LFD_Off_Road
Old 11-27-2020, 05:34 PM #1291
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
Finally made my first LFD purchase, crossbars set with fairing. If anyone has some installation tip please let me know! It should be quite straightforward from what I can tell.
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 05:38 PM #1292
krhayes79's Avatar
krhayes79 krhayes79 is offline
Real Name: Kelly
krhayes79 has a spectacular aura about krhayes79 has a spectacular aura about
krhayes79's Avatar
Real Name: Kelly
Just put a blanket down to rest the crossbars on when installing each side so you dont scratch or ding the paint on your roof. Other than that, it is super simple.
If you have OEM cross bars, here is a vid to help remove them cause they are kind of a pain.
https://www.youtube.com/watch?v=xYDTwXjSzUA&t=276s
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
krhayes79 is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 06:42 PM #1293
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Do you think it is worth upgrading to the wide bars? It would save on buying the plate to mount RotoPax’s and if I ever went with a RTT the loading would be better. Do you think there are any other pros or cons to the wider bars besides weight? TIA
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 07:44 PM #1294
krhayes79's Avatar
Real Name: Kelly
krhayes79's Avatar
Real Name: Kelly
Looking at the mounting plate and it seems there are multiple options to mount the plate to the crossbars. It does seem to work with 2 bolts so I would say you wouldnt need the wide crossbars but I would imagine it would help be a bit more stable if you did the wide crossbar.
Only other benefit i see is the ability to have more mounting options at different lengths. I have had to move my bars quite a bit to make sure I can mount longer items (traction boards & plano case). The measurements have to be perfect for them to fit so the wider crossbars could help with more than one item but slightly different lengths.
Hope that helps!
Old 11-28-2020, 02:40 AM #1295
vdog2000002 vdog2000002 is offline
vdog2000002 is on a distinguished road
I got two of the 2" bars and two of the 4" bars. I set them 12 3/4" apart. They are 15% off for the black Friday sale.
vdog2000002 is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 03:04 AM #1296
If you got the fairing that is sold separate from the bars (not the new bar with the integrated fairing) then DON'T try to mount the fairing to the bar before you install it on the truck. If you mount the fairing first you won't be able to install the front mounting nut and bolt. The fairing blocks access to the front of the bar. This means that you will need to remove the fairing each time you move the bar, so put it whare you want it to stay (I put mine all the way forward). If you need to adjust the bars for your cargo needs move only the rear bar. I also put double sided tape on the fairing mounting tabs to prevent direct contact of the two powder coated surfaces (bar and fairing). Use a utility knife to cut a + in the tape to push the bolt through.
Old 11-28-2020, 03:04 AM #1297
Hope that helps!
Well, I decided to buy four wide bars and the fairing. $399.96 including shipping to California. I decided to go this route as the mounting plates were $45 each for the Rotopax or other accessories and I would have bought two, which would have cost me close to $100 extra.
Also, I like the extra footprint, mounting locations and load carrying capacity, and for $100 more than the standard bar bundle I felt it was worth it. Thanks
Old 11-28-2020, 07:32 AM #1298
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
A set of metric L-shaped Allen wrenches with a ball end will speed it up a bit. You only need one of them (4mm?). A long flat blade screwdriver is sometimes helpful to keep the t-nut from turning as you tighten them down.
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 10:37 AM #1299
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Anyone getting a resonance or slight "rattle " with the wide crossbars? I'm running two. Getting a vibration/resonance coming form some place and its driving me crazy. Normally above 30mph and not exactly constant. Goes away when i open the sunroof, but will come back while driving slow and hitting road seams "old concrete roads". Getting ready to pull interior panels and roof rack.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 11:26 AM #1300
Did you get a fairing? The fairing is supposed to help with the wind buffering / vibration when the rack is unloaded. I installed the fairing when I installed the bars and never had any noise or vibrations. I would check your hardware to make sure that everything is still tight.
Old 11-28-2020, 11:59 AM #1301
Charlievee's Avatar
Charlievee's Avatar
No. Faring was in redesign at the time. All the hardware has been checked and dbl checked. Guess my next step is to remove them to make sure they are the issue.
Old 11-28-2020, 01:21 PM #1302
salsanacho salsanacho is offline
salsanacho will become famous soon enough
I ended up doing a mix of bars... bought the integrated fairing crossbar, 2 wide ones, and 1 regular one. the 15% off pretty much just paid for shipping.
salsanacho is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 03:47 PM #1303
From every member running the LFD crossbars the fairing was the key to omit wind noise and turbulence. Also, the aluminum bars, as members and LFD have stated, seem to make more noise unloaded than steel.
Old 11-29-2020, 09:16 PM #1304
From reading on the LFD website the fairing is mostly needed on the aluminum crossbars. I got the stainless steel 2" bars and the fairing to make sure that it would not make any unusual sounds. Maby the fairing will help.
Old 11-29-2020, 09:47 PM #1305
I forgot to mention one of the most versatile tools in my tool box. I call it the "stickum". It is a 8" piece if garden irrigation tube with duct tape wound a few times normally then flipped and wound with the sticky side outward. This will help you install the fairing. The "stickum" will hold the nut while you thread the bolt. When you try to install the nut and bolts in the center of the fairing it is difficult to hold the nut stable. Put the nut on the "stickum" and a put it under the bar aligned with the hole. Then thread your bolt from the top. It is so easy with the "stickum". I hope that this helps.
The LFD Off Road Thread-20201129_194609-jpg
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
