LFD_Off_Road
Old 11-30-2020, 07:48 PM #1306
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
lol thanks, I'm not following but maybe it will be more clear once I get my hands on the hardware!
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 08:17 PM #1307
LFD_Off_Road's Avatar
LFD_Off_Road LFD_Off_Road is offline
official vendor
LFD_Off_Road has a spectacular aura about LFD_Off_Road has a spectacular aura about
official vendor
Originally Posted by Charlievee View Post
No. Faring was in redesign at the time. All the hardware has been checked and dbl checked. Guess my next step is to remove them to make sure they are the issue.
It probably is the crossbars, especially if they're empty. You can try moving the first one farther back and play with the positioning, which can help sometimes. There's lots of variables involved in noise/resonance: position of the crossbar, vehicle rake, load on the crossbars, etc.
The only sure way to prevent it is a fairing. If you need one send me a PM and we'll help out.
LFD_Off_Road is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 08:17 PM #1308
krhayes79's Avatar
krhayes79 krhayes79 is offline
Real Name: Kelly
krhayes79 has a spectacular aura about krhayes79 has a spectacular aura about
krhayes79's Avatar
Real Name: Kelly
You will see once you try installing. It is kind of a PIA to get those underneath T bolts held in place with your hand!
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
krhayes79 is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 08:22 PM #1309
official vendor
official vendor
Reach out if you have questions! Its usually pretty straightforward. T nuts can be challenging, but there's a few tricks too. A lot of times you can assemble the T nut and bolt and drop it through the slot on the fairing, rotate 90 degrees, then drop it through the slot on the crossbar and then just tighten.
Old 11-30-2020, 08:32 PM #1310
krhayes79's Avatar
Real Name: Kelly
krhayes79's Avatar
Real Name: Kelly
HAHA! Wow, why did I not think of this when installing!!! Hardest part was just getting that thread started!
Old 11-30-2020, 11:38 PM #1311
vdog2000002 vdog2000002 is offline
vdog2000002 is on a distinguished road
I only used it for installing the two center nuts and bolts of the fairing. They can be difficult to install because of the distance from the side of the truck and the angle of reaching under the cross bar while balancing the nut on your fingertips. I stuck the nut on the tape, aligned it with the hole, and threaded the bolt from the top. It makes it easier to get the bolt started in the nut. Once the bolt is started you can reach with your fingers to keep the nut from spinning as you tighten it up.
vdog2000002 is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 06:07 PM #1312
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
Anyone getting a resonance or slight "rattle " with the wide crossbars? I'm running two. Getting a vibration/resonance coming form some place and its driving me crazy. Normally above 30mph and not exactly constant. Goes away when i open the sunroof, but will come back while driving slow and hitting road seams "old concrete roads". Getting ready to pull interior panels and roof rack.
I noticed some vibration / rattle at 80 / 85 mph on my steel crossbars with fairing. Don't notice it at lower speeds. Probably just need to check the tightness of the hardware.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 02:52 PM #1313
krhayes79's Avatar
Real Name: Kelly
krhayes79's Avatar
Real Name: Kelly
Should I be able to mount a crossbar in one mounting hole in the side rails (see red square in pic)? Currently, the carriage bolts just barely do not fit. They go in but the square part of the bolt makes the bolt slightly pop out and not sit flush. I could get non-carriage bolts and it would fit, but if there is a structural or safety reason for not being able to use one hole, I would not want to do that. Moreover, the bolts provided should fit.
The LFD Off Road Thread-side-rails-jpg
Old 12-14-2020, 04:45 PM #1314
BR4R87 BR4R87 is offline
BR4R87 is on a distinguished road
@LFD I purchased two aluminum cross bars a few months back and get noise at 70+ mph unloaded. I have a fairing on the front, but not the rear. Any help would be appreciated!
BR4R87 is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 06:25 PM #1315
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
If the second one is way back from the front the air could be dirty again by then. Move it up some.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 12-15-2020, 11:52 AM #1316
DaltonJ DaltonJ is offline
DaltonJ is on a distinguished road
Anyone have any experience with the minimalist roof rack? I just ordered mine and haven’t seen a ton of reviews. Love to hear some opinions/issues/etc
DaltonJ is offline   Reply With QuoteReply With Quote
Old 12-19-2020, 02:18 PM #1317
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
Can someone get a measurement from the roof to the top of the LFD crossbars please? I have LFD crossbars on my OEM rack now and I am looking at getting LFD siderails, but I don't want to lose any more overhead clearance if possible.
Thanks!
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 07:08 AM #1318
Neither is wide like the bar you have shown. You could buy another wide bar and add the fairing to it if you want the same width.
Old 12-20-2020, 09:52 AM #1319
Finslayer83 Finslayer83 is offline
Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough
I've got one sitting in the garage, need to get it on today.
Also my LFD bumper should be in queue here soon.
Finslayer83 is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 09:59 AM #1320
Anand Anand is offline
Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough Anand is a jewel in the rough
Which one did you go with?
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
Anand is offline   Reply With QuoteReply With Quote
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
