12-14-2018, 09:07 PM
Loctite blue or anti-seize paste for skid bolts?
I'm going to get my skids and sliders soon and have seen both materials suggested for the bolts. The blue threadlocker supposedly protects from corrosion and vibrating free, while the anti-seize does its thing for easy later removal but has a greater chance of vibrating loose?
Any one have experience with either?
2018 ORP Magnetic Gray, RCI sliders and skids
12-14-2018, 09:16 PM
definitely anti seize, skid plate bolts usually rust, strip and need to be drilled out
Troner envy... the struggle is real!
12-14-2018, 09:34 PM
Definitely anti-seize ... as CF_Machete said, these bolts are notorious for rusting/breaking.
2020 Silver 4Runner Venture w/KDSS, sliding cargo tray, Falken WildPeak A/T3W 265/70R17 tires
12-15-2018, 01:16 AM
Anti seize with lock washers. You don’t want any welded nuts breaking off in tbe frane.
12-15-2018, 01:56 AM
Vibra Tite AC-3. Much better than your regular thread locker - repositionable. If you use anti-seize - nickel based is the best.
12-15-2018, 12:26 PM
Anti-seize BUT I live where they use salt and slurry on winter roads.
You should also understand that anti-seize works as a lubricant and will affect the torque settings of the hardware. The factory frame nuts aren’t a very hard steel either, if you are using aftermarket hardware they are more than likely a higher grade. Don’t over torque.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
12-15-2018, 02:34 PM
Never had a problem with anti seize and just snugging them down.
I had 1 completely seize on my 4th gen that I never fixed.
On my 5th gen I also had 1 seize and fixed it when I did RCI skids. Was going to drill it out and retap but the welded on nut completely snapped off so I just drilled the hole out and used a m8 nutsert.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
12-15-2018, 03:01 PM
Anti seize and lock washers. If you want to go the extra mile - use bolts drilled for safety wire.
12-15-2018, 03:06 PM
Another vote for anti-seize.
Sent from my SM-G960U1 using Tapatalk
2008 Sport Edition - GONE
2020 TRD ORP
12-15-2018, 03:14 PM
Anti seize here. I'd also consider running a tap through any threaded holes just to clean them out. My factory skid had a ton of crap in the attachment point threads.
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
12-15-2018, 07:22 PM
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
12-15-2018, 07:52 PM
@ SnowYeti
are you sure those are m10x1.25? You're linking to a m10 tap anyway.
IIRC all that undercarriage hardware is m8x1.25
2013 TE w/ KDSS Nav
12-16-2018, 12:04 AM
Pretty sure I got the links from another discussion on the same issue. You might search to find that thread. Several people did it and talked about the gunk that was up there, and that the factory threads were not great leading to galling, then to stripping.
I have not done it yet. But I would caliper the bolt to make sure. Though if it is a M8, the M10 would not even start in those threads.
Personally I wii also try and find some stainless replacements. Even though they will be weaker I don’t think it will matter in this application. The SS will have less galling issues. I think the zinc plating on the stock fasteners was a poor choice for repeated use. (Oil changes)
12-16-2018, 11:33 AM
@ SnowYeti
Well you’re telling someone to buy something that isn’t correct. Not sure why you are telling me to search for a thread that you posted information from, but whatever. *shrug* You should do you own research to make sure what you are sharing is the right information.
When you say “chase the threads” you are cleaning them not cutting new ones as you would with a larger or different pitch tap. The Amazon link you posted, goes to a larger tap, an m10x
If someone takes your advice, buys something, it’s incorrect, the only one that looks bad here is you. That’s all I’m saying.
2013 TE w/ KDSS Nav
12-16-2018, 11:44 AM
I’ve found that while I only use a bit, the anti-seize is a little bit gummy and I’m not concerned that the bolts will rattle out. All my skid plate bolts are installed snug tight at best. Those fasteners want to twist apart with anything larger than my smallest ratchet
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
