03-23-2021, 03:04 AM
#1456
Originally Posted by LFD_Off_Road
I don't know if it would. Never tried it as far as I know.
What are the dimensions of the mounting plate? I could not find that information on your website.
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
03-23-2021, 03:05 AM
#1457
Originally Posted by Anand
You may want to wait for an official answer (if they have one, I can't say I know of anyone using a 450C for OBA). I have a 450P automatic that I used on the 4Runner, but it lived in a bag, not under the hood.
Just looking at the dimensions...
Viair 450C
10.5"L x 3.94"W x 6.87"H
ARB Single (CKMA12)
7.5"L x 3.9"W x 5.7"H
The Viair's mounting pattern is 8.375" x 3.31"
The ARB's mounting pattern is 2.76" x 2.2"
Based on their photos, you would need to create some sort of adapter bracket to bolt the Viair to, and then bolt that to the mount. It looks like there may be another 3" in the longitudinal orientation, and there may also be enough if you mount it transversely, but again you would still need the interfacing bracket. Depending on how you do the adapter, the extra 1.17" in height may start to become a factor with hood clearance
Thank you for the info; that helps somewhat. If the plate is big enough I would just drill new holes.
03-23-2021, 03:06 AM
#1458
Originally Posted by 007Tacoma
The plate is pretty easy to work with. I managed to fit my old Viair 300P on it. I am currently looking at the possibility of mounting this under one of the bumper covers.
Based on this, it appears a 450 might be too large for this compressor plate. Also, where did you find that rubber cover for the male air hose connection?
03-23-2021, 09:49 AM
#1459
official vendor
official vendor
Originally Posted by krhayes79
We've got four completely redesigned ones going through welding this week, and then next week one of our employees is heading out to Moab with it installed for vacation. We'll see how it does on his trip.
03-23-2021, 09:53 AM
#1460
official vendor
official vendor
The mounting plate itself is 11.4" by 4.1".
03-23-2021, 01:01 PM
#1461
Real Name: Kelly
Real Name: Kelly
If you need help testing, i would be happy to be a guinea pig!!!
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
03-24-2021, 02:22 PM
#1462
Real Name: Mark the Common Sense Wizard
that cover came with my 300 as it was originally a portable version with the handle. I removed the handle when I modified it.
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
03-24-2021, 03:38 PM
#1463
Does the 3/4 require drilling and or silicone to install?
Interested while I still have my stimulus money haha
03-24-2021, 04:02 PM
#1464
Real Name: Kelly
Real Name: Kelly
no drilling, yes silicone to make the mounting points water proof!
03-24-2021, 04:52 PM
#1465
butyl tape should do the job right?
03-24-2021, 08:19 PM
#1466
Hmm mine is originally a portable too. I’ll have to look around in the bag for one then. Thanks!
03-24-2021, 08:43 PM
#1467
I offered also the only thing that I have that isn't made by them are my sliders and I bought those to help a small business in the NE where I am from.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
03-29-2021, 01:58 PM
#1468
So my 450p appears to have not come with that little rubber cover for the male end BUT I found that a normal schrader valve cap fits snugly over the end. I'm pretty sure a rubber 5/16" vacuum cap would fit over it perfectly as well. I was able to fit a 1/4" one by expanding it a bit and I fit a 3/8" one by pushing it further over the collar on the male connector.
03-29-2021, 02:00 PM
#1469
Also, I purchased the LFD air compressor mount and plan to try to fit the 450 on it. Based on the dimensions of the plate and the 450 mount points I think it will fit...barely. I plan to drill new holes if needed (probably). I will let everyone here know how it goes!
04-03-2021, 09:25 PM
#1470
I have a question about the rear bumper. What are the 2 little cut outs for that are near the shackle mounts, are they for lights? If so what size?
The Build
