03-09-2022, 12:18 PM
#1606
Put a piece of 3m paint protection film across your roof where the wind fairing will be. That will eliminate any potential contact issues with the roof.
2021 White 4Runner ORP, Bilstein 5100, OME 2” front, 1” Eibach rear, RCI aluminum skids - Engine, Transmission, TC, A-arm (steel) and gas tank, LFD stainless steel 7/8 rack, RCI steel sliders 20 degree no plates, Greenlane ladder, 265-70/R17 Toyo Open Country ATIII, SprintBooster
03-09-2022, 01:18 PM
#1607
have you done this? my concern here would be vibration will still wear on the components. likely the rubber piece first, then it would be metal on the ppf and will wear the ppf down to the roof
has anyone done this with long term success?
03-09-2022, 01:24 PM
#1608
Yes I have done this and no issues at all. Probably wouldn’t be a bad idea to simply replace the film every few years. The 3m film is very tough. The fairing (really the rubber piece) doesn’t touch the roof with much force, so there really isn’t enough motion or force to wear down the 3m film to the roof. Just make sure to check that your fairing is bolted tightly every few months, which you should be doing anyways, and you will be fine going this route.
03-09-2022, 01:36 PM
#1609
ok thanks. so it seems maybe light pressure from the rubber is what to expect vs. the fairing 'resting' on the roof. I do have some XPEL that I can get so that should work fine. my boxes will actually sit just ahead of the fairing so I might not actually need it which is also why I didn't buy it. going to test first without it and see how it is
03-09-2022, 03:15 PM
#1610
That is the case for me. If I didn’t have the rubber piece installed, the fairing would not touch. But it would be super close and I just didn’t want to take the chance of it contacting the roof in case it a mounting screws got just a little loose or if any added weight to the fairing crossbar depressed the crossbar onto contacting the roof. Good luck and let us know your results once you test it out!!
03-20-2022, 06:10 PM
#1611
Windrock with the LFD crew this weekend.
03-23-2022, 11:17 AM
#1612
Real Name: Mark the Common Sense Wizard
I can't wait till I can make it out there for one of these meets.
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
03-23-2022, 06:00 PM
#1613
04-05-2022, 01:16 AM
#1614
I’m about to buy 2 wide SS bars and an integrated wind fairing SS bar. I’m thinking I might get a 3rd wide bar for more support (and not gonna lie, for aesthetic reasons).
Does anyone have this set up? I searched and couldn’t find any photos or info.
04-08-2022, 06:26 AM
#1615
The LFD Off Road Thread
I recently bought stainless crossbars to put on my factory rails. Like others have mentioned I was also worried about the wind fairing rubbing my paint. After doing some research and looking at pictures I noticed that the bolt on wind fairing didn’t touch any of the roofs in any of the pictures I saw. There was always a slight gap in every picture I could find. I ordered the bolt on wind fairing and the fit was perfect. No rubber weather stripping needed and enough of a gap (but not too much) to where I didn’t have to worry. The bolt on wind fairing is $49.99. Loving the setup and highly recommend.
04-15-2022, 05:41 PM
#1616
checking this thread to see if anyone has mounted lights on the sides of their LFD rack. the shape (i.e. not flat) side rails make it seem a little tricky. I fish a lot at night and could benefit from a side utility light.
2004 v8 | bilstein 5100s | ome883 + wheelers t12 | 2013 FJ cruiser wheels
04-19-2022, 05:45 PM
#1617
Recently added the stainless full rack to my 5th gen and so far so good. There was something slightly askew when putting on the front support feet, I should have double checked that before tightening everything down. Instead of loosening it up and trying to shift things, I made some spacers from some scrap bar stainless and it solved the issue. No noticeable wind noise until I was going over 80. Sealed the mounting points with GE 100% supreme silicon from the big box store and after a few rains there are no leaks, hope it stays that way.
As an added touch I went ahead and had paint protection film put on the roof prior to install so I don’t have to obsess about a dirty roof.
Also painted the bolt heads for a cleaner look, YMMV. The close up of the mount uses my own bolts since the spacers required something longer than was provided.
Now I’ve got a foundation to build on, thanks for a quality product and great packaging that kept everything safe in shipping.
2017 TRD-OR w/ KDSS
04-19-2022, 09:39 PM
#1618
I don’t know their entire product line but here’s a pic of the side rail of my 5th gen full rack showing part of the side rail is flat
2017 TRD-OR w/ KDSS
04-20-2022, 02:56 PM
#1619
I have mounted lights on the side a few times with success. I was not using them much. So, mine got relocated.
04-20-2022, 05:02 PM
#1620
official vendor
official vendor
We've got some bolt on handle/light mounts that just came back from paint a few days ago... working on photos as soon as the truck with them installed comes back from vacation this week
ETA photo!
