Originally Posted by AKBrown
So the DRL is needed with Toyota 4Runners? Has anyone had both LED and DRL drives for high and low? Im asking because we rarely use high beams in FL and if I do need a high beam I use the light bar.
Needed? In the US they aren’t mandatory to run.
I’m not sure what you’re asking, but I have both high and low beam LED. Both have “drivers” but the high beam I linked earlier from xenon depot works specifically to our high beam lights to allow running at a lower Lumen output while in DRL mode.
You could run a regular high beam LED without the special driver and it’ll work just fine except if you turn on your DRLs. Then it’ll either flicker or be too bright with DRLs on. The high beams will work normally.
As for using a light bar on public roads, there are a few laws that can get you in law enforcement attention if you have them on like whether they are DOT approved, will blind oncoming traffic, or will exceed the number of running lights you have on (varies by state).
