02-17-2020, 09:41 AM
#901
Real Name: Mark the Common Sense Wizard
Originally Posted by Unretired
Engo SR10 - Synthetic 10000lb Winch weighs 60 pounds.
LFD Hybrid Bumper weighs 83.2 lbs.
Stock Bumper I removed weighed 24.4 pounds.
Center of mass of new gear is a bit forward of stock bumper so 60 + 83.2 - 24.4 = 118.8 isn't exactly right, but close.
I still have stock suspension and I think the front went down about 1/2 inch... hard to tell with various measurements.
Front skid plate seems to show it most.
That sounds about right. We added a bit more weight with lights, but our Dobinson’s springs only dropped 1/2 inch...
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
02-18-2020, 03:17 PM
#902
Has anyone mounted an antenna to the crossbars? Thinking about mounting my midland gmrs antenna up there and curious to what solutions you folks may have. Thanks!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
02-18-2020, 03:36 PM
#903
3/8" through hole NMO mount should fit almost perfectly in the large hole cutout part of the slot
02-19-2020, 12:55 AM
#904
I have my magnetic shorty antenna for the WeBoost mounted to a cross bar (and then I pop it "down" to live horizontally off of the inside of the side rail when I'm not expecting to need it)...
Are you talking about the short magnetic mount antenna included with the MXT275 (and I'd imagine the 115)? Or adding a NMO style mount should be fairly easy. I've never measured to see if the 3/8" NMO will fit through the circular part, but it could alternatively just enlarge one of them. If that's not your cup of tea any of the generic 90 degree or "fender" NMO mounts should work just fine.
If you wanted to get fancy with it you could look into something like a Diamond trunk lip mount (or SUPER fancy with their motorized one).
'21 Tundra DC - |Aluma 2.5s/SPC/Dobinsons HD|Skinny 35s|DECKED|Dual Batteries|eXcelon Reference/Hertz Dieci/Kicker|ARB Elements|LRA Tank|LFD Bed Rack|CVT Mt Hood|ARB 2000|Everything Diode Dynamics|
'21 Tacoma TRD-OR DCLB - GF's Truck - |Aluma 2.5s/SPC/AAL/Durobumps/U-Bolt Flip|Level8 Mk6|ARB Single|ARB ZERO|Everything Diode Dynamics|
'18 4Runner TRD-OR - SOLD!
02-19-2020, 01:54 AM
#905
Thanks for the responses folks! Was planning on adding an NMO mount to use with the MXTA26 antenna.
02-20-2020, 08:31 AM
#906
official vendor
official vendor
I've run a CB antenna bolted directly to a crossbar in a pinch (left the mount at home accidentally). It was tall, which is good for reception but bad for branches!
02-20-2020, 10:50 AM
#907
The LFD Off Road Thread
This is how my Dual Band antenna is mounted... It becomes a pogo stick with the branches.
It is in the top of the pic by the ROAM Crate...
02-20-2020, 05:15 PM
#908
Don't tease, show the rest of the rig! looks clean!
02-24-2020, 08:58 AM
#909
Thanks!!!
Not always so clean...
02-24-2020, 09:31 AM
#910
Real Name: Terry
Real Name: Terry
Update - Wind Fairing Solved the Noise
Seems obvious but I figured I'd update the post. Yes, the wind fairing works. Installed the steel fairing Saturday (about 2 mins) and noise went away, loaded or unloaded.
If you are considering number of cross bars and/or a wind fairing - this might help.
Had 2 stainless crossbars positioned between the low noise OEM marks on the rails.
Was able to mount hi-lift, shovel and 4 recovery boards (2 Xbull stacks side by side).
Noise was noticeable, but easy to ignore.
Above 70 got a little worse, but not bad.
No need for a wind fairing.
Moved the 2 bars all the way back and noise wasn't much different.
Added 3rd bar all the way forward and now the noise is annoying.
Don't really need the 3rd bar for 4x4 gear, but I wanted it to spread the bars out for Lowe's runs.
I could have just moved the two around as needed and saved money, but I already bought the third, so now I think i need a wind fairing.
Plus, moving them around isn't hard, but it is time consuming - they aren't quick-release and slide.
And they have to be just right so all the bolts and brackets line up for the gear on top.
2016 SR5 - Wildpeak A/T3W 265/70R17SL or BFG K02 C Load 285/70R17; RSG Sliders; LFD Crossbars, Skid Plates & Hybrid Bumper; RCI Skids on Rear Diff, Lower Links & Shock Mounts; Engo SR10S Winch; Dobinson 700/701 IMS with 314/327 Coils +2.25" front +2.5" rear; Goat Armor; Redarc Brake Controller; Camping Hatch Mod; DIY Drawers & Sleeping Platform; Cheap 10" Light Bars in Grill; Front/Rear Camera Mod with Nav Input; Simple Nav/Comms - Garmin inReach Mini, iPad & Motorola FRS.
02-24-2020, 04:22 PM
#911
Thanks!!!
Snaps that looks good! Do you find the bumper trim helpful? Approach wise? Thinking about cutting mine a little
02-24-2020, 04:46 PM
#912
Originally Posted by gdvan01
Looks great!
What would you say is the added weight with the bumper and winch?
Damn that looks good. Best hybrid out there because of the winch access. Will be getting one maybe later this year. How long did it take to install, without the winch and with the winch?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
02-24-2020, 04:52 PM
#913
official vendor
official vendor
Glad it made a difference! Hope you guys had fun this weekend!
02-24-2020, 08:34 PM
#914
Real Name: Terry
Real Name: Terry
Install Time... 1/2 day going slow
Honestly didn't really time the install, since I had all day.
Started around lunch and was done by dinner going slow.
Needed help holding things a few times, it would be really awkward by yourself.
I reviewed some posts about bumper removal and kind of mapped out my plan before hand.
Nothing really difficult about it... just have to commit on bumper removal (popping parts out) and later cutting.
Son used floor jack to lift LFD bumper in place while I bolted it up - easy.
I connected all the wires to the winch and it bolts right on - easy without bumper cover in place. (don't think it can be done with cover on).
Winch fit fine and I didn't have to bend any brackets or anything - suspect that will vary on winch model.
Dremel to cut out area on the bumper cover was fairly easy but scary.
Then maneuver the bumper cover back in place - I think a 2 person job and requires patience.
And trim with edge guard.
I wanted some wire loom for my positive cable so I went back later and connected to the battery... plenty of room and another 15 minutes of fiddling.
To me the scariest part is the cutting.
If you have a trail then your valence is the template - easier.
The most annoying part is getting the bumper cover off and then back on - read some posts for tips.
It isn't hard, but you are pulling and tying to get it to pop apart without creasing plastic... then getting the damn thing back on is worse.
The bolt turning LFD/winch part is easy.
If you plan on doing the winch at a separate time - that sucks because you have to do the bumper cover twice. Maybe you'll be better at it than I was.
02-24-2020, 11:15 PM
#915
Since it is relevant to the thread, and shows the rear bumper and roof rack actually being used, here are a few shots from this past weekend's event with LFD/OEX...
@ Unretired
I had a thought that was your truck in the other group! We caught up to your group just in time to see your truck getting a little help on the rocks, but I don't think we ever actually got a chance to chat.
For anyone else even remotely in the area (Uwharrie, NC), if you're looking for off-road training or want to understand how to fully use everything your truck can offer you, get in touch with Overland Experts
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
