12-29-2018, 03:40 AM
OEM Audio Plus 500Q Reference - System Review in a 2019 4Runner
**** BTW I am getting errors in uploading pictures so I will post the pics later in this thread ******
I bought an OEM Audio Plus 500Q Reference system a few months ago with all speakers, amp, and a custom subwoofer made just for the 2010-2019 4Runners. I had first installed in my 2011 Canadian Trail 4Runner which did not come with any JBL radio. I followed all video instructions from OEM Audio Plus and installed it without any issues, enjoyed it for a couple fo months…. before I came across a 2019 VooDoo Pro that I could not pass. I also came to know that the Canadian Pro did not come with the factory JBL Audio. At first I was a bit disappointed because I prefer to keep it all stock…..but that was momentary as I already had the OEM+ setup which blends in under the seat and keeps the stock look. I am kind of glad now that Toyota Canada did not include JBL in the 2019 Pro because otherwise the MSRP would have been at least $3K more… like the US Pro model.
There are Three distinct advantages for choosing OEM Audio Plus 500Q Reference…..
(1) Sound Quality. In short, it is ten times better than my my wife’s Runners’ JBL system. The experience is almost identical (within the 4Runner confines) to listening to the hi-Res audio on a two channel setup in my house. The sound is crisp and clear, the lows are well balanced with mids/highs and gives the full body to the sound tracks as intended. if you are crazy after just a ton of low frequencies to shake your butt then you should contact OEM+ as they might have an option to add a second sub. Ideally I would have gone for the Sony hi-Res ES deck but the deck alone comes for $2K+ and I would have to remove the stock setup. Besides the supreme sound quality, you can keep your stock looks and wiring etc. The DIY job is so simple. I am attaching some pics. My wife thought I was really crazy to open a brand new car….but really the install is very very simple with a couple of right trim tools. I am like a pro now… after installing it in 2011, removing it from 2011, and re-installing it in 2019.
(2) Customer Service: Daniel La Blanc and the full staff of OEM + is super knowledgable and passionate about their product line up. I must say that they are committed to get the intended performance out of their product after the install. You may wonder how do they achieve that? see #3 for that. I dropped one of the speakers and damaged it a bit while the 2011 removal. When i contacted OEM+ they were very helpful in getting me a replacement…. and not only the replacement, but they practically stood next to me until after the install was done successfully and the system was tuned optimally. A+++ for the customer service.
(3) Product technology: Toyota must have changed something in so many years. I jumped from 2011 to 2019 runner and I noticed that the volume level after connecting OEM+ setup was a bit lower and I felt as if I had lost some low frequencies. When I mentioned this to Daniel, he right away give me a series of very simple steps to upgrade the firmware of the unit and load the latest optimal tuning file to the 500Q unit. it took me a couple of simple steps to perform the upgrade using a computer…. and wow the system now performs better than it ever did before.
I use a Fiio Hi-Res portable player to load my high quality media files and connect the player to the AUX input of the Runner. This sound quality is far superior using the OEM Audio +. I had played the same Hi-Res player before the OEM+ install and it sounded like an off-air FM radio station using the stock setup. In fact any source (spotify over bluetooth, AM, FM, XM) that played in the stock setup significantly improved with the OEM+. I just had to mentioned the Hi-Res part more because the net gain in this source was simply out-sanding… .the point here is that OEM+ was the new component added to achieve this quality sound. Stock is just dull regardless of the type of source.
So the final question many of you would have is the price of the OEM+. yes it is steep a bit but if you really know what you want out of a music system then look no further. You get what you pay for…. Quality Sound, unmatched customer service, and superb product tune-ability. This is a very carefully tuned setup by many experts at OEM+ (you will know when you talk to them)…. And it does NOT tear apart you runner with distorting ultra low frequencies and/or screeching high frequencies with spiked mids. Choice of sounds quality and ow much you want to spend on it really depends on your taste… so be your own judge and decide on what you want to spend on…. at least find someone to audition this system if you are struggling with a decision. OEM Audio Plus gives a ton of value for your money.
…. after all there is a reason why you drive a 4Runner over any other new car that comes with a ton of bells&whistles. i don't really care for the toyota lane assist and safety sense in a runner but the music system need to be top quality... so this was it for me.
https://oemaudioplus.com/toyota/4runner/
12-29-2018, 02:23 PM
In regard to #3, can you share what you did to upgrade? I think several of us have wondered about the same thing...
2018 Off Road Premium - Magnetic Grey Metallic
12-29-2018, 06:59 PM
I can certainly share the software and files I received from Daniel @ OEM+; however it would be best if you contact him directly and get a specific file that is targeted for your model. I have a black 500Q Reference model. Just let me know. OEM will stand behind what they supply whereas what I share would be a second hand material and I obviously can not support if you run into any difficulty. I must tell you that the whole process was very simple. Steps 1, 2, 3 using a windows computer and a mini-USB cable attached to the OEM+ amp. Let me know what you prefer.
thanks.
12-29-2018, 07:57 PM
Did you add any vehicle treatments while you were mucking about the interior?
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod , Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger , Ironman FCP shocks
12-30-2018, 01:48 AM
no i did not. i thought of adding sound damping on the door panels last minutes but got lazy to find a good quantity on a deal... so i saved that for a later date. is that what you mean by treatment?
12-30-2018, 12:49 PM
Real Name: Tom
Real Name: Tom
So where is OEM plus located?
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
12-30-2018, 02:37 PM
Yep, all the stuff that goes along with a high quality stereo and the associated acoustics.
http://sandv.com/downloads/1110saha.pdf
https://www.sounddeadenershowdown.com/
Good Luck!
12-30-2018, 07:26 PM
Thanks. now this is going to be the project for the spring. it started getting cold here and that was part of the reason i didn't plan it out properly. was supposed to get the Pro delivery in mid November but got it in the first week of December.
12-30-2018, 07:28 PM
the main unit mounts under the front passenger seat. its very compact and mounts nicely.
complete install video at... https://youtu.be/wxMe94iei3k
01-08-2019, 11:29 PM
Has anyone run into issues with their OEM Audio + system not working after installing HID low beams? For some background, I installed their system with no issues. Had it working great for a few weeks. And just recently, I installed the XenonDepot HID Xtreme lights for my low beams, but after reengaging the battery, my system no longer had sound. Anyone experience this or similar issue before?
01-09-2019, 10:41 PM
Real Name: Jason
Real Name: Jason
Yikes.....what could have caused that?
01-09-2019, 10:52 PM
Thanks for the review. I've looked at their stuff for my 4Runner but just get over the sticker shock at the moment. But I do understand value for your money. I've got some big ticket items ahead of it but I will probably do it in the future. First the Fox lift and tires, then the bumper and winch, so maybe after those.
When I worked at Toyota many years ago we did of couple of OEM+ system upgrades in the Scions and I was pretty impressed with them. Thanks again.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
01-10-2019, 08:49 AM
Great review. I hope they do something for the 4th gen but doubtful because the interest probably isn't there. I was following OEM+ back when they had a crazy 2300 dollar setup for the BRZ that came with 2 subs. I think they only made like ten of those setups. I was going to get one but ended up with a Type R instead of the BRZ.
1999 2.7 5MT - SOLD // 2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT // Model 3 // IS300 5MT // FD RX7 //
01-10-2019, 10:24 AM
Real Name: Chris
Real Name: Chris
Did you check the radio fuses?
01-10-2019, 06:11 PM
Yep. Fuse is intact. Checked my wiring and butt connections to make sure I didn’t screw anything up and that power was going to amp too. All those things seem fine. Thinking maybe something is wrong with the amp?
Daniel from OEM+ is a bit stumped too but is working with me to try and figure out what’s up. Open to any other ideas since I’m not technical or proficient on this sort of stuff at all.
