Originally Posted by Jeremy556
How much weight do you have above stock? How much preload are you running on the 650s?
Besides the higher spring rate, the Icon 700lb coils are also longer. If you have tons of preload on the 650s to support a lot of weight over stock, you will get better ride quality from the longer 700lb springs with less preload.
I have a steel bumper (no winch), skid, rock sliders and a RTT. I'm at about 1.5" of preload on the passenger side and 1.75" on the driver side to even out the lean.
So, the 700lb coils are probably where I need to be. But I'd rather be a little soft than too stiff as I don't normally go ripping across the desert.
I have a dual swing bumper in the rear and went with Dobinson's C59-701V coils, but they were too tall and too stiff. I put the Icon coils back on while I waited for Dobinson's C59-327 coils to come in. The 327's just arrived so I'll add those tomorrow.
