LFD_Off_Road
Old 10-09-2019, 06:05 PM #661
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Originally Posted by uh0h50 View Post
Looks good. What did you use to secure the boards down?
5" long 3/8 bolts, 4 of them. Others use two but when I did mine the boards were a little warped so I used 4. Held the bolts to the cross bar with a washer, a lock washer, and a nut. I think I used a 7/16 (or whatever the next size up was) flat washer since it is a little wider than a 3/8.
Now to hold the XBulls down, you can use a 1" od (outer diameter), 1/2 id (inner diameter), and 2" long steel bushing to go on top of the XBulls after you slide it on the 4 bolts. But they were expensive. Steel Bushing on EBay. Notice at $7 not too bad but they want $8 for shipping. I also found them at an Ace Hardware store (no shipping because it's in person) but they were $12 a piece. Since they are steel they will rust.
So I chose to go cheaper and go with a 1/2" PVC 2" connector pipe. It's threaded on each side but it's already pre-cut so much easier than buying a pipe and cutting it yourself. 70 cents a piece at Ace Hardware. Here is what it looks like although this isn't exact and is more expensive.
Then I screwed them down with 4 of these.
Pic. And thanks to Brick Sprickly for the help.
The LFD Off Road Thread-xbull-setup-jpg
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 10-11-2019, 01:22 PM #662
jafrush's Avatar
jafrush jafrush is offline
Real Name: Jacob
jafrush is a jewel in the rough jafrush is a jewel in the rough jafrush is a jewel in the rough
jafrush's Avatar
Real Name: Jacob
Small update post:
We're not exhibiting at Expo East this year because I'm recovering from a small surgery earlier this week, and none of the other guys could make their schedules work. Was really a bummer how the timing just sucked this year all around.
We were talking though this week, and are actively planning on making the trip out to Expo West this coming year! Really excited about that already. I've been out west several times, love it out there, but never with my own 4x4.
Lead times: Over the past several weeks we've really worked on increasing stock levels on a lot of items, and our shipping team has also done a phenomenal job getting orders out ahead of schedule. Right now we're actually sitting at less than one week lead time on most of our roof rack products. That's still going to fluctuate depending on order levels, but we're going to try to keep that lead time down for roof racks.
Also last week we had one of our good customers, Ed, stop by on his way out to Utah. He's got one of our rear bumpers (and roof rack and full skid set), and was actually in a wreck on the interstate about two weeks ago. The bumper took the impact and saved his 4Runner, he drove away with only some damaged powder coating and a bent left rear wheel. You can see the mark on the left rear corner of the bumper. Hated to hear about the accident, but was really awesome seeing how well the bumper held up. Its the second time now that we've had one of our rear bumpers get hit, and both times had the same result. They're freaking stout Really looking forward to getting one back on my own 4Runner.
We'll be set up next Saturday in Uwharrie for the Uwharrie Outdoor Summit, come by and say hi if you're around!
jafrush is offline   Reply With QuoteReply With Quote
Old 10-11-2019, 03:29 PM #663
gdvan01's Avatar
gdvan01 gdvan01 is offline
Real Name: George
gdvan01 will become famous soon enough
gdvan01's Avatar
Real Name: George
Originally Posted by jafrush View Post
Small update post:
We're not exhibiting at Expo East this year because I'm recovering from a small surgery earlier this week,...
Get well soon!
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
gdvan01 is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 10:45 AM #664
jafrush's Avatar
Real Name: Jacob
jafrush's Avatar
Real Name: Jacob
Question for people who have our racks (and if you don't as well I guess)
One of the complaints we hear often is that the carriage bolts are ugly. Unfortunately we still havent found any other solution for the carriage bolt that is both black AND corrosion resistant AND the appropriate grade.
I just got some bolts in that are black with an even higher corrosion resistance rating than the current yellow zinc carriage bolts, BUT they're standard bolts. So that means install would require two wrenches. The second negative is they're extremely pricey - it was $110 our cost for a full rack's work of them. We're trying to see if we can find them cheaper from another vendor.
So, the question - Is the negative of needing two wrenches for installation, and a probable higher cost, worth it to people to get black hardware instead of the yellow zinc bolts? It would probably start as an option instead of making it a standard.
I'll probably install these on the rack sometime this week or next week to see what it looks like.
Old 10-16-2019, 11:16 AM #665
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
Post In My Humble Opinion: Zinc Carriage Bolts
What follows is 100% my opinion...
If I didn't like the look of the zinc carriage bolts, I would have no problem painting them. I may actually do this with plasti-dip as that would be a great way to do it. The higher cost of the black bolts really is not worth it to me, but I understand why other people are wanting that option.
For me - I chose the LFD Roof Rack for its unique design, the single wrench needed to adjust, the overall strength, and its relatively low cost. Also, I LOVE the smooth look of the carriage bolts and being able to use a single wrench to move my crossbars around.
I may do a trial run of plasti-dipping the the carriage bolts to see how it looks...
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 11:22 AM #666
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
I used self etching primer and black automotive spray paint
I'd prefer the carriage boots for single tool installation vs black bolts, it only cost about $8 to paint them
Sent from my SM-G960U using Tapatalk
jhguth is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 03:03 PM #667
007Tacoma's Avatar
007Tacoma's Avatar
That does look good.
I'm 007Tacoma.
Old 10-16-2019, 05:41 PM #668
mteolus's Avatar
mteolus's Avatar
$110 too much for me even if I just had to have them black.
Old 10-16-2019, 05:46 PM #669
jafrush's Avatar
Real Name: Jacob
jafrush's Avatar
Real Name: Jacob
I didn't think about it when originally posting, but the standard hardware costs around $50 a rack I think, so it'd be about a $60 up-charge since you're not sending double hardware. Still too much?
Old 10-16-2019, 08:14 PM #670
sactown sactown is offline
sactown is on a distinguished road
Stainless still unavailable?
2017 TRD-OR w/ KDSS
sactown is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 10:14 PM #671
gdvan01's Avatar
Real Name: George
gdvan01's Avatar
Real Name: George
I don't mind the yellow/gold bolts myself...it's kinda like having gold crowns on my 2 front teefs.
RVA Toyota Trucks
Old 10-17-2019, 07:30 AM #672
jafrush's Avatar
Real Name: Jacob
jafrush's Avatar
Real Name: Jacob
We only found one supplier who said they could get them in stainless and in the right grade, and they never got back to us with the quote. :/
Old 10-17-2019, 08:20 AM #673
gdvan01's Avatar
Real Name: George
gdvan01's Avatar
Real Name: George
Fargin' Iceholes!
RVA Toyota Trucks
Old 10-17-2019, 10:26 AM #674
jafrush's Avatar
Real Name: Jacob
jafrush's Avatar
Real Name: Jacob
Another Dual Swing High Clearance rear bumper coming off the laser this morning. It is the first one in this latest batch, which are all already sold. Probably running another batch late next month.
Old 10-17-2019, 12:33 PM #675
That’s sad. Maybe try the search again sometime.
2017 TRD-OR w/ KDSS
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
