LFD_Off_Road
Old 06-15-2019, 08:41 PM #376
jafrush's Avatar
jafrush jafrush is offline
Real Name: Jacob
jafrush is a jewel in the rough jafrush is a jewel in the rough jafrush is a jewel in the rough
jafrush's Avatar
Real Name: Jacob
Originally Posted by Jay's T4R View Post
Full Rack:
I tried to apply pressure to the front leg when bolting it in and I'm still having issues with wind noise at low speeds. Tried re-shifting some of the bars but no luck. Starting to wonder if I went wrong somewhere in the installation process?
Ok, a few things to look at/try real quick.
First, give each crossbar a knock, and make sure one isn't loose. I've missed tightening a bolt before, and it made some noise. The crossbar with the loose bolt made an obvious noise difference when knocking on it.
Second, if they're all tight, we should have sent some rubber tape with the hardware. See if the front feet are touching metal on the roof anywhere, and if so use some of that rubber tape on the bottom of the foot where yous see contact. If you ran out of the tape or discarded it, we can send you more.
Lastly, I don't remember which rack you got, but if it's an all aluminum one with no steel crossbars at all, adding a couple steel crossbars may stiffen it up and take out any excess movement if it is an all aluminum. We can send you a few to swap out and try if so.
Im out of the office for the next 10 days at the trade show for the parent company, but I can have someone in the office send stuff if you need.
jafrush is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 09:26 PM #377
TCstang's Avatar
TCstang TCstang is offline
TCstang is on a distinguished road
TCstang's Avatar
I have 4 crossbars on the stock roof rails. The wind noise between 45-55 is excessive. So I ordered the wind deflector. It took a bit of adjustment to keep the wind deflector from vibrating against the roof on the highway, but I finally got everything working good and successfully made it from Dallas, TX to Moab and back with out issue.
Unfortunately about a week after I returned the wind deflector started vibrating against my roof again. I ensured the deflector and crossbar were fully tightened down but it made no difference. At this point I’ve taken everything off and will only mount the cross bars up when on a trip.
TCstang is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 11:55 AM #378
Florunner78 Florunner78 is offline
Florunner78 is on a distinguished road
I've noticed mine is hit or miss, too. Some trips there is very little noise/vibration but then on the next trip it's really, really bad. Still playing with the position of the front cross bar and keeping the deflector as close as possible to the cross bar.
Florunner78 is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 02:13 PM #379
Originally Posted by KWSRStorm View Post
My deflector is as far up towards the front of the car as it can go. The crossbar is all the way to the front as well. With the rubber on it was a little close to the roof so i just yanked it up a little bit and now its perfect. Drove for 40 hrs the past 5 days and no noise. Had the 2 treds mounted as well and it was as quiet as the factory rails.
Sent from my SM-G973U using Tapatalk
Do you have the steel or aluminum deflector? Also, what rubber are you referring to? Thanks.
Old 06-17-2019, 02:36 PM #380
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
I used this on my wind fairing to remedy the sound and vibrations everyone speaks of
McMaster-Carr
I got the idea from @mynameistory
https://www.toyota-4runner.org/3117705-post13.html
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 02:39 PM #381
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm has a spectacular aura about KWSRStorm has a spectacular aura about
KWSRStorm's Avatar
Steel. Mine came with a rubber piece to put on the edge of the deflector to protect the roof. It sits about 1/4 inch off the roof
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 11:42 AM #382
Cool - thanks. I got the aluminum version and it didn't come with any rubber pieces.
Old 06-18-2019, 07:26 PM #383
hwong232's Avatar
hwong232 hwong232 is offline
hwong232 is on a distinguished road
hwong232's Avatar
Installed four of the ruggedized steel crossbars with the wind deflector a while ago. Quailty stuff from LFD and happy with the purchase. Only minor complaint is that the powder coating in some corners seems to be chipping off, so I just did a quick touch-up with spray paint. Blends right in
hwong232 is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 07:30 PM #384
hwong232's Avatar
hwong232's Avatar
That's odd you're getting vibration, I have no issues with my 4 bars and wind deflector. I don't notice any wind noise either. Only time I notice it is at highway speeds when the radio isn't on, but I always have it on and don't notice a thing. Have you tried different positions for the 4 cross bars? I'm assuming you already set it up like mine though with two on the farthest ends of the rack and the remaining two splitting the middle evenly.
Old 06-19-2019, 12:00 PM #385
jafrush's Avatar
Real Name: Jacob
jafrush's Avatar
Real Name: Jacob
Some of the early deflectors can definitely do that.
We revised the deflectors and added a center support to help stiffen it up. You may need to add a few washers underneath that new center support to get the center a bit higher off the roof.
The rubber edge trim we're now including can be used during installation to protect the paint, but can be left on or removed after install. The clearance seems to vary between different setups. If there is enough clearance on your setup the edge trim wont matter and can be removed, but if its closer the edge trim can be left on to help.
Send us a message via our help desk if you have one of the older farings, and we'll send you a new one to replace it.
Old 06-20-2019, 10:44 AM #386
Beach5150 Beach5150 is offline
Real Name: Tom
Beach5150 will become famous soon enough
Real Name: Tom
Got my 5th Gen crossbars installed yesterday. They fit great!
The finish & powder coating looked very nice.
I was surprised how soon they were shipped considering they were on backorder. Great communication when I decided to add another cross bar to the order.
Waiting for the wind fairing before I adjust for any wind noise but didn’t seem to be too bad.
Good stuff!
A white 2017 Off-road for me, and a Cement 2020 Tacoma Off Road for the wife.
Beach5150 is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 12:40 PM #387
ToyoTex's Avatar
ToyoTex ToyoTex is offline
ToyoTex is on a distinguished road
ToyoTex's Avatar
Originally Posted by jafrush View Post
I'll start off with a few pictures from @007Tacoma of our 7/8 rack. He was one of our early adopters.
That front Pro bezel with the side mounted lettering is the coolest version I have ever seen. Where can I scope those letters and that front trim, or are they custom made?
2019 LE Nautical Blue|"Onroader"
2017 Chevrolet Silverado LT Z71 Summit White|"Bess" - SOLD: 12,500 MI, 1.5 years ownership TOO BIG
1999 Mercedes ML320 White|"Rustbucket" - DONATED: 335,000 MI, 20 years ownership I MISS IT EVERY DAY
ToyoTex is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 09:41 AM #388
jafrush's Avatar
Real Name: Jacob
jafrush's Avatar
Real Name: Jacob
@007Tacoma
Old 06-21-2019, 09:53 AM #389
007Tacoma's Avatar
007Tacoma 007Tacoma is offline
Real Name: Mark the Common Sense Wizard
007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice 007Tacoma is just really nice
007Tacoma's Avatar
That is actually the emblem off the tailgate of my 2008 Tacoma. It was sprayed with Plasti-Dip (gunmetal grey). We loved it, but it got broken by a piece of road debris in Colorado. So, now we are ordering a new one to replace it.
I'm 007Tacoma.
...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
007Tacoma is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 10:00 AM #390
ToyoTex's Avatar
ToyoTex's Avatar
Ah, thank you for illuminating that forum function to me, been a minute since I've used one
AH, now that's pretty darn cool. I like how unique it looks, compared to the big ol' Pro TOYOTA in dead center. Thank you for letting me in on your secret
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
