rack (preferably on corners)
- Probably use a faring
Questions:
1) I am not seeing the stealth (no front riser bar) option on the website. Is that a "must call" feature?
2) Do the stealth racks still make it easy to put multi-light setups on top?
3) Are there mounts to put directional spots on the back corner(s)?
4) Are there better light options than the Gobi branded ones?
- I want to have one central light in front, one directional on each front corner, and maybe one on a back corner
5) Is it tricky self-installing the lights? In terms of running power?
6) Am I taking on too much hoping to install all this myself? (I'm pretty handy, but I've never tackled this sort of thing)
Thanks so much for your help and replies.
04-05-2020, 12:10 PM
#30
I want to:
Questions:
1) I am not seeing the stealth (no front riser bar) option on the website. Is that a "must call" feature? Yes, fairing is included with the rack. I recommend the removable crossbars. I didn't really like them as they sat too low when using for out RTT. I picked up some Yakima Rail Grabs and round bars so I could get my hands underneath it.
2) Do the stealth racks still make it easy to put multi-light setups on top? Yes, if you order the multiple light configuration they have plates in between the vertical support bars.
3) Are there mounts to put directional spots on the back corner(s)? Yes, they have the mounting spots like the front, but only on the corners.
- I want to have one central light in front, one directional on each front corner, and maybe one on a back corner On their site I'm only seeing Rigid brand. Rigid is one of the top brands out here. Another brand to consider would be Baja Designs.
5) Is it tricky self-installing the lights? In terms of running power? Not terribly tricky, no. There are a few ways to do it, but you could just run the wiring down the A-pillar (underneath the trim) and down into the engine bay. Run the rear light wiring down the length of the rack and down the A-pillar the same.
6) Am I taking on too much hoping to install all this myself? (I'm pretty handy, but I've never tackled this sort of thing) Installing the rack is easy. Remove the old rack, put in 2 bolts per foot of the Gobi, lift it on top and snug it down. The wiring won't be that bad.
Pictured is the multi light configuration
2017 T4R TRD Pro Cement - Dobinsons 2/1" (300/599), IMS 700/701, Air Lift 1000 air bags (60804), Pelfreybilt hidden winch mount, Warn VR8 w/ Amsteel synth, 2021 ORP LED headlights, DD SS3 Sport yellow fogs, CBI steel skid plates, Rough Country 20" LED bar, Gobi stealth no rise w/ ladder, ARTEC sliders, ARB 63qt fridge, Canvasback liners, homemade spare tire hitch carrier, ARB single air compressor w/ Slee mount, bronze TRD Pro wheels
