09-11-2019, 07:57 PM
#586
@ jafrush
can let you know about ladders
Edit: lol too slow
09-11-2019, 08:01 PM
#587
Real Name: Jacob
Real Name: Jacob
I installed one of our revised 3/4 racks on my '16 Trail this past weekend as part of its conversion over to the family vehicle.
I've never actually had one of the 3/4s on my own vehicle before. I honestly can't tell its up there. Its by far the quietest rack option we offer, mainly due to sitting farther back out of the wind. Very happy with this little rack setup.
Crummy cell phone pictures from behind the plant tonight
09-12-2019, 11:09 AM
#588
I know you've answered this before
@ jafrush
, but I can't find it through a search and its not on the lfd site.
How much does the 7/8 rack with aluminum cross bars weigh? the all aluminum full rack?
Also, how much height do they add to the roof line at their tallest point?
Are there any plans to do the side rails for the 7/8 rack in aluminum instead of steel? How much weight would that save?
Also, do you have any plans to make the wind fairing form to the roof better? In the site photos it appears to just be a straight cut fairing along the bottom that does not contour with the roof.
I know you've mentioned that you're trying to keep skus low and only have one fairing for multiple vehicles, but honestly that's the only thing that has me looking at something other than LFD.
Thanks for your reply.
Build thread
09-12-2019, 11:23 AM
#589
Real Name: Jacob
Real Name: Jacob
@ jafrush
The 7/8 aluminum weighs around 50 pounds, the full aluminum around 60 pounds. Both of the aluminum options do have aluminum side rails made out of 1/4" aluminum. The full rack is the tallest, and adds about 5.5" at the rear of the vehicle, which should be your tallest point with a factory rake. The 7/8 is around a half inch shorter.
We're evaluating a few faring options to hug the roof more, but honestly the racks are not that loud as is compared to other brands we've all owned. The Gobi rack that came on the red 4Runner I just bought was much, much louder. Each complete rack does have its own wind faring already, the comment earlier about SKUs was relating to the bolt on faring option for crossbars. Complete racks get a crossbar with an integrated faring instead.
09-12-2019, 12:28 PM
#590
Exactly what I want my set up up to be with the exception of using the factory rails (have and like to use my moonroof). Right now I have just the Hi-lift jack mounted. I just need to see if I can fit 1 or 2 Rotopax's to it. I may go with the shorter ARB Tred 800's to see if that gives me more space for them.
Will probably get a hybrid front bumper too eventually. I like the winch access, no other bumper that I know of has that.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
09-12-2019, 12:43 PM
#591
I use 4 of the crossbars and was able to fit a hilift, shovel, 2 2gal rotopaxs, and a set of Xbulls
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
09-12-2019, 12:48 PM
#592
Real Name: Jacob
Real Name: Jacob
The 3/4 sits behind the sunroof and doesn't interfere at all, and gives you about an additional foot of mounting room versus the stock side rails.
I was able to fit rotopax between the Maxtrax and the hi-lift with my crossbar setup on the factory side rails when I had that setup.
09-12-2019, 01:27 PM
#593
In some other topic in the General section there was someone that thought the Xbulls could be mounted using the ARB mount for the Treds. Not sure if that is true but that would be cool. Otherwise I guess I'll just the Tred 800's or get the XBulls and get some hardware from the Hardware store. The Tred mounts are expensive though.
09-12-2019, 03:51 PM
#594
Just ordered my SR5 and am super excited. LFD looks to be the best option for keeping the stock roof rails. I have a 14' paddle board that will be going up on top. Do I have to wait until I'm out of warranty to add a full (3/4) rack?
09-12-2019, 04:12 PM
#595
I just use 3/8" SS carriage bolts for my bolts, the square part of the carriage bolt fits right into the slot. I used either 3" or 3.5" (cant remember) carriage bolts and a wing nut for my xbulls.
09-12-2019, 05:11 PM
#596
haha I believe that was me! Sorry forgot to update you on that. The ARD mount did NOT work with the Xbulls. The width was just a tad short. IF you wanted you could make the hole bigger on the Xbulls. I ended up just making my own mount.
Originally went with Carriage bolts but switched them out to 5.5in SS -Threaded rods (5/16). Allows me to remove them quickly (my other accessory mounts are attached via a Tnut). I use a wing nut+washer on the bottom part and a nut + rubber wash on top. The rubber washer keeps the mount from vibrating. To secure the boards I use a clamping nut along with a 1/2in pvc pipe. All in all, very happy with it
photo of all the gear attached (minus shovel)
09-12-2019, 06:02 PM
#597
Thanks for the info.
Regarding the question about putting the LFD side rails on and warranty, I don't know for sure but I highly doubt it will affect your warranty at all. The advantage is about a foot more of space up there to put things. I think the LFD siderails look better than factory too.
09-12-2019, 06:04 PM
#598
Real Name: George
Real Name: George
Heck yeah, man. I have the new 3/4, quiet as a church mouse.
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
09-12-2019, 06:07 PM
#599
Real Name: George
Real Name: George
......A ladder is on our to-do list, but haven't gotten around to it yet.
Well that's just peachy..... another part from LFD to sit and wait for....
RVA Toyota Trucks
09-12-2019, 07:37 PM
#600
The only relevant way I could think it would have anything to do with your warranty is if you had a leak in the headliner, they probably wouldn't warranty that if you had installed a rack. Just apply silicone around and in the hole and it's not a worry.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
