LFD_Off_Road
Old 09-17-2019, 03:37 PM #616
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Originally Posted by SpeedyKevin View Post
Are you unscrewing nut and pulling it out from the bottom of the rail? When I was using carriage bolts (5in), they were too long so I can't get them out from underneath the crossbars. Probably could with a shorter one. With the rod, I don't need a tool and just unscrew the butterfly nut
3/8 fits right through the slot, you can go as long as you want, just lift the bolt up through the slot and the square parts holds it in place. I could use a wing nut but use regular nuts just to make it slightly less convenient if someone wanted to steal the xbulls.
I used threaded rod on the OG crossbars with the holes because of what you said with being too long, but now that there are slots I just use carriage bolts. 1/2" would be too big and have the same problem, but 3/8 fits right through and the square part fits perfectly in the slot (smaller than 3/8 and the square part can turn in the slot)
jhguth is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 03:45 PM #617
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
ahh ok makes sense! Are you securing/locking your Xbulls down? If so, how? Saw some folks drill a tiny hole in the bolt to use a lock. Was considering just using a bike lock through the side handles on the xbull
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 06:15 PM #618
gdvan01's Avatar
gdvan01 gdvan01 is offline
Real Name: George
gdvan01 will become famous soon enough
gdvan01's Avatar
Real Name: George
Installed a 100W solar panel on the rack, recessed so I can still carry lumber or plywood without the solar panel being in the way.
@mteolus you can see 2 of the SS carriage bolts in this pic I use for my x-bulls (i'm not sure i understood the other comment about saving time with 5/16 threaded rod, the carriage bolts just slide right through the slot and just need a couple washers and lock washer to secure them. the slot is the size of the square part of the carriage bolt so you only need 1 tool)
That's pretty slick with the solar panel.
Another good idea for the board mounts too.
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
gdvan01 is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 12:06 AM #619
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Originally Posted by gdvan01 View Post
I apologize that this took me so long, but I ended up being too sick to complete my voice overs until this past week...
YouTube
YouTube
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 09:06 AM #620
gdvan01's Avatar
Real Name: George
gdvan01's Avatar
Real Name: George
YouTube
YouTube
Dude, that's awesome...thanks!
RVA Toyota Trucks
Old 09-18-2019, 08:24 PM #621
Paragon29er Paragon29er is offline
Paragon29er is on a distinguished road
Got my rack and it has been sitting for a few days while I get the time to install it. More specifically...get the time to get help in case I run in to trouble. I've mentioned I'm not mechanically inclined, so I have another question for the group.
Directions say to use some silicone when bolting the side rails on to keep it waterproof. Husband recommends 3M Marine Adhesive Sealant Fast Cure 4200; he even fished some out of the shop for me. He's a pretty smart guy....but should I follow the directions or follow his recommendation? Either?
Don't worry....you're not taking sides in an argument.
Paragon29er is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 09:50 PM #622
you'll want something that remains flexible because things are going to move and also expand and contract with temps
the 3M marine adhesive says it remains flexible, so it may be okay, but if everyone else is using silicone and has some longer term feedback that it works to me that seems like the better way to go
Old 09-18-2019, 11:54 PM #623
catus's Avatar
catus catus is offline
catus will become famous soon enough
catus's Avatar
I posted this in the What did you do... thread, but figured it belongs here too. LFD 3/4 rack on my 5th Gen. Perfect size for what I need, and strong! No noise from the rack either.
catus is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 10:34 AM #624
jafrush's Avatar
jafrush jafrush is offline
Real Name: Jacob
jafrush is a jewel in the rough jafrush is a jewel in the rough jafrush is a jewel in the rough
jafrush's Avatar
Real Name: Jacob
As long as you get the caulk/sealant around the holes without gaps you shouldn't have any issues. I dont know how fast "fast drying" is, so Id just make sure you get the spacers on before the caulk dries.
jafrush is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 11:04 AM #625
007Tacoma's Avatar
007Tacoma's Avatar
meant drop these photos of the hidden winch mount here...
I'm 007Tacoma.
Old 09-19-2019, 11:19 AM #626
007Tacoma's Avatar
007Tacoma's Avatar
then added some eBay lights to it...
I'm 007Tacoma.
Old 09-24-2019, 10:48 PM #627
AZ Silver Dollar's Avatar
AZ Silver Dollar AZ Silver Dollar is offline
Real Name: Duane
AZ Silver Dollar is on a distinguished road
Real Name: Duane
Your rack looks great!, I ordered the 7/8 rack because I have no sun roof. still have a couple weeks to go to get mine .... why does time go by sooooo slow when your excited about getting something HAHA
AZ Silver Dollar is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 11:13 PM #628
Real Name: Duane
Real Name: Duane
Originally Posted by jafrush View Post
This is the only one I have at the moment. None of us even have one installed yet on ours, we cant keep them in stock long enough to claim one for ourselves...
I really dig the look of that! Im kicking my self, I should have ordered this skid at the same time I ordered my rack so I could have them both at the same time
Old 09-24-2019, 11:37 PM #629
catus's Avatar
catus's Avatar
Too true! I really had to work at not bugging Jacob so much about the delivery date, so I think I only asked twice! Thanks - the rack does look great and is perfect for what I need. Installation isn't bad even if you're solo...just block out a couple of hours and you'll be set!
Old 09-25-2019, 12:06 AM #630
Real Name: Duane
Real Name: Duane
yeah I wont bug Jacob, I still have few weeks left anyway. I wonder if the 7/8 rack is as quiet as yours? I will see soon enough
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
