02-24-2021, 12:24 PM
#1426
Originally Posted by LFD_Off_Road
We haven't looked into a window panel yet because out here on the tight east coast trails we run, that's just asking for a broken window or damage.
@ Anand
knows what Im talking about ;)
I'll add it to the list of things to look at though
Makes sense, our trails don't seem to be as tight here. The main selling point for me would be that I could store trax boards/rotopax on the sides when upgrading from the cross bar package to a 7/8 rack. Sure I could go full, but that would require entirely new cross bars and that defeats the purpose of scaling the crossbars up to the larger rack. Just a thought!
02-24-2021, 01:23 PM
#1427
Originally Posted by carlodonz
I’m thinking to mount an awning to the LFD crossbar.
I found some that match the length of the stock rails but I’m afraid they won’t provide much shade.
I’m thinking to upsize to a 6-6.5’ ft length one.
Not a fan of the overhang at the front but my concern is mainly how stable and secure it will be give the front part won’t have any mounting point.
Does anyone have photo of a similar setup and can provide feedback? Thanks
I have the Ironman 2.5m awning on stock rails with LFD crossbars. No issues, other than a slight bounce on rough 4x4 roads. Never caused any problems though. The quick release brackets are amazing, takes 15 seconds to take it off and store it in the garage.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
02-25-2021, 02:04 PM
#1428
Real Name: Carlo
Real Name: Carlo
Thanks for the feedback, can you post some pictures of the brackets and how did you mount them to the crossbars?
02-25-2021, 04:05 PM
#1429
The one thing I had to do is to make the two holes I used for the L bracket that came with the awning bigger (to fit the LFD hardware). I think it was 5/16 if I remember right. Steel was hard so it took a while to make the hole bigger. I mounted it with the outermost 2 holes so that the awning was out as far as possible. The awning then just sits on top. The back is secured by a Brinks lock I got at Wal Mart and the front is secured with what came with the quick release awning, a pin. You can put a second quick release bracket on the passenger side if you want and it is easy to move from driver to passenger, but the awning will stick out in the back (because of the 3/4 roof rack). To solve that you would have to add a 3rd quick release on the awning itself (not on the mounting brackets, just the awning). I plan on doing that but I haven't yet. I still don't know if it would work or not. I may have to put 2 quick releases on the awning as I doubt the middle one is exactly half way.
I also have the tent that goes with the awning. It is pretty cool, but heavy and bulky. I have used it and put an XL cot inside and fit perfectly.
02-25-2021, 08:31 PM
#1430
Real Name: Carlo
Real Name: Carlo
Thank you that helps a lot. I'm personally still undecided between 4' and 6' awning, how often do you actually use it?
02-26-2021, 02:16 AM
#1431
I would think a 4' awning would be pretty dang small. Wouldn't be too good unless the sun was above you. I haven't used it a whole lot but I just put it on this summer. I will probably use it more often this year. I like the light strip it has too, great for sitting under at night. Once I get the passenger side set up I won't have to move around as much to avoid the sun. I think it was worth the price for the awning. Not sure about the tent yet.
02-28-2021, 06:20 PM
#1432
Great company and people
03-04-2021, 05:51 PM
#1433
@ Anand
Any discount code for the forum member that we can use? Thanks
03-10-2021, 08:59 PM
#1434
Do you worry about the HiLift rusting and staining the paint. It did on my xterra.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
03-12-2021, 11:22 AM
#1435
Has anyone painted their rack/crossbar hardware? If so can you recommend what products you used?
03-12-2021, 12:16 PM
#1436
my Hilift is a little rusty, but the mounts are easy to use so I just remove it when I'm not offroading
03-13-2021, 10:44 AM
#1437
Thumbs up!
4 LFD bars and wind fairing, great product, looks pretty close to stock and no wind noise. Easy install.Great option for carrying stuff on the roof!
03-20-2021, 04:40 PM
#1438
Originally Posted by DaveSki
Got a great deal on these LFD crossbars. Was able to mount the traction boards using carriage bolts and plastic knobs for easy removal. I noticed the LFD website doesn’t offer full length rails, any idea of this will be a future option?
How's the wind noise on your setup?
It looks like you 2 crossbars + 1 integrated crossbar set up correct?
Thanks!
03-20-2021, 05:21 PM
#1439
Thanks!
I have the same setup. I am planning on adding a 4gallon rotorax and some traction boards. The wind fare sounded like it was coming through the roof though.
The Build
03-21-2021, 12:18 AM
#1440
Banned
Banned
Just update on my LFD full roof rack, it was rusting pretty bad after roughly a year (steel version), so I contacted them and they sent me out two aluminum side rails no cost. I noticed that all their roof racks say “rust free” in the description which I thought was odd. They definitely had a horrible batch from powder coating as all my cross bars are completely rusted and chipping powder coat, i might just scrap the entire rack and just get their overland crossbars as i have a roofnest falcon installed, and Roam awning.
