Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 07-16-2019, 12:46 AM #211
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Originally Posted by KuhDunkADunk View Post
The Kurgo divider is foldable into 3 parts. So you could configure it to allow for a seat to be free behind either the driver or the front passenger seat. However, keep in mind that the Kurgo uses the headrest to support itself and when you are using it like I'm using it, there'a strap that also goes around the seat (to keep it from moving around).
So I'm not sure I understand which configuration you need, but this is adjustable.
Hey! Thanks for the response. What I meant is having one passenger in rear seat. And then having the center hump covered using the Kurgo BUT having the upright center portion that blocks the dogs from getting behind to two front seats be down. So I would want my dog to be able to lay on the Kurgo bridging him from the backseat to between the driver and passenger front seats. Basically my dog likes to lay on the center console next to me as I drive so I wanted to make it easier for him. haha
pointman is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 02:56 PM #212
KuhDunkADunk's Avatar
KuhDunkADunk KuhDunkADunk is offline
KuhDunkADunk will become famous soon enough
It might be possible (I had to take my Kurgo out of the car for the next week) but you would just have to not use the headrest cable support. If you did, that center piece blocking the armrest area would just fall flat. When I put my Kurgo back in, I'll take a picture to show you.
See attached for now.
lets see your interior mods-kurgo-jpg
KuhDunkADunk is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 10:29 PM #213
Banned
Banned
Thanks again! That looks awesome. I was worried that if I wasn't using one of the headrest cable supports (so that 1 person could sit in back and so center pass thru was also down) that the entire Kurgo unit would fail and not allow for it to stay and cover the center hump in the floor. Appreciate all the help!
Old 08-15-2019, 06:58 PM #214
rnr1957 rnr1957 is offline
Real Name: Rich
rnr1957 is on a distinguished road
Real Name: Rich
Post Clean drilled dash RAM MOUNT with power for iPhone
This is my first post. My first mod for my (new to me) used 2017 Limited
5th gen T4Rs
Not my idea, but I wanted a cleaner look. I looked at two other ram mount base pieces and didn't like either. One wasn't visually clean and I decided I wanted more support at the base. It took me forever to find this for some reason, probably because it's not a standard base mount, but I think it should be.
RAM MOUNTS (RAP-395T-BBU Stack-N-Stow topside Base with 1" Ball
Secondly I wanted power for my iPhone run under the dash and separate from the Standard USB connected to the entertainment system. I tapped into the cigarette lighter power, it's already fused and connected to the key.
Here are my steps. (Photos show my how to)
1. Used painters tape to protect the plastic and give me a rough position.
2. Pulled the dash apart including the area where the cigarette lighter is. I did not include these steps they can be found in this group and on YouTube.
3. I needed to remove one wire from the entertainment system, I think it was the antenna wire. This allowed me to flip the assembly upside down and gave me more room to work on it from the passenger seat.
4. I figured out the best location visually, that was also clear internally. Note, there was barely enough room to use my low profile screwdriver.
5. Drilled a hole big enough to slide my iPhone connector through. I used a rubber grommet for a clean look. I did a practice test with a scrap piece of plastic to make sure I could get the plug through and insert the rubber grommet afterward. A little tight but worked well. I used a plastic dash removal tool to seat the rubber grommet. It was a pain, but worked well.
6. Made sure I had a clean path for the power cable to reach the cigarette lighter area.
7. Used a cigarette lighter style USB power supply. After looking at all my options. I used a metal bracket that holds the air conditioning ducks. One vertically wrapped tie wrap with two horizontal tie wraps. The bolt worked well to space the horizontal tie wraps.
8. Connected my power by tapping into the cigarette lighter and staggered the soldered connections for safety reasons. I used electrical tape and put the cable protector back in position. Black and white wire is the ground.
Thanks, Rich
More pictures Flickr
lets see your interior mods-01-jpg  lets see your interior mods-05-jpg  lets see your interior mods-09-jpg  lets see your interior mods-12-jpg  lets see your interior mods-14-jpg  lets see your interior mods-17-jpg  lets see your interior mods-17b-jpg  lets see your interior mods-20-jpg
rnr1957 is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 07:37 PM #215
Ferd_4R Ferd_4R is offline
Ferd_4R will become famous soon enough
Damn that looks clean!! Love what you did with the charging cable.
Ferd_4R is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 08:01 PM #216
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
I love the little rubber grommet. The little things that get me.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 08:15 PM #217
rbpower rbpower is offline
rbpower is on a distinguished road
This thread is insane. Psyched to reference it over the next few months.
rbpower is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 02:27 AM #218
michalik.piotr6837's Avatar
michalik.piotr6837 michalik.piotr6837 is offline
michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough
Holly shiiiiit, that Nardi wheel is the stupidest ricest thing i have ever seen in a 4runner. Eliminating the steering wheel controls and air bag for that nasty wheel? Lol. Ya, to each their own, yada yada. Lol
michalik.piotr6837 is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 03:07 AM #219
j3flight j3flight is offline
j3flight is on a distinguished road
I recently added some bungee straps in the cargo area so that stuff on the wheel wells was better secured...
- Remove the plastic bolt covers
- Use some fairly small nylon rope to create a loop at the top bolt.
- Cut a flat bungee into two halves, using one half for each side. Burn the frayed end.
- Poke a small hole in the cut end of the bungee and put the bolt through it.
Very helpful to keep things from moving around. Could be a little more professional maybe, but looks good enough for me.
Sent from my Pixel 3a using Tapatalk
j3flight is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 08:39 AM #220
BigCountryT4R's Avatar
BigCountryT4R BigCountryT4R is offline
BigCountryT4R will become famous soon enough
Originally Posted by OregonRaine View Post
I have a disability in my arms. The steering wheel is 100% a mobility and safety modification. Thanks.
Explain how that helps you over a normal steering wheel? Because, most with a disability use a small wheel attached to the wheel and you can use one arm to turn it from that wheel back and forth.
2019 4Runner Limited in Magnetic Gray Metallic, w/Redwood Interior, and 3rd row. Mods: Lastfit 7440/7443 Led Blinkers | JDM ASTAR LEDs throughout the interior and backup/license plate bulbs | OEM Tundra LED Fog Lights | Morimoto Elite HID 5500k 35w | Xenon Depot Led Pro 9005 w/LED Driver for DRL / XPLORE OFFROAD USA Flag rear windows | Adams Polishes UV Ceramic Paint coating
BigCountryT4R is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 04:01 PM #221
OregonRaine OregonRaine is offline
OregonRaine will become famous soon enough
Sure, one of the common adaptive devices is a spinner knob, or something else attached to an OEM wheel. I've tried one, and it made driving more difficult. I needed the wheel to be much closer to my body, since I can't extend my arms beyond 90*. The pic below should show how much closer the Nardi wheel is compared to the OEM wheel.
I've used the exact same setup across 5 vehicles over the last 12 years, with zero incidents.
It's a unique modification for our vehicles, and I'm likely one of the very few, if not the only 5th Gen in the world with an aftermarket steering wheel. I've been working on a solution for cruise control and infotainment buttons, too.
I scrubbed my post history related to this modification, since most responses from other members were juvenile, obnoxious and judgemental.
PS - I have a lot of family in Abilene and some in Stamford.
OregonRaine is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 06:20 PM #222
Yikes...
Old 09-20-2019, 07:14 PM #223
That is a interesting mod, and it definitely makes the wheel much closer to you. I can see it help someone with your issues, no doubt. You don't have any airbag lights stuck on at all?
If you ever come to Abilene, let me know. Would love to meet up.
Either way, ignore the haters, you got to do what you need too do to make it in life.
Old 09-20-2019, 08:14 PM #224
Zero airbag or other warning lights. I did a lot of research to determine part compatibility and make sure I wouldn't have any electrical Gremlins. Two resistors plug into the airbag harness, which takes care of the airbag lights, while keeping the other airbags active.
The only uncertainty was the display in the dash, and how it would function without the button to switch screens. For me, the default screen is avg MPG. When a door is opened, the screen automatically switches to show what door is open. Sadly, I still have the ECO bar, but I'm aware of how turn it off.
For the infotainment system and navigation, I can control everything from my phone, which uses a magnetic mount on the lower spoke of the steering wheel.
Old 09-29-2019, 01:55 AM #225
Banned
Banned
Don't let those people bother you. They are usually the ones with sad lives and nothing to do. There aren't too many on this forum, but they exist everywhere. Your truck, do what you want. I am sure people appreciate your insight.
1st/2nd gen Interiors and Interior Mods Lets see them! soj1057 Classic T4Rs 25 05-25-2017 08:43 AM
Post your interior mods Frontier719 3rd gen T4Rs 0 02-08-2015 11:47 PM
04 Interior and Exterior Mods rossagge 4th Gen T4Rs 12 06-06-2014 08:29 AM
Interior Mods Jay Rob 5th gen T4Rs 7 09-21-2011 08:52 PM
Interior mods beerstash 3rd gen T4Rs 5 03-27-2011 11:17 AM
