Monroe
Old 01-06-2019, 06:18 PM #16
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
It wonít even get to the O ring. Itís the metal housing with the 3 prongs that wonít even fit. I did an exchange through amazon so Iím waiting on the next set. Lights are super bright though so we will see if the next ones work
Ď14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinsonís 3Ē Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8ís w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 01:29 AM #17
Monroe Monroe is offline
Monroe is on a distinguished road
Here is short video I made to show the difference between Supernova V.4 and Nineo purchased from Amazon.
YouTube
Monroe is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 01:44 AM #18
BrodyUSMC BrodyUSMC is offline
BrodyUSMC is on a distinguished road
I bought them too (the Cougar ones) and I got them to seat in there, but they were not bright at all.I sent them back. I, however, kept the Highbeam ones they are super bright.
BrodyUSMC is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 09:13 AM #19
Did you make sure the LEDs were facing sideways, 9 & 3 o'clock position. The beam pattern can be allover the place if not.
I know it took me good 5 minutes for each bulb to find a sweet spot. The brights were easy since you can see them. The bulbs in lows I couldn't see because of projector lens. What I did instead is, I followed the wiring coming from the bulb that happen to be in-line to make sure it's pointing perfectly down once the bulb is locked.
Old 01-12-2019, 01:10 PM #20
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
That would frustrate the hell out of me, if you're still considering alternatives the SL1 bulbs I purchased over a year ago now from Diode Dynamics (actually did a pre-order from their launch) perform awesome and while sure - they don't illuminate any farther or wider than the stock halogen I wasn't expecting that. Just wanted them to fit like a glove, no dust cap mods, and be just as sharp on the cut off line so no other adjustment required for on coming drivers. They check all the boxes there, good warranty coverage is a plus too I guess.
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 02:11 PM #21
kaaekuahiwi's Avatar
kaaekuahiwi kaaekuahiwi is offline
kaaekuahiwi is on a distinguished road
Originally Posted by SlickTRD View Post
LED in high beam will result in non-functional DRL or lots of flickering. Only Diode Dynamics has a special module that enables normal DRL function. The module only works on their specified LED kit.
I am only recommending the Katana LEDs for low beam.
Xenon Depot makes a DRL driver for their 9005 High Beam LEDís that makes the DRL fully functional with no flicker.
2018 TRD Pro 4Runner Cavalry Blue w/ Gobi Rack
ATTACK!!
kaaekuahiwi is offline   Reply With QuoteReply With Quote
Old 01-21-2019, 03:59 PM #22
gp55445's Avatar
gp55445 gp55445 is offline
gp55445 is on a distinguished road
gp55445's Avatar
Originally Posted by Monroe View Post
Check Nineo from Amazon. Both 9005 (Hi-beams) and H11 (low beam) looks and works exactly the same as Supernova V.4 for the fraction of the cost. The color, beam pattern and output even drivers or wire protecting sleeves are identical.
I had H11 and 9005 bulbs side by side and the only difference other then price is the finish color. Supernova V.4 H11 is bright silver, where 9005 is also silver but has much darker finish. Both 9005 & H11 from Nineo are black.
Also, Supernova V.4 (Hi-beams) came with wrong locking ring with much narrower tabs where Nineo 9005 came with proper one matching OEM tabs (9005/HB3).
Have you tried these for your fogs?
gp55445 is offline   Reply With QuoteReply With Quote
Old 01-29-2019, 12:44 AM #23
No I didn't, got my Morimoto fogs before. But they should work. If you're buying from Amazon you can always return it ;)
Old 02-10-2019, 08:44 PM #24
20164runner's Avatar
20164runner 20164runner is offline
20164runner will become famous soon enough
Any problems out of the nineos so far? I just ordered some for mine.
2019 Voodoo blue TRD Pro
20164runner is offline   Reply With QuoteReply With Quote
Old 02-10-2019, 09:53 PM #25
Axix23 Axix23 is offline
Axix23 is on a distinguished road
If yall want some good quality leds/hids with awesome customer service and warranty, order these. They are also fine with the DRL's. I run their HIDS and Leds all of my vehicles since 2007. End of story. If anything is defective or goes out, they replace it with no questions asked. Super fast shipping and there are always coupon codes.
Super_Bright_LED_Headlamps - Retro-Solutions Store
Axix23 is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 05:47 AM #26
Nope. All good. Just make sure to adjust locking ring so LEDs are facing 3 and 9 o'clock.
Hint: the wire coming off the bulb need to be at 6 o'clock in locked position, I think.
Old 02-11-2019, 06:54 PM #27
4Runner 4eva 4Runner 4eva is offline
4Runner 4eva is on a distinguished road
I am experiencing the exact same issue with my set of Katanas. The passenger side went on in 5 mins, no issue. The drivers side, I can't turn it to lock. it just sits there. Even with no o-ring.
Even put into the housing (held with tape), with the LED facing 3 and 9, the pattern looks like crap. Too bad. The passengers side is awesome.
Also expecting a replacement set but its too damn cold and snowy to drop in right now.
Did you get your replacement? did it resolve your problem?
I might go back to my XD HIDs and go back to getting flashed every other car!
2019 TORP Greyhound Hauler ver 3.0
2016 TEP / TRD FAUX Greyhound Hauler ver 2.0
2000 4Runner SR5 Greyhound Hauler Extraordinaire SOLD
4Runner 4eva is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 07:02 PM #28
GX4SEVEND's Avatar
GX4SEVEND's Avatar
Yeah you have to get a replacement set sent to you. They’re manufacturing process doesn’t have the highest quality control that’s for sure. I ordered through amazon and had to wait. I put the one that didn’t fit in the socket as best I could until I got the replacement bulb.
Replacement set worked perfectly fine. Weird because my passenger side fit wrong but the drivers side was perfect.
Ď14 SR5 in white
Full RCI skids
Old 02-12-2019, 02:39 AM #29
57buick's Avatar
57buick 57buick is offline
57buick is just really nice 57buick is just really nice 57buick is just really nice 57buick is just really nice
57buick's Avatar
I used these from Headlight Revolution and I am very happy with how bright they are and a perfect beam pattern right out of the box. Although they do have an adjustment screw to adjust the angle I didn't change anything, 5 minute install and they were perfect.
https://headlightrevolution.com/2014...ed-headlights/
2018 TRD Premium, KING suspension, 285/70/17 Duratracs, 4.88 gears, Addicted offroad front Bumper, C4 FAB rear bumper, My build thread https://www.toyota-4runner.org/5th-g...ld-thread.html
57buick is offline   Reply With QuoteReply With Quote
Old 02-12-2019, 04:43 AM #30
They lost my trust and the moment they said the ring their Supernova v.4 9005 come is what is suppose to, which is total BS since Nineo has a proper locking ring matching 4Runner headlights 9005/HB3. They shut the hell up and returned my money once I sent them a photo comparison. Not only that, because of it the bulb did wiggle in fully locked position.
Nineo bulbs are exactly the same for the fraction of the price Headlight Revolution is trying to sell their top of the line crap.
I'm not saying Nineo is superior to other brands but to Supernova V.4 definitely is.
I just saved few hundred dollars by switching to Nineo 😋😂
bulb , doesnít , light , passenger , side
LED headlight question Ezlife45 5th gen T4Rs 8 07-08-2015 04:48 PM
Headlight Question OCMEDIC 4th Gen T4Rs 6 10-01-2013 11:11 PM
headlight question Duhockey 3rd gen T4Rs 7 03-09-2010 06:41 PM
Headlight question surforguy 3rd gen T4Rs 3 04-25-2007 11:18 AM
Headlight question.... WVBryan 4th Gen T4Rs 6 01-25-2007 07:03 PM
