08-31-2020, 11:01 AM
#1186
Originally Posted by LFD_Off_Road
Two of the short bolts go at the front of the engine skid, two of the middle length bolts got at the rear of the engine skid with the two spacers to fill in the frame divots, the four long bolts go at the rear of the transmission skid, and the two remaining short bolts go in the inside of the frame for the transfer case.
I'll send you a PM with the instructions
Would you mind PMing me instructions as well?
2017 SW SR5
09-01-2020, 12:53 PM
#1187
Everything went well, although for the transfer case skid I could not get it installed by sliding the front in first even with only 2 threads holding the transmission skid. What I did instead was completely remove the rear transmission skid bolts and let it hang then mounted the transfer case skid to the side rails first then it was just a matter of putting a jack under the transmission and transfer case skid bolt area to lift it flush and installing the 4 bolts.
The rustoleum big projects cans worked well, but I had to leave them to cure in a hot garage for a long time because the paint took so long to fully harden and cure. I painted them awhile ago but they still felt fairly soft after a couple days, so I just let them sit in the garage for a long time. I'll probably try krylon next time.
09-02-2020, 11:20 AM
#1188
Real Name: Mark the Common Sense Wizard
I still need to take mine off, sand them, and repaint them... It might be time to do a video on that.
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
09-02-2020, 01:22 PM
#1189
For the gas tank skid, should I install the brackets before the skid or attach them to the skid first? Particularly the passenger side bracket that gets attached kind of behind the drive shaft
09-02-2020, 02:14 PM
#1190
Real Name: Kelly
Real Name: Kelly
Originally Posted by 007Tacoma
Green Lane Ladder with my full length rack...
Can I please ask what high-lift jack mounts are you using to mount it on the side rails?
Thanks!
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
09-02-2020, 04:28 PM
#1191
Real Name: Ryan
Real Name: Ryan
Does the 7/8 rack interfere with the tilt function of the sunroof?
I haven't been able to find a clear answer.
09-02-2020, 04:34 PM
#1192
Real Name: Kelly
Real Name: Kelly
Just placed my order for the 7/8 side rails, 2 additional crossbars (+1 crossbar/fairing that is included in the purchase) and the high-lift mount!!!
Have a long road trip planned starting 9/26. Praying to the LFD Gods my order gets here before then.
Excited either way!!! Thank you LFD!!!
09-02-2020, 04:35 PM
#1193
official vendor
official vendor
We're heading out to Appalachian Toyota Roundup tomorrow, hope to see some of you there!
When it ends Sunday we're heading West for the week instead of heading home. We'll still have people in the office, but they're not the usual staff answering messages and such, so there may be a delay in getting some things answered. We'll be back to full staff Monday the 14th.
09-02-2020, 04:36 PM
#1194
The answer is no, it will not interfere.
Mark with Trail or Sail Prod. has a short review of it in the link below.
https://www.youtube.com/watch?v=RHFPjg_Zda0&feature=youtu.be&t=150
#1195
official vendor
official vendor
Haha I literally just sent you a reply email a few minutes ago, after I hit send and my inbox updated I saw your order notification come through. Thanks
09-02-2020, 04:37 PM
#1196
Real Name: Kelly
Real Name: Kelly
Where in the West? Heading to Cali?
09-02-2020, 05:29 PM
#1197
The new style of ruggedized crossbar is $50 more per bar than the old style. Is the only difference the slots cut into them? Seem's lot just for that difference. Or is it the slots and stainless steel? Or am I missing something.
09-02-2020, 07:02 PM
#1198
You are missing something, they offer stainless, steel, and aluminum. 5th Gen crossbars are $79 in steel and $129 in stainless. The ones in stainless say it right in the title so do the aluminum ones.
2018 TRD ORP - Dobinsons IMS 3/2 lift, BFG KO2 285/70/17, LFD 7/8 roof rack, LFD Steel Skid, LFD Bump Out Sliders, TRD intake, Rago Molle Panels, Ellis Precision Shift knobs
09-02-2020, 09:07 PM
#1199
Yep totally missed the line "Now shipping "New style" 5th Gen Crossbars with mounting slots for easier accessory mounting!" in the just regular steel ones for $79. Thanks for setting me straight.
09-03-2020, 12:52 AM
#1200
Real Name: Ryan
Real Name: Ryan
Originally Posted by GCT4R
Thanks! Definitely makes ordering more compelling.
