LFD_Off_Road
Old 01-04-2019, 03:39 PM #46
TRDBuckeye TRDBuckeye is offline
TRDBuckeye is on a distinguished road
Originally Posted by rmbertoldi View Post
Finally got my wide skid on this wknd, aside from one bolt with the top spun off (thanks Toyota tech) being a particular PITA to get out..everything went smoothly and this thing looks awesome and TOUGH. Thanks again LFD!
Just a tip, when you bolt-up the rear/middle two bolts at the crossmember, make sure to use the spacers LFD provides to get clearance..I almost missed them in the bag because I used my own zinc-coated bolts for the install!
Any pics installed? Looks good
TRDBuckeye is offline   Reply With QuoteReply With Quote
Old 01-04-2019, 11:11 PM #47
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
what's the weight difference between the aluminum and steel ruggedized roof cross bars? is the weight limit the same? do they come with hardware? I was really close to pulling the trigger on rago cross bars, but I like the aluminum idea much better and that look to have more clearance between the bottom of the bar and the top of the roof.
and what's the difference between the 5th gen regular skid and the wide one?
mr.walleye is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 04:23 AM #48
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I would like to know the difference also. I’m thinking about the Rago crossbars and was considering the Prinsu until I heard about many quality issues. What is the total weight of the LFD 3/4 rack in aluminum as compared to steel? What type of wind noise does this rack produce and is there any clearance problem with a sunroof? Also, any measurable difference in gas mileage? TIA
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 03:58 PM #49
unsub1 unsub1 is offline
unsub1 will become famous soon enough unsub1 will become famous soon enough
No issues with noise or clearance on my full rack, for what it's worth.
unsub1 is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 07:59 PM #50
Isais101 Isais101 is offline
Isais101 is on a distinguished road
Stock side rails
I want to know if I can put a CVT tent on top of lfd cross bars on stock side rails?
I’m don’t want to spend another $500 I already spent about $2000 on the tent
Isais101 is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 08:11 PM #51
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
I rough it out, we don’t need no stinking tent.
The LFD Off Road Thread-91efce3c-cc3f-410a-b44b-0d33c2a7d5ad-jpeg
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 10:04 PM #52
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
I highly doubt you could with stock side rails. You already spent all that money, mind as well finish it would the structural sound LFD side rails.
slprciv is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 10:25 PM #53
YellowSnow YellowSnow is offline
Banned
YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough
Banned
Why couldn’t you? Those oem side rails are bolted on and just as strong as any other rack.
YellowSnow is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 10:52 PM #54
renau001 renau001 is offline
renau001 will become famous soon enough renau001 will become famous soon enough
Pretty sure @007Tacoma had a RTT on LFD crossbars before putting a rack on.
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
renau001 is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 06:11 PM #55
young young is offline
young is on a distinguished road
I have a hard shell RTT on LFD crossbars on the stock rails. No issues on sleeping but I am concerned about its front end bouncing at high speed (after 40 mph). I am getting 7/8 roof racks and I am hoping the bouncing issue would be eliminated.
young is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 06:53 PM #56
Brian3676 Brian3676 is offline
Brian3676 will become famous soon enough
I have the LFD cross bars with stock side rails and a tent. Works just fine.
Brian3676 is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 10:29 AM #57
rmbertoldi's Avatar
rmbertoldi rmbertoldi is offline
Real Name: Ryan B
rmbertoldi is on a distinguished road
rmbertoldi's Avatar
Real Name: Ryan B
I know you can with the RAGO reinforced cross bars mounted into the factory roof rails..it's what they're made for and why they're reinforced to hold up to 500lbs (I believe that's the number from Rago).
rmbertoldi is offline   Reply With QuoteReply With Quote
Old 01-07-2019, 10:31 AM #58
rmbertoldi's Avatar
Real Name: Ryan B
rmbertoldi's Avatar
Real Name: Ryan B
Yeahhh I've been meaning to get one, I finished up the install in the dark that day. I'll get one up, maybe at lunch today, I love this thing it looks great and is a solid, not overly gawdy or "customized" addition. Should do the trick great once I get to the testing!
Old 01-08-2019, 09:44 AM #59
jwscott79's Avatar
jwscott79 jwscott79 is offline
Real Name: Jason
jwscott79 will become famous soon enough
jwscott79's Avatar
Real Name: Jason
Got the LFD crossbars installed yesterday.... and this morning's ride to work sounded like I was riding on 40" boggers. I assume this is normal due to the size/shape of the bars, just sounded extra loud. I did take a look to make sure no hardware backed out during the drive. Anyone else have the same sound issue after installing crossbars?
Btw, the crossbars are perfect for my needs and look great on the truck, can't wait to find something to haul up there. Thanks Jacob and Scott for all your help and a great product.
jwscott79 is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 09:58 AM #60
16Gamer 16Gamer is offline
16Gamer is on a distinguished road
Just blacked out the rails and added three LFD bars and noticed the same wind noise. I've noticed it's worse if there is a cross wind. Nonetheless, they are stout and look good and I have confidence hauling almost anything up there now.
The LFD Off Road Thread-image1-jpeg  The LFD Off Road Thread-image2-jpeg
16Gamer is offline   Reply With QuoteReply With Quote
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
