Old 01-02-2019, 06:48 PM #1
assassin assassin is offline
Real Name: M
assassin is on a distinguished road
Real Name: M
Max Recommended Front Lift, Center Hub to Fender
Was wondering how much lift you guys recommend "maxing" out at in the front. Currently I am at 22.5 center of hub to fender. I went to a meet and saw people with as much as 25 inches in the front. I am sure more lift in the front with stock axle shafts means worse CV life.
assassin is offline   Reply With QuoteReply With Quote
Old 01-02-2019, 10:56 PM #2
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
3" over stock which would be about 23" center of hub to bottom of fender.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 01-03-2019, 12:07 AM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
i wouldn't go by how much lift you can get, but more along the lines of how much of an angle your cv boot looks like. Everyone is different.
I went up to 3 inches to fit tires, now I'm actually going back down as much as I can to maximize my cv's life.
Old 01-03-2019, 02:48 AM #4
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
I agree with this.
shrub1 is offline   Reply With QuoteReply With Quote
Old 01-03-2019, 07:27 PM #5
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
This thread got me checking and mine measures center hub to fender @ 23 1/8" . Too much?
zonzin is offline   Reply With QuoteReply With Quote
Old 01-03-2019, 08:44 PM #6
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Do you want a show truck or something functional?
For functional height - 3 inches is kinda the limit. Higher than that and you should be either going for a bracket lift or long travel.
For a show truck that doesn't really do anything very well - you could maybe get away with up to 4.5" lift if you clearance your CVs and use a diff drop. It's going to suck on and off road. But it can physically be done and move under its own power.
Old 01-03-2019, 11:00 PM #7
shrub1's Avatar
shrub1's Avatar
I think that's fine. But again, check your boots to see how angry they may be.
I am down to 23.25 from 23.5 and the ride and breaking is so much better.
Old 01-04-2019, 02:44 AM #8
Real Name: M
Real Name: M
When my lift was freshly installed I was at 23 inches my boots currently look pretty good I think I could afford to go a little higher in the front but don’t think it’s worth the work adjusting 1/2 with kings
Old 01-04-2019, 12:05 PM #9
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
maybe im uninformed. Checking your boots your just looking for tears/angle and stretching ya?
Im at 23 with a diff drop. Hope to go up 1/2" more when I get my icons.
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 01-04-2019, 12:12 PM #10
What are your rears at homie? Looks good!
Old 01-04-2019, 12:24 PM #11
shrub1's Avatar
shrub1's Avatar
To see if and or how much the boots are rubbing (looking for tears and slung grease is also a good practice every so often as well). If a business card can fit between the bellows you are good to go. Now..everyone has their own comfort level with this, so everyones appetite will be different on this.
Old 01-04-2019, 12:25 PM #12
shrub1's Avatar
shrub1's Avatar
24.3 unloaded
Old 01-04-2019, 01:29 PM #13
zonzin's Avatar
zonzin's Avatar
Here are a couple of pics of the CV @ 23 1/4" . To my untrained eye, all looks well. Comments?
Old 01-04-2019, 01:42 PM #14
mrblah's Avatar
mrblah's Avatar
That’s beyond my comfort zone
Old 01-04-2019, 02:47 PM #15
shrub1's Avatar
shrub1's Avatar
Thats about what mine look like. I am ok with it.
Will the boots last 150K+ miles, probably not. Price of admission.
center , fender , front , hub , lift
What rear coil is recommended for 2" lift? 6112 in the front, 5100 in back minimalist 5th gen T4Rs 29 05-24-2019 01:14 AM
Lift recommended with or w/out KDSS? yellowdog 5th gen T4Rs 6 11-28-2016 08:19 PM
Recommended dealer service center in Maryland-DC area jamion 5th gen T4Rs 35 11-13-2016 12:52 AM
Recommended Lift Kit bryantd85 5th gen T4Rs 58 06-02-2015 02:24 AM
Aftermarket UCAs recommended for front lift only? bruinjay 5th gen T4Rs 1 01-24-2015 11:48 PM
