11-22-2019, 11:33 AM
#736
Originally Posted by 007Tacoma
Ugh... I wish... Daily Driver Problems. We put on average 35,000 to 40,000 miles a year. Can't go up in size without taking a huge chunk out of our budget. I am thinking about spacers to get a wider look. *shrug*
It's a slippery slope for sure but I think once you commit to a rear bumper you're basically on a full build whether you'd like to admit it or not. I just recently put a 4x4 Labs rear bumper on mine and MPG and daily driving aspect were impacted a lot. Was averaging about 17-18 MPG previously on 275's and now with the 4x4 Labs bumper I'm getting anywhere from 14-15 MPG, everything the same except the bumper. It just takes a little effort from the 4R to move all that weight hanging off the rear. The 4x4 Labs bumper is a freaking beast, not sure what it weighs exactly and I'm sure it weighs more than the LFD but it also requires cutting part of the rear cross-member so I don't think the added weight differential is all too different. I'm only running 32"s right now but likely going with a 34" and a re-gear will be necessary. I'll probably be averaging anywhere from 13-15 mpg when it's all said and done. I don't know, I feel like with certain upgrades and a rear bumper falls into that category that you're kind of past the point of the 4Runner being a reasonable daily driver. That being said even when it's built out fully it's still not too bad as a DD. You could spec and build out a LC200 and get 10-11 mpg
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
11-22-2019, 11:36 AM
#737
Originally Posted by LFD_Off_Road
Look at 255/75s next time you need new tires. Gives about another inch in diameter so the tires don't look quite as small, but MPG seems to be just as good.
Out of curiosity how much does the LFD bumper weigh?
11-22-2019, 11:40 AM
#738
official vendor
official vendor
About 230 before the accessories get added on. I average around 16 mpgs around town, 17-18 on the highway. Besides the 255/75s, I run the TRD cold air intakes also, not sure how much those help but I think they do make a difference.
11-22-2019, 12:01 PM
#739
Real Name: Mark the Common Sense Wizard
Hmmm... I may have to do that.
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
11-22-2019, 12:04 PM
#740
Yeah... it still has to be a daily driver. I think intake is next on the list of "things I should spend money on but am going to anyway".
11-22-2019, 04:17 PM
#741
Originally Posted by carlodonz
I got a set of Yakima Big Powerhound, not sure it will fit around...
You just need to source longer bolts for the grip pieces. I had my fat cats which have the same style feet as those on my Touareg that had factory crossbars which were about 1.5" thick and they worked.
Edit: I tested it out. Should be fine although I think there are better solutions.
First image is how the clamps would work with longer bolts.
Second images is the beginnings of me figuring out how to mount it directly to the rack with a Dremel and my sander.
I'm going to take it to RackAttack and see if they have any ideas.
Build thread
11-22-2019, 06:20 PM
#742
Just got 15% off an aluminum crossbar and 2 accessory mounting plates for Rotopax. Thanks LFD. Maybe front hybrid bumper next year.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
11-22-2019, 07:59 PM
#743
@ carlodonz
I just found these at Rack Attack
SmarT-Slot Kit 2
These work for the fat cat but you may find something similar for your racks.
Good luck
Build thread
11-23-2019, 01:49 AM
#744
Real Name: Carlo
Real Name: Carlo
Originally Posted by mscot
@ carlodonz
SmarT-Slot Kit 2
Good luck
that looks good, thank you for the info!
11-23-2019, 11:06 AM
#745
awaiting the rear spare and some other stuff
Sent from my SM-N970U using Tapatalk
11-23-2019, 11:27 AM
#746
I am shocked at how well the roof rack was packaged. Very professional.
A couple questions:
for those that have installed their rack. What kind of silicon did you use at the factory holes?
Is there a place I should be a able to find those sliding T-nuts locally? Amazon won't have them to me until mid-december to mid-january.
Build thread
11-23-2019, 11:56 AM
#747
I used black silicone permatex for the holes and on the bolts...
I've used these T-nuts with success; they aren't quite as perfectly fitting as the ones LFD includes with the accessory plates, but they get the job done and are in stock... I also use M8 allen-head bolts, similar to what is supplied with the accessory plates
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
11-23-2019, 11:57 AM
#748
Thank you
@ Anand
Do you know the size (width, I guess) of the slots on the crossbars?
Build thread
11-23-2019, 12:12 PM
#749
Thank you
@ Anand
I don't but I know that those M8 t-nuts wedge themselves in there to tighten pretty well
11-23-2019, 01:12 PM
#750
Looks sick. Be sure to post up pics when it's all kitted out
