Monroe
Old 10-01-2019, 02:15 AM #61
Vultradamus Vultradamus is offline
Vultradamus is on a distinguished road
Originally Posted by chihbin2000 View Post
Curious, clicked on the link on the Youtube Video Description, and Verizon says its a non-functioning website.
Vultradamus is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 11:35 AM #62
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
Originally Posted by Jonny_04 View Post
i used a spade drill bit for the dust cap. If you leave the dust cap off, you'll run into problems with moisture and dirt getting inside of your housing.
Did you apply some silicon or anything around the cable to keep it sealed?
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 08:16 PM #63
Jonny_04's Avatar
Jonny_04 Jonny_04 is offline
Jonny_04 is on a distinguished road
Jonny_04's Avatar
no, if you're replacing with an aftermarket bulb; it should have a rubber grommet that fits and seals the hole after you have drilled the dust cap. If the hole that's drilled into the dust cap is slightly bigger than the rubber grommet than yes i would place tape around it to prevent moisture from getting inside.
https://www.youtube.com/watch?v=Pf9_c7QTCEU&t=379s (you'll see what im talking about starting around the 2:30 mark)
'19 TRD Off Road Premium w/kdss| King shocks 2.5 w/adjusters| Total Chaos uca| Icon 2" rear coil| Nitto Ridge Grapplers 305/70/17| stealth custom series Ray 10 17x9 -38| Rigid Industries D-series amber fog lights| Morimoto HID & LED| Outgear Solutions full roof rack| Outgear Solutions rock sliders| RCI Steel Skid Plate| Drawer System
Jonny_04 is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 09:20 PM #64
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
The katanas fit inside the dust cap. I didn’t modify or cut anything for them to fit and have zero issues.
As for adjusting, do it while it’s darker out and aim it against a garage door or something so you can watch the beam pattern.
The HID kits you’ll need to modify the dust cover. These you don’t
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 11:07 PM #65
Thanks. Of course I figured that out after drilling a 1/2" hole in each cover.
I'll find a 1/2" rubber plug at the hardware store.
Build thread
Old 12-01-2019, 10:12 AM #66
josephp732 josephp732 is online now
Real Name: Joe
josephp732 is on a distinguished road
Real Name: Joe
I tried a few LED kits but each would have dark spots or a broken beam pattern. I found the Katana works extremely well in my three 4Runner's. I get a really nice beam pattern, a good match to my OEM pattern with a much higher brightness and no dark spots. I agree with some other forum members - this bulb seem to match the Supernova V4's at a third of the price.
Installation in my 4Runner's was a bit tight, the cable and LED driver are a little larger than some other bulbs. I just took some time to try a few different ways of mounting and installing the LED driver behind the headlight housings dust cover. I found the best way to get everything to fit, was to connect the factory wiring to the LED driver and get it installed with the drivers base flat against the bulbs solid aluminum mounting block, then install the bulb and connect it to the driver.
I also decided to keep halogen's in the high beams because of the DRL flickering issue, I did replace the stock 9005's with 100W temperature matched bulbs that are super white and come close to the LED's.
Upgraded the fog lights with a inexpensive Alla Lighting 2800lm LED Fog Lights Bulbs set that seems to work well. I choose these because of the internal driver - time will tell if they hold up.
All in I am very happy with the results - far improvement over stock.
2019 White 4Runner Limited - NJ
2019 Black 4Runner TRD Off Road - NJ
2019 Silver 4Runner Limited - FL
josephp732 is online now   Reply With QuoteReply With Quote
Old 12-01-2019, 03:37 PM #67
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I just ordered katana. For the fogs, are these the ones ?
Thx,
Alla Lighting 2800lm H8 H11 LED Fog Lights Bulbs Xtreme Super Bright High Power COB-72 Cars Trucks H16 H11 LED Foglights DRL Replacement, 6500K Cool Xenon White https://www.amazon.com/dp/B07G5WJ4ZK..._txb5DbMP9BWJD
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 06:18 PM #68
Real Name: Joe
Real Name: Joe
Yes, those are the LED fog light bulbs that I am running. Seem to be a nice match to the Katana low beams. Let me know how you like them after you get the installed.
Old 12-01-2019, 08:55 PM #69
Thanks Fogs are arriving Tuesday and low beams Wednesday
Old 12-03-2019, 01:29 AM #70
Fogs arrived today. They are nice and bright. Thanks for the recommendation. The low beams I have now are Fahren, also from amazon. I plan to swap them out with the Katana as these have some defect on the cutoffs.
Old 12-04-2019, 04:21 AM #71
Real Name: Joe
Real Name: Joe
I tried the Fahren bulbs also, I found the same as you not a great cut-off and a few dark spots, switching to the Katana bulbs was a very noticeable and positive change. Using the Alla fog bulbs with the Katana low beams, to me, provides a great coverage pattern, I think they work very well together.
Old 12-04-2019, 04:43 AM #72
These led h11 are okay, but they are not as bright as Oem led like Bmw and Lexus. But they will do until I get something like morimoto xb. I just want to see them in person before I buy them.
Old 12-13-2019, 03:03 AM #73
macscac's Avatar
macscac macscac is offline
macscac has a spectacular aura about macscac has a spectacular aura about macscac has a spectacular aura about
macscac's Avatar
Are these the katanas on amazon?
KATANA H11 LED Headlight Bulbs w/Mini Design,10000LM 6500K Cool White CREE Chips H8 H9 All-in-One Conversion Kit
$35.99 a pair
macscac is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 07:28 AM #74
LED headlight question
$35.99 a pair
Here are the katana h11 I got. They are awesome. Very bright as drl and nice high beams. There’s some flicker as drl but barely noticeable.
The ones I got are $48.99.
KATANA H11 H8 H9 LED Headlight... https://www.amazon.com/dp/B078W5WJZ2...p_mob_ap_share
Old 01-04-2020, 12:05 AM #75
tstevens tstevens is offline
tstevens is on a distinguished road
Glad I found this post! Previous owner installed Auxbeam LED's and the passenger side low-beam output was essentially non-existent because of how the LED was sitting in the projector.
Ordered some Nineo's off Amazon, delivered in a day and they are night and day better than the Auxbeams. Took me about 30 minutes to get the adjustable mounting right but once I got them in place they are solid! Perfect fit, no issues whatsoever. Adjusted the aim on the headlights themselves and am thoroughly impressed. The fan on the Nineos are about 20X quieter than the Auxbeams, you can barely hear them with the engine off. The Auxbeam fans you could audibly hear with the engine running.
FWIW, my high-beams are also Auxbeam and they work great, extremely bright. If/when the Auxbeam high-beams go out, will be ordering Nineo's as replacements.
tstevens is offline   Reply With QuoteReply With Quote
bulb , doesn’t , light , passenger , side
LED headlight question Ezlife45 5th gen T4Rs 8 07-08-2015 04:48 PM
Headlight Question OCMEDIC 4th Gen T4Rs 6 10-01-2013 11:11 PM
headlight question Duhockey 3rd gen T4Rs 7 03-09-2010 06:41 PM
Headlight question surforguy 3rd gen T4Rs 3 04-25-2007 11:18 AM
Headlight question.... WVBryan 4th Gen T4Rs 6 01-25-2007 07:03 PM
