12-23-2018, 01:33 AM
SPC Upper Control Arms: Safe or Not Safe?
Hey folks! Finally pulling the trigger on a lift and I'm in the business for some upper control arms. The SPC's are obviously attractive considering the price. That said, I have read some horror stories on this site. Here's what I've gathered so far...
First "generation" had instances in which the arms broke. Terrifying prospect...
Then the next set apparently had some bushings that failed. Also scary. I haven't read of any problems since, though. One one hand, seems like too important of a part to get wrong. On the other hand, seems like they're pretty functional now?
Anyone know this history and have thoughts on the latest product? Thanks!!
2016 SR5 4runner
12-23-2018, 01:39 AM
Banned
Banned
I think the recent variations have been solid, and the range of adjustments with them is a big plus as well. I personally run JBAs because it uses a serviceable standard GM ball joint, grease fittings and 3 degrees of built in castor. They are built really well, in the USA and ride excellent on/off road.
12-23-2018, 02:00 AM
Nice. Thank you for info. Does JBA sell them for 5th gen? Can't seem to find it on their site...
2016 SR5 4runner
12-23-2018, 04:10 AM
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
12-23-2018, 05:32 AM
I have spc UCA- driver side ball joint went bad after 1.5 years. 2 buddies have them and have had no problems and have 2-3 years on theirs. The shop I used to do the initial install reports they haven't had any issues with the SPC, owner has a built 4Runner and he uses SPC.
I wasn't pumped when I discovered this- but figured I'd replace it and see how it goes. I also had to do bushings but I suspect those went bad after the BJ ate it self and introduced some play and put extra stress on the bushings.
The whole reason I went with Ball joints and not uniballs is I didn't want to deal with parts that are gonna wear out quick, make noise, throw the alignment off and eat my tires.
My understanding is that JBA has advantages like those listed above -Chevy 1/2" that can be found all over. Where as the SPC BJ is proprietary. However I was told the castor on the JBA maxes out at about a 285 size tire. Anything larger needs an UCA with more castor.
Regardless if I have further issues I'll be looking at replacing them with JBA.
12-23-2018, 09:32 AM
I went JBA and I’m perfectly happy.
12-23-2018, 09:37 AM
What is that supposed to even mean? Caster is a suspension angle, 285 is a tire width. The width of a tire (or anything about a tire beyond matching the tire size and pressure left to right) has no effect suspension angle.
12-23-2018, 09:45 AM
Real Name: Morgan
Real Name: Morgan
I was confused and intrigued as well
2010 SR5 Blizz Pearl- Borla cat back, Firestone ride rite, Huskyliners, Afe Cai, Urd MAF, Gobi stealth with ladder, 5100s, icon 2" rear, toytec 1.6" front, TC UCA, HAF custom sliders, hand hold light mod, Led interior, stock rims and BFG KO2 265/70 C, Arb CKMA12- slider tanks w/ couplers, BD S8 10", opt7 40", BD dome light led in rear hatch
12-23-2018, 10:31 AM
Banned
Banned
There are a few members in here running 295s with JBA without issue.
12-23-2018, 11:07 AM
Originally Posted by Icantdrive55
I wish I'd never bought mine, and went with JBA or icon deltas instead
^like
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
12-23-2018, 12:12 PM
I'm on my second set of SPC arms as of last week. My first set was of the initall variety that had bad ball joints. One failed and both were replaced on SPC's dime at about 6,000 miles. I then ran them for 65,000 miles with no issues. I had a new set installed with my new suspension last week. I asked about rebuilding them or replacing the ball joint but was told that the new version aren't compatible with my old ones. SPC discounted them to incentivize me to get a new set (15%). We'll see I guess. I hope there' no issue. All this was done through my local shop Hi Country 4x4 here in Denver who buys lots of arms from them so maybe that's why the customer service was better?
I have also heard that the SPC arms have more caster adjustment than most others but have no factual evidence of that. FWIW I get over 4 degrees of caster on my setup which is listed in my signature. I'm also not sure what the heck caster has to do with tire size but I can always learn something new if that's the case
12-23-2018, 12:46 PM
Banned
Banned
Congratulations on having a full on novel as your signature line...it yook me five minutes to read your modifications
12-23-2018, 12:54 PM
Real Name: Chris
Real Name: Chris
With all the failures reported, terrible customer service, you couldn't pay me to run SPC arms. These failures are not isolated to our trucks either, they are across the board. SPC makes products for everything, cars, trucks, there are a lot of issues with their poor quality products. Google it, that's all I did and came up with quite a bit.
12-23-2018, 01:16 PM
I wanted to hit like but I guess that's no more
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
