Clean drilled dash RAM MOUNT with power for iPhone
This is my first post. My first mod for my (new to me) used 2017 Limited
5th gen T4Rs
Not my idea, but I wanted a cleaner look. I looked at two other ram mount base pieces and didn't like either. One wasn't visually clean and I decided I wanted more support at the base. It took me forever to find this for some reason, probably because it's not a standard base mount, but I think it should be.
RAM MOUNTS (RAP-395T-BBU Stack-N-Stow topside Base with 1" Ball
Secondly I wanted power for my iPhone run under the dash and separate from the Standard USB connected to the entertainment system. I tapped into the cigarette lighter power, it's already fused and connected to the key.
Here are my steps. (Photos show my how to)
1. Used painters tape to protect the plastic and give me a rough position.
2. Pulled the dash apart including the area where the cigarette lighter is. I did not include these steps they can be found in this group and on YouTube.
3. I needed to remove one wire from the entertainment system, I think it was the antenna wire. This allowed me to flip the assembly upside down and gave me more room to work on it from the passenger seat.
4. I figured out the best location visually, that was also clear internally. Note, there was barely enough room to use my low profile screwdriver.
5. Drilled a hole big enough to slide my iPhone connector through. I used a rubber grommet for a clean look. I did a practice test with a scrap piece of plastic to make sure I could get the plug through and insert the rubber grommet afterward. A little tight but worked well. I used a plastic dash removal tool to seat the rubber grommet. It was a pain, but worked well.
6. Made sure I had a clean path for the power cable to reach the cigarette lighter area.
7. Used a cigarette lighter style USB power supply. After looking at all my options. I used a metal bracket that holds the air conditioning ducks. One vertically wrapped tie wrap with two horizontal tie wraps. The bolt worked well to space the horizontal tie wraps.
8. Connected my power by tapping into the cigarette lighter and staggered the soldered connections for safety reasons. I used electrical tape and put the cable protector back in position. Black and white wire is the ground.
Thanks, Rich
More pictures
Flickr
