Monroe
Old 02-12-2019, 06:05 PM #31
20164runner's Avatar
20164runner 20164runner is offline
20164runner will become famous soon enough
Originally Posted by Monroe View Post
They lost my trust and the moment they said the ring their Supernova v.4 9005 come is what is suppose to, which is total BS since Nineo has a proper locking ring matching 4Runner headlights 9005/HB3. They shut the hell up and returned my money once I sent them a photo comparison. Not only that, because of it the bulb did wiggle in fully locked position.
Nineo bulbs are exactly the same for the fraction of the price Headlight Revolution is trying to sell their top of the line crap.
I'm not saying Nineo is superior to other brands but to Supernova V.4 definitely is.
I just saved few hundred dollars by switching to Nineo LED headlight questionLED headlight question
Just put mine in and I'm happy. I used the rubber gaskets from the stock bulbs and everything is good. They're hella good imo. Let's see how long they last.
20164runner is offline   Reply With QuoteReply With Quote
Old 02-14-2019, 05:52 PM #32
pumacat24's Avatar
pumacat24 pumacat24 is offline
pumacat24 has a spectacular aura about pumacat24 has a spectacular aura about
pumacat24's Avatar
Talking
Hey,
I bought the same Cougar Motor H11/9005 on Amazon too.
Installed 9005 first as they were easiest, no issues. They run fine on DRL no flickering and the brights are BRIGHT!!!
As I was running out of daylight to installed I then went for the driver's side low beam first. I figured if I could get the difficult side finished first w/o taking out battery that the passenger side would be no problem. Boy, was I wrong!
The light just would not fit in no matter what I did. I changed o rings from stock light, I watched a video to make sure I wasn't missing something random.
I put the stock bulb back in just to prove I could do it, and then continued to struggle for 45 mins trying to put this stupid bulb in. I called my husband to come out and look at it. He struggled also, until we had a EUREKA moment!
He was holding a flashlight watching me try to install the LED bulb when he saw that there is a small piece of metal blocking the entry of the LED bulb housing.
Once he saw that, he used his grinder and barely shaved off 1/16" to 1/32" of the area I circled in the picture.
You have to line it up to see exactly which area to sand down bc the tabs are different sizes.
PERFECT FIT, and the lights are amazingly bright.
Hope this helps someone else.
LED headlight question-71rhx-8k98l-_sl1080_-jpg
2019 TRD Pro | IG: @trdprocat | RSG Sliders | Falken Wildpeak AT3W | Morimoto/XD LEDs | CTX Tint
past: '18 4Runner TRD ORP... RIP, Kaiyo!
'07 4Runner SE... SOLD
'02 4Runner SR5 4WD... SOLD
pumacat24 is offline   Reply With QuoteReply With Quote
Old 02-14-2019, 06:23 PM #33
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
I’m glad they fit.....however, you should not have to grind metal off the headlight bulb in order to make them fit. Not everyone will have the tools to do so. I still think they should be made correctly from the start.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 02-14-2019, 06:29 PM #34
pumacat24's Avatar
pumacat24's Avatar
Sure, I know what you mean, but it’s a piece of metal on the 4runner that makes it not fit only on the passenger side. Eh. It is what it is.
You can buy sandpaper and just sand it down a smidge.
Personally, I’d rather do that than risk humidity issues in my headlights than by having to mod the dust cover.
To each their own. LED headlight question
Old 02-14-2019, 06:31 PM #35
GX4SEVEND's Avatar
GX4SEVEND's Avatar
Yeah that’s why I got rid of the HID. I didn’t want to mess with the dust covers
‘14 SR5 in white
Full RCI skids
Old 02-15-2019, 11:58 AM #36
4Runner 4eva 4Runner 4eva is offline
4Runner 4eva is on a distinguished road
Originally Posted by GX4SEVEND View Post
Yeah you have to get a replacement set sent to you. They’re manufacturing process doesn’t have the highest quality control that’s for sure. I ordered through amazon and had to wait. I put the one that didn’t fit in the socket as best I could until I got the replacement bulb.
Replacement set worked perfectly fine. Weird because my passenger side fit wrong but the drivers side was perfect.
Finally got my replacement too and the weather warmed up past sub-artic so finally able to install. The replacement fit perfect and no issues.
So, word to the wise on the Katana's from Amazon. Great customer service in trying to resolve the situation but the quality control is DEFINITELY hit or miss.
For now, I'll see how I like them. Definitely brighter than OEM but not as much as XD HIDs. And since I already drilled the holes in my dust caps for the HIDs, I just ran the wiring and pack thru the vacated hole and can still use the dust caps. Of course its not water tight and hopefully they won't overheat being enclosed.
2019 TORP Greyhound Hauler ver 3.0
2016 TEP / TRD FAUX Greyhound Hauler ver 2.0 SOLD
2000 4Runner SR5 Greyhound Hauler Extraordinaire SOLD
4Runner 4eva is offline   Reply With QuoteReply With Quote
Old 02-15-2019, 01:51 PM #37
kelkins kelkins is offline
kelkins will become famous soon enough
I’ve tried morimoto LEDs and the “cheap, but same as” Super Nova V4 LEDs in my 4Runner and they simply aren’t as bright as my HID kit. I never get flashed, have them aimed correctly, and am happy with the light output. No where as nice as the retrofit that I did on my last truck, but certainly good enough for now.
kelkins is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 01:24 AM #38
nbtrdrunner nbtrdrunner is offline
nbtrdrunner is on a distinguished road
Little update.......bought the katana kit....one light fits perfect. Lines up perfect. The other does not. Switched sides. One light works fine. The other does not fit regardless of what you do. Will not for in the housing without getting stuck or having to pound it in. Should not be this difficult to install lights. I’m sure other kits from them have worked fine but this did not. Second kit I’ve bought and have spent $100 total and wasted time and effort into this for headlights.
So definitely purchase this kit with caution. Like I said, one fit perfect and was aligned perfect out of the box. The other doesn’t even fit at all.
i had the same exact problem with the cougar motor led headlights,.....driver side projected great and passenger did not. I bought some philips led fog lights and now it is nice and bright.whole setup 200$
nbtrdrunner is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 01:51 PM #39
gpilarte14 gpilarte14 is offline
gpilarte14 is on a distinguished road
Nineo led
Hi, Can you tell me if still do you have the Nineo led lights on your 4 runner? I want to update my lights but I am not sure If I want to pay for Supernova V4, please advise.
gpilarte14 is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 01:59 PM #40
GX4SEVEND's Avatar
GX4SEVEND's Avatar
I’m running the katana kit from amazon and after a fitment issue in the first set the second set has been fine. You definitely need an adjustable beam on the light. Cougar Motor does not and they didn’t line up no matter what I did.
‘14 SR5 in white
Full RCI skids
Old 08-02-2019, 03:14 PM #41
Monroe Monroe is offline
Monroe is on a distinguished road
Yes, no issues at all. Good as the day they went in.
it is exactly same bulb as Supernova V4, same brightness , different finish with much better fitment due to matching mounting tabs used by Nineo vs standard used by Supernova.
Monroe is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 07:26 PM #42
thank you, one more question How do you use the High beam and DRL ?.. did you get something else?
Old 08-05-2019, 07:45 PM #43
I did DRL cancelation mod. Bought used DRL relay on eBay and bend one tab (contact). Just search for DRL cancelation.
But you can buy LED DRL module to prevent flickering if you want and keep em.
Old 08-13-2019, 04:05 PM #44
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
My 19 OR has a DRL position on the stalk, if I choose not to use it would there be any problem with the nineo's?
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 07:51 PM #45
There is no problem using any LED bulbs in low beams or hi-beams. The only problem is a flickering of hi-beams in DRL position. Basically Toyota is using hi-beam bulbs and lower voltage. So when you install any LED bulb in a hi-beam they will flicker (barely noticeable but still) in DRL position unless you install LED module.
bulb , doesn’t , light , passenger , side
LED headlight question Ezlife45 5th gen T4Rs 8 07-08-2015 04:48 PM
Headlight Question OCMEDIC 4th Gen T4Rs 6 10-01-2013 11:11 PM
headlight question Duhockey 3rd gen T4Rs 7 03-09-2010 06:41 PM
Headlight question surforguy 3rd gen T4Rs 3 04-25-2007 11:18 AM
Headlight question.... WVBryan 4th Gen T4Rs 6 01-25-2007 07:03 PM
