04-03-2021, 09:34 PM
#1471
Originally Posted by Signal
I have a question about the rear bumper. What are the 2 little cut outs for that are near the shackle mounts, are they for lights? If so what size?
Cutouts for Hi-Lift jacks.
04-03-2021, 11:55 PM
#1472
Huh. That didn't even cross my mind, all I was thinking is man, those are going to be small lights.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
04-04-2021, 08:34 PM
#1473
Function, function, function, that is what I have figured to be the purpose of the bumper
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
04-05-2021, 08:14 AM
#1474
Real Name: Mark the Common Sense Wizard
...and they work really well when you are needing to lift the rear in a tight spot.
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
04-05-2021, 11:07 PM
#1475
Real Name: Neil
Real Name: Neil
Curved Fairing Vibration
Originally Posted by LFD_Off_Road
Some vehicles we've seen a need for double sided 3M tape under the front feet on the rack. We've also seen a few bad welds crack on fairings every once in a while.
If you send us a Pm we can try to work through and help troubleshoot.
I just completed a 2000 mile round trip between CA and CO on 80 mph highways and was limited to 75 or less, depending on the wind speed, because of the same vibration issue with the curved fairing. I have a feeling that it's the gap between the bottom of the fairing and the roof that's creating an airflow/harmonics issue. The vibration actually went away when i opened my sunroof--either fully opened or tilted up the back--so changing the airflow would fix the problem.
It was really frustrating that I had to slow down far enough for semi trucks to pass me in order to not have the rack vibrate itself off of the roof. In the first 100 miles I hit 85 mph on a down hill and it sounded like it was vibrating metal on metal against the roof, but fortunately there was no damage so that wasn't the case.
I'll PM you on FB. I definitely need to find a solution!
04-05-2021, 11:33 PM
#1476
Real Name: Neil
Real Name: Neil
Originally Posted by HeelsFan72
Has anyone else had problems with the new curved front wind faring (XLFOR017-7) vibrating on their full length racks? Got mine on and every time I get above ~70 MPH, my wind faring vibrates CRAZY hard. It is so bad I thought I put a wheel out of alignment or a tire out of balance. Shakes the whole 4R
Yes! I just finished a 2000 mile trip where I couldn't go the speed limit on 75-80 mph freeways because of this issue. I didn't have the front feet on, so I'm sure that exacerbated the vibration, but it's an aerodynamics issue, not a structural issue. I think that closing the gap between the fairing and the roof may solve the problem. When I opened my sunroof and disrupted the airflow the vibrtation would all but disappear.
I saw that
@ YellowSnow
added a Prinsu style fairing to close the gap, which solved his wind noise problem, but he didn't mention the vibration issue.
04-05-2021, 11:36 PM
#1477
Real Name: Neil
Real Name: Neil
Originally Posted by YellowSnow
My guess is LFD had a bad batch of powder coat and/or had to change who they were using. That’s why they were quick to send me the aluminum replacements no charge, and also why they now state “rust free” on all their racks...seems redundant to have to specify rust free, unless there was issues previously.
On another note, I switched over to their curved wind fairing and noticed awful wind noise even at low speeds, so i added the Prinsu style rubber door seal off Amazon and it was minimized drastically. It also seals the fairing against the roof and all but erases the gap.
Could you send a link to the Prinsu style seal that you ordered? I have a horrible vibration issue that starts between 75-80 mph with my curved fairing and I'd like to see if closing the gap will fix it. Did you have a vibration issue at high speeds, too, or just noise?
04-06-2021, 09:07 AM
#1478
official vendor
official vendor
What's weird about these is that we've run these for more than a year with many, many different vehicles in our fleet and not had that issue. One of our employees just did a 4,500 mile trip last week with his out to Moab and back, and we did a similar trip last year to CO too.
We are experimenting with a few different edge trims with seals right now, should have some available to send out this week if anyone wants to try one.
04-06-2021, 09:57 AM
#1479
I'm curious about the rake angle of the vehicles with vibrations vs without
if you are having vibrations, what kind of front and rear lift are you running, what's your rake angle?
04-06-2021, 10:06 AM
#1480
Mega thanks to LFD for sending me a replacement Integrated Wind Fairing Crossbar, free of charge. It's awesome to see a company that listens to customers!
LFD Off Road - Integrated Wind Fairing Crossbar
No vibrations / jack hammering out of this one.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
04-06-2021, 10:50 AM
#1481
Word of advice: put the "weatherstripping" on before you install the wind fairing. It's a massive PITA to do afterwards.
04-06-2021, 02:59 PM
#1482
official vendor
official vendor
Little follow up, did a fresh install of a full rack this morning on Salsa for some testing.
I think some of the issues may be not enough pressure with the front feet. We lift the front corner of the side rail when installing the front foot, you can get a little bit of flex up doing so (helps to have someone else help with that step!) That way when you let go the foot is pushing down against the rubber gutter cover with some good pressure. Without doing this, when you grabbed the front crossbar I could get some side to side flex in the rack. After adjusting them with pressure that side to side flex went away and turned into all vehicle rocking motion, no rack flex.
Also tried a second highway run with some of the bulbed edge trim we're playing with. It did make a difference in wind noise. We're expecting a big roll of it in probably sometime next week, once it arrives and we confirm it fits well if anyone with a full wants some send us an email/IM/ with your address and we'll send it your way.
04-06-2021, 08:42 PM
#1483
Has anyone added a folding table to the rear bumper? I have no clue how much space is needed but it would be nice to bolt one on.
The Build
04-07-2021, 05:52 AM
#1484
Real Name: BLACK TRD PRO
Added 4 wide LFD crossbars and fairing to my rig. Will be getting my hi lift mounts from LFD this week. Adding a double rifle case, hi lift jack, traction boards and a Rotopax. Nice clean design that you don’t have to remove rails and end caps or worry about leaks with the OEM rail and cap setup. This setup would work great with a cargo box and extras or a RTT.
04-07-2021, 09:21 AM
#1485
Orangeboxx Fab sells this one specifically for the LFD Bumper
