06-10-2020, 01:07 PM
#1081
Real Name: Bird Dog Overland
The LFD Off Road Thread
Here is stock vs LFD 3/4 rack. The plastic cap ends on the stock units where the bolts are located are not usable for rails (red marks). The LFD 3/4 rack makes that space usable and adds maybe an inch or so in front between where the bolts mount and the edge of the sunroof. I’ve also attached a picture of my 60” hi-lift jack mounted on the rack to show that the previous post was correct in regards to 60” of mounting space (and with rear hatch up).
06-10-2020, 02:54 PM
#1082
Looks great, thanks for sharing. I'm getting ready to order my crossbars this week. Could you let me know what you used to mount your traction boards up there?
2020 ORP - Dobinson's 302/505, JBA UCAs, 5100s, Cooper AT3 Discoverer XLT 285/70/17
4Runners and Dobermans - https://www.instagram.com/derpydobies
06-10-2020, 11:07 PM
#1083
Real Name: Kelly
Real Name: Kelly
Thank you so much for sharing.
If you had to do it over again, would you still go with the 3/4 or go up to the 7/8?
Also, I think I got the same Amazon traction boards so I'd also like to know how you mounted them.
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
06-11-2020, 10:44 AM
#1084
official vendor
official vendor
Originally Posted by krhayes79
I have the same set up as the previous person with 4 cross bars on stock side rails. Looking to add more length since we can't mount the cross bars to the front or rear of the stock side rails.
So, you are saying the 3/4 rack adds about 18 inches of usable storage space? Would it also be wise to get a 5th cross bar at that point?
Lastly, any summer sales coming up I should wait for before ordering?
Thx a bunch for the info!!!
I haven't measured the stock side rails in a while, but yes that sounds about right for the space increase. We've had several people do 3/4s with just 4 crossbars. Depends entirely on what you're planning to use it for. You can always add more later
We'll probably do something for the 4th, but haven't discussed it yet.
06-11-2020, 11:35 AM
#1085
For the x-bull traction boards, I used a Stainless Steel 3/8' carriage bolts (5" long if you want to stack them on top of each other, 3" long if individual like I have them now) nuts, and washers from Home Depot. I also used rubber washers (off amazon) in between the bolt head/crossbar and between the SS washers/crossbars to prevent scratching/rust due to our strong winters here in Chicago. The aluminum bushings and knobs I got from McMaster.com at the recommendation from LFD (same knobs they supply with their hi lift mounts, see attached picture). DEFINITELY use anti-seize on the bolts to prevent galling and making them near impossible to remove if needed later.
06-11-2020, 03:23 PM
#1086
I have the stock rails and 5 crossbars. I have already installed a Hi-lift jack and 2 XBulls but I intend on installing Rotopax gas tanks, an awning, and maybe a shovel. It should all fit.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
06-11-2020, 03:32 PM
#1087
Currently using 4 bars for wind fairing, Xbulls (stacked), Hilift, Shovel, and 2 rotos. Took some work to get it all to fit. If I could do it all over again, I'd get 5 bars.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
06-11-2020, 04:27 PM
#1088
Originally Posted by SpeedyKevin
Currently using 4 bars for wind fairing, Xbulls (stacked), Hilift, Shovel, and 2 rotos. Think some work to get it all to fit. If I could do it all over again, I'd get 5 bars.
What size rotos? I was thinking about two 4 gallon ones stacked. That way I could either take 4 gallons or 8 gallons of gas. I guess you can get an extension if you stack two together so you can mount them?
06-11-2020, 04:58 PM
#1089
I can fit two 2 gallons (or 2 more with extensions). Could probably fit a 4 gallon
06-12-2020, 12:06 AM
#1090
Real Name: Kelly
Real Name: Kelly
Thx so much for the help! I'll keep an eye out for a sale! Gonna pick up the 3/4 side rails and possible a 5th cross bar.
Does the side rails come with the hardware to mount the cross bars? I noticed they mount to the LFD side rails differently than the OEM side rails.
06-12-2020, 02:52 PM
#1091
Real Name: Old man
Real Name: Old man
That's why I'll eventually end up with the 7/8.
2018 T4R TRD Pro Stock - RSG Sliders - Lock'er Down Console Safe - Yaesu 7900 - Cobra 75 - Garmin 55 Dash Cam - Gaia GPS - Garmin InReach Mini - Earthmate - Baja Designs Squad Sport Ditch Lights w/ Cali Raised Low Profile Ditch Light Brackets -Diode Dynamics SS3 Fog Light Kit - LFD Crossbars - BFG K2s - Warn VR EVO 10s - Warn Semi-Hidden Bumper
06-15-2020, 03:50 PM
#1092
official vendor
official vendor
Yeah, if you put in the comments when you order the new side rails how many crossbars you have we'll include new hardware for them.
06-15-2020, 09:58 PM
#1093
Real Name: Old man
Real Name: Old man
So, I have a project in the morning.
06-16-2020, 11:07 AM
#1094
Real Name: Old man
Real Name: Old man
Install went easy. Not sure if the vinyl wrap caused issues or the 1st bar drew the rails together but I had to spread the the rails just a tad to fit the 2nd bar. Also instead of taking the mounts off and all that mess I just bumped the t-nuts ever so slightly on the grinder to flatten them just enough to fit though the slots.
I freakin love the bars! looking forward to next months purchase!
06-16-2020, 06:23 PM
#1095
Real Name: Terry
Real Name: Terry
Wheeling AOAA in Pennsylvania
Went with a local Toyota group to Anthracite Outdoor Adventure Area in Pennsylvania - great venue. 100 miles of trails across 6500 acres. Best of all its old coal mine country so no VA/NC clay - you can actually wash it off. Lots of folks without skids, sliders or bumpers. I was a part time LFD salesman as people were checking out armor options. Hopefully you get some business @LFD and check out AOAA if you are an east coast person.
2016 SR5 - Wildpeak A/T3W 265/70R17SL or BFG K02 C Load 285/70R17; RSG Sliders; LFD Crossbars, Skid Plates & Hybrid Bumper; RCI Skids on Rear Diff, Lower Links & Shock Mounts; Engo SR10S Winch; Dobinson 700/701 IMS with 314/327 Coils +2.25" front +2.5" rear; Goat Armor; Redarc Brake Controller; Camping Hatch Mod; DIY Drawers & Sleeping Platform; Cheap 10" Light Bars in Grill; Front/Rear Camera Mod with Nav Input; Simple Nav/Comms - Garmin inReach Mini, iPad & Motorola FRS.
