LFD_Off_Road
Old 09-13-2019, 08:15 AM #601
jafrush's Avatar
jafrush jafrush is offline
Real Name: Jacob
jafrush is a jewel in the rough jafrush is a jewel in the rough jafrush is a jewel in the rough
jafrush's Avatar
Real Name: Jacob
Regarding the warranty:
Modifying a vehicle only affects warranty on parts that are directly related to the modification. The two big things you can do with a roof rack are not seal it properly during install, which could cause a leak, and putting too much pressure on the threaded stud plate inside the roof and breaking it off, which makes it fall into the headliner. If you did either of those, no Toyota would not warranty it. It should not affect warranty on anything else on the vehicle though.
I've only heard of one customer who had a leak, and he had some gaps in his caulking coverage around the holes when he took the rack back off to look. A re-caulking to cover those gaps fixed the leak.
I did have my first experience with a broken off stud plate a few weeks back. My "new" red Trail had one of the rear plates broken (thankfully the previous owner warned me it was broken). With some creativity, I was able to keep one bolt in the threads at all times during the roof rack switchover, which prevented the plate from falling back into the headliner again. It only added about an extra 10 minutes of work to the rack install. Now if it had dropped, I would have had to pull the headliner and have another set of hands to get the plate back up and bolts back in (which the previous owner had to do when he installed the original rack).
jafrush is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 08:17 AM #602
jafrush's Avatar
Real Name: Jacob
jafrush's Avatar
Real Name: Jacob
Originally Posted by gdvan01 View Post
Well that's just peachy.....another part from LFD to sit and wait for....
Haha. You should see our engineering project list. Its so long its not even funny.
Old 09-13-2019, 02:53 PM #603
gdvan01's Avatar
gdvan01 gdvan01 is offline
Real Name: George
gdvan01 will become famous soon enough
gdvan01's Avatar
Real Name: George
Originally Posted by SpeedyKevin View Post
haha I believe that was me! Sorry forgot to update you on that. The ARD mount did NOT work with the Xbulls. The width was just a tad short. IF you wanted you could make the hole bigger on the Xbulls. I ended up just making my own mount.
Originally went with Carriage bolts but switched them out to 5.5in SS -Threaded rods (5/16). Allows me to remove them quickly (my other accessory mounts are attached via a Tnut). I use a wing nut+washer on the bottom part and a nut + rubber wash on top. The rubber washer keeps the mount from vibrating. To secure the boards I use a clamping nut along with a 1/2in pvc pipe. All in all, very happy with it
photo of all the gear attached (minus shovel)
1/2" PVC pipe for...a spacer between the boards and the clamping nut ?
I just ordered a set of the X-Bulls, your idea sounds like the way to go.
Almost forgot....how are you securing your shovel?
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
gdvan01 is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 03:35 PM #604
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
That is correct! The 5/16 clamping nut wont be able to screw down all the way with the xbull. I can take pictures of the set up later today
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 12:05 AM #605
Sea_ledford Sea_ledford is offline
Sea_ledford is on a distinguished road
Speaking of... I'm about ready to pull the trigger on a hybrid bumper. Before I do that are there any imminent updates to it?
-Chris
Sea_ledford is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 09:57 AM #606
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Installed a 100W solar panel on the rack, recessed so I can still carry lumber or plywood without the solar panel being in the way.
@mteolus you can see 2 of the SS carriage bolts in this pic I use for my x-bulls (i'm not sure i understood the other comment about saving time with 5/16 threaded rod, the carriage bolts just slide right through the slot and just need a couple washers and lock washer to secure them. the slot is the size of the square part of the carriage bolt so you only need 1 tool)
jhguth is offline   Reply With QuoteReply With Quote
Old 09-17-2019, 10:37 AM #607
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Very cool. Did you get the X-Bulls off Amazon or EBay? $85?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 09-17-2019, 11:36 AM #608
probably amazon but not sure, i've had them for awhile
Old 09-17-2019, 01:37 PM #609
mteolus's Avatar
mteolus's Avatar
Just checked on Ebay, $45. Not X-Bull but look exactly the same. Probably is the same.
Just ordered them, $45, no shipping, no tax. I like the black color better. I heard the red is more of a pink. Although in the description it says fiery red and also black so who knows. Who cares at $45 anyway.
Old 09-17-2019, 01:43 PM #610
Looks good!
I use threaded rods as sometimes take them off quickly as i need a little more clearance for short los angeles garages lol
Also, I got my xbulls off ebay for 60ish
Old 09-17-2019, 01:52 PM #611
gdvan01's Avatar
Real Name: George
gdvan01's Avatar
Real Name: George
X-Bulls were $65 on Amazon this past Friday when I ordered, back up to $78 now...
RVA Toyota Trucks
Old 09-17-2019, 02:18 PM #612
Looks good!
yeah but how is that quicker? i think i may be misunderstanding how you mount yours, i'm just using a carriage bolt with a single nut so it seems pretty quick to me. i want to be able to remove them quickly so not sure if i'm missing something.
Old 09-17-2019, 02:27 PM #613
Ahh I see where the confusion is. I mean I actually have to remove the rod itself (empty roof rack) to gain that extra 2-3 inches of height clearance! I went with a 5inch rod so I can't easily take them off the rack :/
Well I think thats where the confusion is haha
Old 09-17-2019, 02:31 PM #614
the carriage bolts come right out with a single nut and single tool
Old 09-17-2019, 03:07 PM #615
Are you unscrewing nut and pulling it out from the bottom of the rail? When I was using carriage bolts (5in), they were too long so I can't get them out from underneath the crossbars. Probably could with a shorter one. With the rod, I don't need a tool and just unscrew the butterfly nut
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
