LFD_Off_Road
Old 09-09-2021, 03:34 PM #1576
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
Originally Posted by JustLucky View Post
Would you mind sharing your planned crossbar configuration? I was thinking of something similar after LFD recommended the narrow crossbar with the integrated fairing over the wide crossbar with the bolt on fairing.
Sure thing, in general, i wanted some flexibility with what I'm able to load up top, as the final loadout is still a bit in question.
Hi-lift for sure
Awning for sure
traction boards - likely
possibly a double fuel can mount from frontrunner, or a 4.5gal long rotopax fuel container.
'm thinking from front to back either
Fairing crossbar
Wide
Narrow
Wide
(this would allow me to run a rotopax in rear most position, directly on the crossbar, if i use rotopax fuel container(s) instead of nato cans, and would also make mounting a nato can holder easier on a combo of the rear most wide and thin bars aligned either left/right or center.
Or
Fairing crossbar
Wide
Wide
Narrow
Which would allow me more surface area in the center of the rack for larger load items like an alu-box or two, and would also seem to be easier to mount a RTT with the narrow bars at the ends, if we end up going that way in the future.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 04:26 PM #1577
JustLucky JustLucky is offline
JustLucky is on a distinguished road
Hi-lift for sure
Awning for sure
Fairing crossbar
Wide
Narrow
Wide
Or
Fairing crossbar
Wide
Wide
Narrow
Thank you! Great info!
JustLucky is offline   Reply With QuoteReply With Quote
Old 10-08-2021, 01:24 AM #1578
meeksodorifto's Avatar
meeksodorifto meeksodorifto is offline
meeksodorifto will become famous soon enough
Does anybody have any reviews of the LFD minimalist rack? Aside from one person on this thread and LFD's stock photos on their site, I haven't really seen much of it. Really want to see if anybody that owns one can chime in about it!
2019 SR5 7 seater Canadian Edition
Kings 2.5 F/R non-adjustable, 1.5" lift all around // 550lb front rate, T13 wheelers springs rear // JBA std uca high caster // Durobumps rear bumpstops
Energy suspension front bumpstops // GY Duratracs load D 285/70/17 // TRDP Wheels // RSG angled sliders // front lower bumper vinyl wrapped black // DIY roof rack + ARB 1250 awning: https://www.toyota-4runner.org/3502577-post43232.html
meeksodorifto is offline   Reply With QuoteReply With Quote
Old 11-07-2021, 05:05 PM #1579
sactown sactown is offline
sactown is on a distinguished road
Roof rack sealant
Received the new full size LFD rack, and reading their instructions to use a silicon sealant, I’m wondering what is the best type of silicon available for this application. Gets very hot here in the Cali central valley (measured my roof temp w/ an IR gun this June at about 180°) so need something that will hold up to the heat and sunlight/UV, as well as the winter cold in the Sierra.
I’ve done searches here on the subject and have found a lot of ideas, but they’re not all specific to LFD and their spacers so I wanted to solicit opinions about sealing the mounting points of the LFD rack in my climate conditions.
Thanks in advance.
2017 TRD-OR w/ KDSS
sactown is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 02:04 PM #1580
Bundutrailer Bundutrailer is offline
Bundutrailer is on a distinguished road
Originally Posted by TRD PANTHER View Post
Added 4 wide LFD crossbars and fairing to my rig. Will be getting my hi lift mounts from LFD this week. Adding a double rifle case, hi lift jack, traction boards and a Rotopax. Nice clean design that you don’t have to remove rails and end caps or worry about leaks with the OEM rail and cap setup. This setup would work great with a cargo box and extras or a RTT.
Wondering if two 4” is better than three 2” crossbars to put an ikamper mini.
Bundutrailer is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 05:31 PM #1581
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I couldn’t answer that. I would contact LFD.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 11-14-2021, 05:41 AM #1582
I will do, how is the noise with 4bars at 4” each, at 2” I hear pretty noisy. Have a fairing?
Old 11-14-2021, 05:09 PM #1583
TBTally TBTally is offline
TBTally is on a distinguished road
Thanks in advance.
Installed full 7/8 lfd rack 2 years ago and live in hot Florida. I used loctite silicone. No issues yet.
The LFD Off Road Thread-20210612_154307_194657389429960-jpg  The LFD Off Road Thread-20210605_154302_170618902891319-jpg
TBTally is offline   Reply With QuoteReply With Quote
Old 11-15-2021, 04:43 AM #1584
I drove it without a wind fairing and it was noticeably loud. After the wind fairing install, it cut the wind noise by about 90%. I consider the wind noise with the four wide bars equally spaced with the fairing to be very tolerable, but not as quiet as without any.
Old 11-15-2021, 09:35 AM #1585
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Perfect stance. How big lift/tires?
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 11-16-2021, 11:17 PM #1586
Thanks for this, I will go 2” given. Want to keep my options open for a RTT in the future.
Old 11-19-2021, 07:34 PM #1587
Finslayer83 Finslayer83 is offline
Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough
Finslayer83 is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 01:28 PM #1588
rsean10's Avatar
rsean10 rsean10 is offline
rsean10 is on a distinguished road
rsean10's Avatar
@LFD_Off_Road , any chance you guys will do the minimalist rack in stainless at some point? Y'all make some awesome gear, and was wicked excited when I saw that one - just worried about rust up in New England.
2010 TE, OME 2884/2895, OME UCAs
rsean10 is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 11:47 AM #1589
KeydeT4R KeydeT4R is offline
KeydeT4R is on a distinguished road
Thule Box Mount
I looked through the thread but didn't see this question answered. Has anybody mounted a thule roof box to the integrated fairing crossbar? Based on the fairing profile I assume the clamps can't fit around the bar, but I'd like to make sure there wasn't an adapter or such before ordering another crossbar.
KeydeT4R is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 01:25 PM #1590
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
I run Thule/Yakima ski mounts on the non-integrated bar, and you have to open the jaws up to nearly full width. Zero chance you could clamp around the integrated fairing, unless you have the old bolt-on fairing and had it mounted as far away as possible (and even then it likely wouldn't fit).
My opinion: no, you can't clamp onto the integrated fairing.
91foxbody is offline   Reply With QuoteReply With Quote
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
