LFD_Off_Road
Old 08-05-2022, 11:04 AM #1666
Finslayer83 Finslayer83 is offline
Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough Finslayer83 is a jewel in the rough
Finslayer83 is offline   Reply With QuoteReply With Quote
Old 08-11-2022, 04:24 PM #1667
Old 08-12-2022, 04:06 PM #1668
Humble Leader's Avatar
Originally Posted by KeydeT4R View Post
After a year of running the integrated fairing and a couple bars I went to mount my Skybox. Some trial and error later I realized the integrated fairing bar would have to come off for the box to clear the hatch on stock rails. Well, needless to say I'm pretty disappointed in what I found under the fairing strip. I should have checked that it was resting on the paint after reading this thread a while back but it slipped my mind. I guess use me as another data point, but do not install the weather stripping with the integrated fairing bar, it will destroy your clear coat.
damn that sucks. honestly LFD should stop including that weather stripping. I didn't install mine and I have about 1/4" clearance between the highest point of the roof and faring. that faring rubs on almost everyone's vehicle that installs it. you can try and install some clear bra or PPF if you really want to use the weather stripping but you're only buying time. vibration ruins everything especially when little bits of sand get stuck between the PPF and weather stripping, acts like sandpaper. I love my LFD rails and want to get a 3/4 rack. they make great products but this stripping needs to go
Old 08-17-2022, 08:24 PM #1669
taylortaylor taylortaylor is offline
taylortaylor is on a distinguished road
Hi all, I just installed my ruggedized crossbar set about a week ago. After seeing a couple cases of some wind faring damage I’m curious to see a detailed photo of exactly how the rubber protective strip is supposed rest against the roof of the car.
In an earlier post an LFD employee mentioned only the “bulb” part of the strip should touch the roof, not the other more rigid material that wraps around the bar itself. I just want to make sure it’s set correctly so I don’t run into any rubbing damage on accident down the line.
Thanks!
taylortaylor is offline   Reply With QuoteReply With Quote
Old 08-18-2022, 01:14 AM #1670
johnnygraphic johnnygraphic is offline
johnnygraphic has a spectacular aura about johnnygraphic has a spectacular aura about johnnygraphic has a spectacular aura about
Thanks!
Best way to prevent rubbing (damage) is to skip the ironically named protective strip. There is only a small gap between the fairing and the roof without it. Myself and others have not noticed any wind noise without it.
johnnygraphic is offline   Reply With QuoteReply With Quote
Old 08-18-2022, 09:42 AM #1671
Thanks!
let me save you some time - just remove it. you don't need it and you'll never have to worry
Old 08-18-2022, 01:14 PM #1672
Awesome thanks guys! I’m just worried there isn’t a big enough gap and the faring could bounce against the roof. The bars are pretty damn rigid so I bet that wouldn’t happen. I’ll give it a go and if that ends up happening I’m sure I’ll know pretty quick haha.
Old 08-20-2022, 01:30 PM #1673
Knuckl3dragg3r Knuckl3dragg3r is offline
Knuckl3dragg3r is on a distinguished road
I opted for the LFD crossbar set on my new '22 after having a rhino rack pioneer platform on the '21 I totaled. Love them so far.
I initially installed the protective strip along the wind fairing but I also noticed what looked to be a bit of grit build up after the first couple of weeks. There was probably 1/16th to 1/8" of clearance between the stripping and the roof. I have since removed the stripping and there is a full 1/4" of clearance now and no signs of additional grit build up. It also seems as if removing the stripping seemed to reduce the wind noise even slightly more... (not that it was significant in the first place).
Knuckl3dragg3r is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 11:20 AM #1674
do you have the integrated faring? that won't bounce against the roof it's solid. maybe if you punched the roof from inside the vehicle upwards you could push it into the faring lol. I've ripped down gravel/uneven/potholed service roads and over many many bumps at speed, never had any sort of flex or contact with the roof
Old 08-22-2022, 10:36 PM #1675
Beach5150 Beach5150 is offline
Real Name: Tom
Beach5150 will become famous soon enough
Real Name: Tom
Yup.
I had a fairing on for a while. It contacted the roof with the trim on so I put film on the roof. I had to take it off to mount a luggage carrier & never put it back.
I have 3 ruggedized crossbars but only put 2 on. Even though the Runner is always parked in the garage they have significant rust.
I installed a Sherpa rack & now all my LFD stuff is just scrap metal for projects now.
A white 2017 Off-road for me, and a Cement 2020 Tacoma Off Road for the wife.
Beach5150 is offline   Reply With QuoteReply With Quote
Old 08-28-2022, 11:33 AM #1676
YT-1300's Avatar
YT-1300 YT-1300 is offline
YT-1300 will become famous soon enough
YT-1300's Avatar
Just finished a 2000+ mile road trip though Michigan's UP. Yakima Skybox 16 and Napa awning on two crossbars, no fairing. Zero wind noise!
As mentioned, the Skybox clamps won't work with either fairing, and the box tunnels more air underneath to make unbearable wind noise at any speed. I had some leftover foam pipe insulation, stuffed it in the front crossbar channel to fill the gap and BOOM!, totally silent! Used some zip ties to keep it in place while I mounted the Skybox.
Sent from my moto g(7) using Tapatalk
2019 SR5 Prem, Nautical Blue, 3rd row, TRD wheels, 255/75/17 Cooper Discoverer AT3 4S (SL), Leveled with Eibach shocks, Rav4 mirrors
YT-1300 is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 09:51 AM #1677
PrettyGoodSam PrettyGoodSam is offline
PrettyGoodSam will become famous soon enough
are the 10-13 trail edition crossbars going to be restocked anytime soon?
PrettyGoodSam is offline   Reply With QuoteReply With Quote
Old 09-03-2022, 10:32 PM #1678
Old 09-15-2022, 11:29 PM #1679
weezol weezol is offline
weezol is on a distinguished road
Does anyone know the weight of the 3/4 stainless steel roof rack? I can't find it listed anywhere
weezol is offline   Reply With QuoteReply With Quote
Old 11-12-2022, 09:32 AM #1680
curmudge1 curmudge1 is offline
Real Name: Dave
curmudge1 is on a distinguished road
Real Name: Dave
Original TE 10-13 crossbars?
My question, too ... will the backorders be filled? I see LFD OR has 15% off for November, I've been thinking about getting the LFD cross bars for some time.
Should I get 2 or 3? And is the wind fairing for the TE 10-13 available? I did not find it with a quick search... do I need it? for running without anything on the cross bars, day-to-day. Seems like I do, so that would be 3 cross bars with a wind fairing on the front one.
I have a Yakima Mega Warrior basket to mount, sometimes. Should be OK?
Lots of questions, but I'm such a cheapskate before I pull the trigger.
curmudge1 is offline   Reply With QuoteReply With Quote
armor , bumper , lfd , roof rack
Murph's Build and Off Road Thread ugamurph 3rd gen T4Rs 102 08-28-2018 11:26 AM
LimaSierra's '18 TRD Off-Road Build and Pic Thread LimaSierra 5th gen T4Rs 37 11-18-2017 07:47 PM
Road Bikes thread DannyLlama General Discussions 16 09-11-2017 04:44 PM
This Thread Needs Off-road Pics! briggs4811 Gallery 19 12-15-2004 04:11 PM
