Monroe
Old 01-03-2019, 01:38 AM #1
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is online now
GX4SEVEND will become famous soon enough GX4SEVEND will become famous soon enough
GX4SEVEND's Avatar
LED headlight question
So I bought an amazon LED kit, the Cougar Motors that everyone seems to say is good, but for whatever reason the passenger side light just doesnít project. Thought is was the bulb so I switched sides but it works fine on the left. On the passenger side the way it sits in the housing itís almost as if the bulb is turned and seated facing the wrong way so it doesnít project light. Still looks like itís on but doesnít throw light at all like the drivers side. I spent 45 minutes trying to see if there was another way to install it and there isnít. Any clue how to fix this or just buy a new kit?
Ď14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinsonís 3Ē Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8ís w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is online now   Reply With QuoteReply With Quote
Old 01-03-2019, 02:45 AM #2
kyle13 kyle13 is offline
kyle13 is on a distinguished road
I had the exact same issue with the exact same kit. I ended up returning the lights and getting a pair that has the ability to adjust the bulb and they light up evenly now! Not that much brighter than the stock halogens. Iíd get a pair from headlight revolution they make a pair designed and test for the 4Runner and they are bright as frig!
kyle13 is offline   Reply With QuoteReply With Quote
Old 01-03-2019, 02:57 AM #3
GX4SEVEND's Avatar
GX4SEVEND's Avatar
I was trying to do this without spending the $150-200 for LED lights since they really just arenít as bright as the HID kits. I ran DDM kits for years and at like $50 they canít be beat. Thought Iíd try this route but I just donít want to spend that much on LEDís thatís arenít that much brighter than halogen just a different color. I will see what I can find locally so I can test fit.
Ď14 SR5 in white
Full RCI skids
Old 01-03-2019, 07:44 AM #4
SlickTRD SlickTRD is online now
SlickTRD will become famous soon enough SlickTRD will become famous soon enough
From a h9 halogen to h11 led user, i can say that some leds have now surpassed halogens in terms of lux and lumens. So far the highest rated leds are the supernova v4 and the morimoto 2stroke 2.0. The word on the street is the supernova v4 and katana are the same leds but minus the huge markup. Check out bulbfacts on the highest rated leds. Hids will still outperform leds but slim leds wont need dustcap modifying.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar
SlickTRD is online now   Reply With QuoteReply With Quote
Old 01-03-2019, 11:46 AM #5
GX4SEVEND's Avatar
GX4SEVEND's Avatar
The question is......do they fit the 4Runner? I mean they might fit but does the passenger side actually project light? The kit I bought doesnít so itís how the bulb actually fits the housing. And yeah modifying the dust cap Iíd also rather not do
Ď14 SR5 in white
Full RCI skids
Old 01-03-2019, 12:13 PM #6
Yes, it does fit and they offer adjustable beam pattern. I run the Morimoto 2stroke 2.0 and the fitment is perfect and they are supposedly a little deeper than the Katana/Supernova v4. The output and color temp is better than stock or h9 halogen. If I could do it again I would go for the Katana kit cause the output is slightly higher but way cheaper.
BulbFacts | Best Recommended LED Headlight Kits
Old 01-03-2019, 12:19 PM #7
GX4SEVEND's Avatar
GX4SEVEND's Avatar
Ok well amazon has they for $95 for low and high beams. I hope these work since Iím running out of options
Ď14 SR5 in white
Full RCI skids
Old 01-03-2019, 01:03 PM #8
Ok well amazon has they for $95 for low and high beams. I hope these work since I’m running out of options
LED in high beam will result in non-functional DRL or lots of flickering. Only Diode Dynamics has a special module that enables normal DRL function. The module only works on their specified LED kit.
I am only recommending the Katana LEDs for low beam.
Old 01-03-2019, 02:04 PM #9
GX4SEVEND's Avatar
GX4SEVEND's Avatar
Ok Iíve already got the DRLís anyway. I just need the low beams to work. If you know these work I will order them
Ď14 SR5 in white
Full RCI skids
Old 01-03-2019, 11:29 PM #10
Monroe Monroe is offline
Monroe is on a distinguished road
Check Nineo from Amazon. Both 9005 (Hi-beams) and H11 (low beam) looks and works exactly the same as Supernova V.4 for the fraction of the cost. The color, beam pattern and output even drivers or wire protecting sleeves are identical.
I had H11 and 9005 bulbs side by side and the only difference other then price is the finish color. Supernova V.4 H11 is bright silver, where 9005 is also silver but has much darker finish. Both 9005 & H11 from Nineo are black.
Also, Supernova V.4 (Hi-beams) came with wrong locking ring with much narrower tabs where Nineo 9005 came with proper one matching OEM tabs (9005/HB3).
Monroe is offline   Reply With QuoteReply With Quote
Old 01-04-2019, 12:04 AM #11
hasoon2000 hasoon2000 is offline
hasoon2000 is on a distinguished road
I bought the Auxbeam T1 series for my low beams. I had their F16 series and I switched to their new T1 series sometime in June. The T1 model bulbs has an adjustable knob from behind so you can level it with your driver side bulb. It's also slightly brighter than their F16 series. It a very clear white and I'm very happy with them.
Auxbeam T1 Series H11 Temperature Control LED Headlight Bulbs
Current vehicles: 2016 Toyota 4Runner Limited 4.0L / 2016 GMC Terrain Denali 3.6L
Former vehicles: 2013 GMC Terrain SLE-2 / 2003 GMC Envoy SLT 4.2L / 2001 Infiniti QX4 3.5L / 2002 Buick Regal 3.8L SC / 1998 Nissan Maxima GXE 3.0L
Mobile Automotive Programmer. If you have questions about module programming (PCM, TCM, etc), feel free to PM me. Located in the Chicago-land area.
hasoon2000 is offline   Reply With QuoteReply With Quote
Old 01-04-2019, 08:31 AM #12
Forgot to mention you may need PWM module to prevent Hi-beams from flickering unless you disable DRLs.
Old 01-06-2019, 02:00 AM #13
GX4SEVEND's Avatar
GX4SEVEND's Avatar
Little update.......bought the katana kit....one light fits perfect. Lines up perfect. The other does not. Switched sides. One light works fine. The other does not fit regardless of what you do. Will not for in the housing without getting stuck or having to pound it in. Should not be this difficult to install lights. I’m sure other kits from them have worked fine but this did not. Second kit I’ve bought and have spent $100 total and wasted time and effort into this for headlights.
So definitely purchase this kit with caution. Like I said, one fit perfect and was aligned perfect out of the box. The other doesn’t even fit at all.
Ď14 SR5 in white
Full RCI skids
Old 01-06-2019, 10:52 AM #14
rushrunner rushrunner is offline
rushrunner will become famous soon enough
Little update.......bought the katana kit....one light fits perfect. Lines up perfect. The other does not. Switched sides. One light works fine. The other does not fit regardless of what you do. Will not for in the housing without getting stuck or having to pound it in. Should not be this difficult to install lights. Iím sure other kits from them have worked fine but this did not. Second kit Iíve bought and have spent $100 total and wasted time and effort into this for headlights.
So definitely purchase this kit with caution. Like I said, one fit perfect and was aligned perfect out of the box. The other doesnít even fit at all.
I really think it is a flaw with the bulb housing. I think the tolerances are not the same, and therefore the bulbs do not seat correctly. I went back to Sylvania Ultra's and they are pretty good. Much better than the stock and fit perfectly.
Past:1991 Lumina Euro 3.1, 1994 Cutlass SL 3.4, 1999 Intrigue GL, 2003 CTS, 2006 Saab 97x, 2009 4Runner SE (should of never traded it in), 2012 SRX, 2015 Charger Rallye, Current: 2018 4Runner Limited (glad to be back)
rushrunner is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 02:57 PM #15
Remove the Katana O ring and use your OEM halogen bulb O ring, i find OEM halogen O rings to be of higher quality and thinner to make non-OEM bulbs like LEDs fit better.
bulb , doesnít , light , passenger , side
LED headlight question Ezlife45 5th gen T4Rs 8 07-08-2015 04:48 PM
Headlight Question OCMEDIC 4th Gen T4Rs 6 10-01-2013 11:11 PM
headlight question Duhockey 3rd gen T4Rs 7 03-09-2010 06:41 PM
Headlight question surforguy 3rd gen T4Rs 3 04-25-2007 11:18 AM
Headlight question.... WVBryan 4th Gen T4Rs 6 01-25-2007 07:03 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
