Hello all. I am looking for advice on combining the rocker switch panel with indicator lights. I have built and installed the 5 switch build in the lower cubby and it works great. However, it is low enough and slightly angled downward, just enough that I do not notice if the I dindicator is illuminated or not. The other night I left rear facing lights on and did not notice until my son and I came back out from the TSO concert, to a dead battery, leaving us stranded outside the American Airlines Center in Dallas. A quick jump got us back on the road, but doesn’t address the issue that I missed the rocker switch illumination indicating that the switch is on.
So my thought...
Using antman’s sp8ball’s led accent light thread,
https://www.toyota-4runner.org/5th-g...tml#post774399
I’m going to build some led power indicators and place them in the flat area above the center vents by the clock.
What I need help with: where do I tie the indicators into the rocker switches so that the led will illuminate when the switch is on?
