Old 12-10-2018, 12:15 PM #1
a t l a s's Avatar
a t l a s a t l a s is offline
Real Name: Chris
a t l a s has a spectacular aura about a t l a s has a spectacular aura about
a t l a s's Avatar
Real Name: Chris
KDSS sway bar bushing fell out
I started having a front end clunk yesterday and I was worried that a bolt came loose or I busted a CV joint. Neither seemed too likely since I am very particular about torquing everything to spec, and I took care to watch my CV angles.
It sucked not having most of yesterday able to search the forum for possible causes (database error?) but when it finally came back up I found that the usual suspects are the sway bar bushings. This morning I saw this:
Thats the sway bar bushing that had slid out of the lower control arm connection. The angle of the connection relative to the sway bar seems pretty off since lifting the truck.
Anyone else experience this?
2018 TRD ORP w/ KDSS: King extended travel coilovers & shocks w/ adjusters - Icon tubular Delta Joint UCAs - Icon 2" rear springs - 17x9 -38 offset Stealth Custom Series stealth blue F5 wheels - 305/70R17 Nitto Ridge Grappler tires - C4 Fab Lo-Pro bumper - Baja Designs 30" S8 - Baja Designs Squadron Sport fogs - TRD Pro grille and rear bumper valance - Full custom audio system w/ CarPlay - URD MAF calibrator - Sprint Booster - RCI skid plate - Shrockworks angled sliders - Front Runner roof rack and Maxtrax mount - Xenon Depot Xtreme HID Philips 4300K low beams - ARB on-board air compressor w/ Rago Fab mount - Wifey 4-corner air system - Warn VR10-S winch w/ Factor 55 fairlead and Ultrahook - Odyssey 34R-PC1500T battery - Voltage booster - T4RPAM with Yaesu FTM-400XDR radio and Android tablet running Backcountry Navigator and APRSdroid
a t l a s is offline   Reply With QuoteReply With Quote
Old 11-27-2021, 12:15 PM #2
kailuakona04 kailuakona04 is offline
kailuakona04 is on a distinguished road
Just had this happen to me along the Mogollon Rim 2 weeks ago. Ordered new OE bushings and new brackets; apparently Toyota has also changed their front bushing and brackets for 2020+ T4Rs. What did you find out was the cause?
kailuakona04 is offline   Reply With QuoteReply With Quote
Old 11-28-2021, 01:13 AM #3
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Ugh, nope, thankfully. Curious, how much lift have you got? The higher you go the more distorted the bushing angles become.
If you had someone do the work check the bushings they are asymmetrical and go in a specific way (should be obvious though) EDIT: looked at your pic, not on my phone and it is indeed correct orientation.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 11-28-2021, 11:26 AM #4
firegod33r's Avatar
firegod33r firegod33r is offline
firegod33r is on a distinguished road
firegod33r's Avatar
Based on your pic I'm guessing you're running Kings 2.5? what's your coil rating in the front and how far down do you have it cranked to (how many turns, post a pic)?
I'm running the king 2.5 with 700 lbs springs and only 3 turns ( 130+ lbs added weight in the front)
Also, if you're pushing close to or over 2.5 inches of lift in the front you should install the Treatyoak Offroad from KDSS spacer. One of its purposes is to avoid what happened to yours. That spacers lowers the fixed arm side so that the KDSS bars sits at a more neutral angel against the bushing. That was the first thing I did after I upgraded to the 700lbs coils.
KDSS Spacer Kit | Treaty Oak Offroad
firegod33r is offline   Reply With QuoteReply With Quote
5th Gen. KDSS vs. Non-KDSS handling performance & sway bar diameter differences. CS223 5th gen T4Rs 60 12-08-2021 06:48 PM
KDSS used bushing. calcrc 5th gen T4Rs 9 06-14-2016 08:07 PM
2015 Kdss sway bar bushing help canucks4runner 5th gen T4Rs 7 05-26-2016 10:38 AM
kdss bushing fell off... tamadabee128 5th gen T4Rs 14 04-12-2015 01:05 AM
sway bar bushing riceandpho 4th Gen T4Rs 1 01-16-2009 09:26 AM
