01-01-2019, 07:35 AM
#16
Did you encounter any issues removing the rack? I've seen another post saying that they may have a plate that could fall into the headliner once you remove the bolts. Could you describe the process please. I'm taking delivery next month and I want to fit a full roof rack.
Looks awesome in the Blue my GF wanted black. I gave in.
2019 4runner TRD PRO Midnight Black Metallic
01-01-2019, 03:57 PM
#17
Su-Su-Sussudio
Originally Posted by sn_85
Seriously the TRD Pro rack looks like a receding hairline.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
01-02-2019, 12:18 AM
#18
During the xmas break I put the 2019 basket rack back on the Pro, and took out the 2011 Trail rack for painting. I primed it and painted it. In fact I installed back the Trail rack today but unfortunately did not take any pics.
In short, I did not see anything that falls inside the roof panel.... not today nor in the past.
There are two mounting designs among the 5th Gen 4runners.
1) 2010-2013 Trail, and now 2019 Pro has the same mounting design. This design places a metal bracket between the rack and the room panel. Not counting the rubber piece in the middle here. Inside the room panel, for each side (front, rear, left, right) there are two short plastic cylinders coming out where the bolts would go in. The one bracket I mentioned sits around these cylinders. You then put the rack in place which sits perfectly inside the room panel cavity where the cylinders and the bracket is. I do not see anything inside the panel that falls out or gets lost within the roof panel. The bolts uses a "*" type socket. I bought thin rubber washer from Lowes that goes on the bolts. When you take out the bolts, the cheap washers mounted by the factory will rip and you can not save them.
2) The remaining all trims in any years between 2010 and 2019 has a second mounting design which is very simple compared to the one I explained above. straight bolts and regular socket. a thick rubber washer is used by toyota which can be reused. no special bracket sits in between the rack and cylinders that accept the bolts.
i hope this helps.
01-03-2019, 09:15 AM
#19
Great explanation. Thank you
Sent from my iPhone using Tapatalk Pro
02-22-2019, 05:20 PM
#20
i hope this helps.
By * did you mean torx ? If so what size? I’m removing my pro rack next week and I’d love to know if I need any special tooling. Thanks so much.
02-22-2019, 09:00 PM
#21
Torx T40 size. nothing else needed.
02-23-2019, 05:42 AM
#22
I may be one of the rare folks who likes the 2019 trd pro rack . But I also like the fj cruiser.
02-23-2019, 05:44 AM
#23
Originally Posted by doyoueventraps
Just Ordered. Thanks!
I ordered the Roof Rack off a Toyota dealer, they first time me that the TRD Pro Rack only fits on Pros and needed a VIN number. I thought that was weird.
I called another Toyota dealer to order one and they said that Toyota is putting a stop order on them and are only selling it to Pro VINs because they were using it for the vehicles sold.
Finally I ordered from another dealer and used the last 8 if a VIN on an inventory model to get the order placed. Now I’m just hoping that it does indeed fit as it will be a pain to return if it doesn’t.
Based on your pictures (thanks btw they’re great) it looks like it should. Ppl don’t like the rack but I had an FJ and I really liked how it looked so I totally dig it.
How much did you pay for the 2019 pro rack ?
02-23-2019, 06:21 AM
#24
I too liked it on my FJ but I just don't think it flows well on the 4Runner.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
04-21-2019, 01:29 PM
#25
There is a bracket that holds a pair of nuts (and plastic cylinder you see coming through the roof) under the roof. This can break off as it is probably tac welded to the roof. Will post a pic of what happened to mine and what the bracket looks like.
FYI I was taking off my factory 19trdp basket. My guess is that is the same for all 5th gens.
04-26-2019, 10:40 PM
#26
i see. so this means i should be careful in the future when swapping the rack. thx
11-24-2019, 08:28 PM
#27
@ niadh0
... question.
Is it just the metal bracket that's different? I see the same plastic cylinders in some youtube videos of non-pro non-trail roof rack deletes ...
Thx
i hope this helps.
11-25-2019, 01:38 PM
#28
none at all. exact fit.
i have installed
- an SR5/Limited rack from 2016 model onto my 2011 Trail with out an issues, before trading it in for the 2019
- installed 2011 Trail rack on the 2019 Pro without an issues.
the 2010-2013 and 2019 comes with the same type of bolts (with black heads as the heads stay exposed) where you need a '*' type of socket for taking the bolts out... where as the rest of trims (2010-2019) the bolts come with 10mm/12mm regular socket type bolts.... but the size, thickness, and the thread patterns are exactly the same.
long story short, no issues, the pattern for holes in the roof is identical across all trims 201-2019
How are the bolts holding up on your 2010-2013 trail rack? I have one on my truck and one of them got stripped. Because they're round on the outside (instead of a bolt), it was a huge PITA to get the thing out, eventually got it out by dremeling a slot (got a tip from a member on here with that idea which saved my ass) and using vice grips to turn a giant flathead screwdriver in the new slot. The metal in the bolts is so soft, once it starts to strip, it's a nightmare. So use caution going forward!
11-25-2019, 01:44 PM
#29
Real Name: Pj
Real Name: Pj
I'm with you on that one.
11-27-2019, 09:43 AM
#30
I believe the bracket under the roof is same in all trims.
Originally Posted by rageandlove
@ niadh0
... question.
Thx
