01-26-2021, 05:09 PM
#1366
Real Name: Carlo
Real Name: Carlo
Originally Posted by krhayes79
Mounting diagonally will make your rotopax sit diagonally as well. Ask me how I know LOL
I would assume you could go without the plate, I just do not know how sturdy it would be with only two bolts. Also, the Rotopax would rub in the crossbars and may rattle and cause wear on the outside of the Rotopax where it is touching the crossbar.
Good point, I haven't thought about that!
01-26-2021, 06:19 PM
#1367
Should be fine mounted directly to the crossbar with only two bolts. Note that the mount is installed to the plate with only two bolts, so at some point they determined two bolts was good enough. The 4 bolts used from the plate to the crossbar is actually overkill from that point of view.
01-26-2021, 06:28 PM
#1368
Real Name: Kelly
Real Name: Kelly
I think another use for the plate is to allow multiple ways to mount the Rotopax. Without the plate, and normal cross bars, you can only mount the Rotopax in the vertical position.
I am sure two bolts is enough for the smaller 1gal or 2gal Rotopax, but for me, I did not feel safe with the 4gal and only 2 bolts holding he mounts onto the crossbars.
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
01-26-2021, 07:35 PM
#1370
official vendor
official vendor
Originally Posted by mbumpus11
The 10-13 trail side rails vary in width from front to back, so the crossbar has to be adjustable to accommodate that variation.
We could take the front position and get that set distance, but I don't have a set installed any more to do that, and I'd worry about fitment; it'd have to be in the correct spot each time or it won't work. 10-13 crossbars have been a pretty low take rate overall too... not sure there are enough out there to justify another part right now.
01-29-2021, 04:55 PM
#1371
Frontrunner propane tank holder on LFD crossbars?
Hello!
Has anyone mounted a frontrunner propane tank holder on their LFD crossbars? I currently have four steel crossbars (and a fairing on the front bar) mounted on OEM side rails. I've also got some Scepter jerry cans on the way: anyone mounted those on the crossbars?
Thanks!
01-29-2021, 05:11 PM
#1372
Real Name: Carlo
Real Name: Carlo
Originally Posted by carlodonz
So I was looking at the actual rotopax mount:
I was wondering if it's possible to mount just the mount itself (top left in the picture above) without the round base.
Or maybe mount the round base diagonally?
Quick follow up on this, I was looking at the rotopax website and found this in the mount page:
Use with included base plate or remove plate to attach mount direct by bolting up through the bottom or down through the top.
So both should be safe.
01-31-2021, 02:50 AM
#1373
Originally Posted by DaltonJ
This is the minimalist roof rack. I love the look and I’m hoping I might see a little better mpg with the weird basket rack off my truck. Hopeful to pull the trigger on an rtt in the spring.
This looks interesting and I like how minimalistic this rack is. By any chance do you have any more pictures of this rack?
-3" Dobinson Lift Kit along w/ SPC UCAs
-285/70/17 Cooper Evolution MT w/ ProComp Predator 35 Wheels
-Diode Dynamics SS3 Fogs and 30" Stage Series Light Bar
-TRD Front Skid, RSG Angled Sliders, Pelfreybilt Front Bumper
-Alpha Fox Trot Design Roof Rack & ladder.
02-01-2021, 05:29 PM
#1374
Well I finally got my LFD Hybrid bumper and winch installed. It was a beating, mainly because I decided to mount my control box up by the airbox as someone on YouTube suggested. I had to buy some new longer cables and do some wiring inside the control box. Somehow I did it right and am happy with the configuration although I guess I won't be buying a second battery anytime soon. :-)
So the questions are, where are people mounting the front license plate?
The hook I got on the Ironman winch isn't big enough to fit around the D-links I have. Is Factor 55 Pro and Flatlink what most people use or is there a cheaper option that still is good quality?
Lastly, I noticed on some other hybrid bumpers there was some flat steel that attached to each side of the bumper where you could then stabilize the factory plastic bumper on each side which the LFD bumper doesn't have. Anybody have any issues with the plastic stock bumper flapping around at all?
All in all though, I love it. Just what I wanted, spool and clutch access.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
02-01-2021, 06:56 PM
#1375
Real Name: Terry
Real Name: Terry
Congrats on your purchase.
I went with the Rough Country Winch License Plate Bracket Kit | Hawse Fairlead | RS138. You can get it on Amazon for $20. It works great but hangs a bit low. If I leave the plate on it gets bent flat in the rocks. So I used wing nuts and usually remember to take the plate off when I hook up the winch controller. You can see it sticking out of the hawse below.
I wanted a factor 55 thimble or something like that, but they cost way too much so I stuck with the hook that was included. It latches and fits on my shackle.
I know what you mean about the "flappy" bumper ends. I thought about some simple strap to tie those in, but never did. I've had the bumper over a year and haven't had any issues. And yes, I've run the bumper into water, mud, a tree, ...
2016 SR5 - Wildpeak A/T3W 265/70R17SL or BFG K02 C Load 285/70R17; RSG Sliders; LFD Crossbars, Skid Plates & Hybrid Bumper; RCI Skids on Rear Diff, Lower Links & Shock Mounts; Engo SR10S Winch; Dobinson 700/701 IMS with 314/327 Coils +2.25" front +2.5" rear; Goat Armor; Redarc Brake Controller; Camping Hatch Mod; DIY Drawers & Sleeping Platform; Cheap 10" Light Bars in Grill; Front/Rear Camera Mod with Nav Input; Simple Nav/Comms - Garmin inReach Mini, iPad & Motorola FRS.
02-01-2021, 10:16 PM
#1376
Cool on the license plate holder. I was barely able to get the fairlead on as the bolt was barely long enough to fit the flat washer and lock washer on. Maybe the lock washer will be smashed down a bit so I can fit the license plate holder on it. If not I'll have to get rid of the lock washer and hope it stays on.
Good to know about the floppy bumper. There is one place where I can put a zip tie from the bumper to a hook (I think the tie down hook) but I may just leave it and see what happens.
02-02-2021, 08:18 AM
#1377
Take the bolt over to your local small family owned hardware store and get the next sized longer one. I had to do that with my Warn Winch & Bumper.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
02-02-2021, 08:28 AM
#1378
The bolt-on LFD Wind Fairing on my Ruggedized front Crossbar is driving me nuts. I'm going to unbolt it and trash can it. I note LFD no longer sells it.
Haven't looked but hoping it didn't leave a dent in my roof from vibrating in the wind. Where I only noticed it at 85mph, it's now doing it at 55mph in a cross wind.
02-02-2021, 08:42 AM
#1379
Real Name: Terry
Real Name: Terry
It comes with longer bolts - M12-1.75 x 35mm - and you reuse the nut and washers from the winch kit.
02-02-2021, 09:09 AM
#1380
Real Name: Terry
Real Name: Terry
That's odd - mine works great and I routinely drive 80mph.
They still sell them - in accessories brackets and mounts.
Which one do you have?
Not 100% sure which one I have - I got it in person at an event.
Mine has 4 bolts (similar to the 2010-2013 model on their site).
No flex but the bolts can be in the way depending on how I lay things out.
I suspect they've tweaked the design over time to address different issues.
2 bolts opens up space (maybe some flex?).
And the final/best design is the integrated.
